Go to Post Building things from scratch builds character. - davidthefat [more]
Unread 22-02-2012, 19:46
siggy2xc siggy2xc is offline
AKA: Tyler Siegrist
FRC #1756 (Argos)
siggy2xc is an unknown quantity at this point
Controls on dashboard
I can create indicators on the dashboard but I would also like to be able to put some controls on as well. How would I go about doing this?
Unread 23-02-2012, 09:06
zaphodp.jensen zaphodp.jensen is offline
Alumni and Mentor of 3130
AKA: Pierce Jensen
FRC #3130 (East Ridge Robotics Ominous Raptors (E.R.R.O.R.'s))
zaphodp.jensen is a jewel in the roughzaphodp.jensen is a jewel in the roughzaphodp.jensen is a jewel in the rough
Re: Controls on dashboard
Use a UDP port to communicate data back to the robot. Currently, we have offboarded our vision processing to the driver's station, and have a couple of customizable controls on the dashboard.
The hardest thing is trying to encode your data into strings, because UDP Ports only accept data as a string.
Give me two hours and I will post some example code.
Unread 23-02-2012, 13:31
demons858 demons858 is offline
FRC #0858 (Demons)
demons858 is an unknown quantity at this point
so what happened to the two hours I think this is what im looking for too
Unread 23-02-2012, 15:09
AKA: Pierce Jensen
School came up. I am working on the example code right now.
Unread 23-02-2012, 15:22
FRC #0858 (Demons)
Thnats understandible school comes first
Unread 23-02-2012, 15:38
AKA: Pierce Jensen
Ok, here we go. This is a short example that encodes a Decimal Numeric, a Boolean, and a string and sends it over UDP from the dashboard to the Robot, at which point it is decoded and sent out in the exact same data types.
You can re purpose this to send data back to the dashboard by switching the port and IP addresses on the UDP reads and writes.
For a more in depth project, I off boarded our vision processing to our dashboard, and sent the target information back to the robot. I can post this code, although it is significantly more in depth than this code.
If you have any other questions, feel free to either PM me, or post on this thread again.
Name:	UDP String Example.png
Unread 23-02-2012, 17:03
plnyyanks's Avatar
plnyyanks plnyyanks is online now
Data wins arguments.
AKA: Phil Lopreiato
I have some example code attached to this post. Take a look, and I'll gladly answer any questions that might arise.
Unread 23-02-2012, 19:14
FRC #0858 (Demons)
Thanks a ton
Unread 24-02-2012, 00:28
AKA: Tyler Siegrist
FRC #1756 (Argos)
Thanks a ton guys, I'll be trying this out at the next meeting!
