Go to Post The championship event is a meta-game of inches. People will complain about unbalanced/unequal divisions, whether you think it's silly or not. - PayneTrain [more]
Unread 22-02-2012, 19:04
Ian McShane Ian McShane is offline
FRC #3585 (Rogue Robots)
Ian McShane will become famous soon enoughIan McShane will become famous soon enough
Button Command
is there a way to end a command when you press a button. EG.
"MoveArmDown" would be a command telling the arm to go down
"End" would be the syntax to end the command
"downSwitch" would be the button
downSwitch.whenPressed(End MoveArmDown)
What would "End" be?
in FIRST, it's process over product, and team over robot.
http://www.roguerobotsof4h.com/
Team 3585 Rogue Robots of 4-H
Unread 22-02-2012, 19:40
mwtidd's Avatar
mwtidd mwtidd is offline
AKA: mike
FRC #0319 (Big Bad Bob)
Re: Button Command
assuming you were using a motor:
buttonA.onPress(new LowerArm())
buttonB.onPress(new StopArm())
LowerArm never actually finishes but rather is interrupted by StopArm
**just make sure they both require the arm subsystem or you may have some explaining to do as to why the arm ate itself.
Unread 23-02-2012, 23:59
Sunstroke Sunstroke is offline
Programmer
AKA: Joe Grinstead
FRC #3504 (Girls of Steel)
Sunstroke is an unknown quantity at this point
Re: Button Command
You can also do downSwitch.whileHeld(<command goes here>);
The whileHeld method will constantly call start() on the command (which means if the command stops, it will restart, but otherwise there is no difference) while the button is held, and then it will cancel the command when the button is released (so the command will die, calling its interrupt method).
