Go to Post Darn IFI and AndyMark for making quality products! :) - Gabe [more]
Unread 22-02-2012, 17:03
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
Re: 2084 Mecanums with Worm Drive
Originally Posted by Tristan Lall View Post
I should probably have been more precise: that's not an efficiency loss in the wheel, but only about 70.7% of the torque available at the wheel can be used for forward motion, because of the sideways component of the wheel's friction force. (I suppose this assumes equal frictional coefficients in all directions.)
That's a friction dependent limit, though. If your wheels aren't slipping, then you're getting 100% of the gearbox's output torque applied to forward motion. Thus, your "efficiency"/pushing force calculation above is bunk. The drivetrain's forward pushing ability is limited to EITHER 80% of the theoretical output torque of the gearbox or 70.7% of the available friction force, as calculated from mu and the normal force. The two limits are unrelated, so multiplying those two numbers together is meaningless.
Unread 22-02-2012, 18:48
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
I will retract that expression—you're right, that's not valid for the case where the wheels are not slipping, which is most of driving around.
I was mistakenly conflating it with the limiting torque for mecanum wheel slip in forward motion, at which point you've got all of the available torque at the wheel spinning it, but not all of the frictional force in the longitudinal direction that you'd expect with a conventional wheel. (This is relevant when you're figuring out if your motors will stall before your wheels slip.) And even in that case, as Ether and Kevin noted, it's better expressed as a mechanical efficiency and a geometry constraint. They end up multiplied (or more accurately, divided) in the equation, but they're not part of the same quantities.
