Go to Post and the only thing i see as a disadvantage to those long hours of hard work is a little less time to spend with my girlfriend - h1n1is4pigs [more]
Unread 22-02-2012, 19:04
Ian McShane Ian McShane is offline
FRC #3585 (Rogue Robots)
Ian McShane will become famous soon enoughIan McShane will become famous soon enough
Button Command
is there a way to end a command when you press a button. EG.
"MoveArmDown" would be a command telling the arm to go down
"End" would be the syntax to end the command
"downSwitch" would be the button
downSwitch.whenPressed(End MoveArmDown)
What would "End" be?
in FIRST, it's process over product, and team over robot.
http://www.roguerobotsof4h.com/
Team 3585 Rogue Robots of 4-H
