Go to Post Any school official who isn't tickled pink by hundreds high school students, and teachers, and parents, and mentors spending their weekend celebrating STEM isn't a school official worth having. - Ian Curtis [more]
  #31   Spotlight this post!
Unread 22-02-2012, 20:07
militaryrobot's Avatar
militaryrobot militaryrobot is offline
FRC #0647
militaryrobot is an unknown quantity at this point
Re: Things Learned During Build Season
When something works don't take it apart then make it lighter. Then not put it back together and it not work. Don't do this the hour before build ends.
Our robot is less then two feet
  #32   Spotlight this post!
Unread 22-02-2012, 20:15
DominickC DominickC is offline
FRC #0023 (PNTA)
Rookie Year: 1620
DominickC is an unknown quantity at this point
Originally Posted by MathMaven View Post
A better one: Finish the robot early so that the programmers have time to PROGRAM. Seriously, we need time to write and, more importantly, to test our code. My two years so far were awful because of this, and year three likely will be stressful again.
+1,000,000!
  #33   Spotlight this post!
Unread 22-02-2012, 20:17
AcesJames's Avatar
AcesJames AcesJames is offline
Mentor, still learning
AKA: James Temple
FRC #2170 (Titanium Tomahawks)(EWCP)
AcesJames has a reputation beyond reputeAcesJames has a reputation beyond reputeAcesJames has a reputation beyond reputeAcesJames has a reputation beyond reputeAcesJames has a reputation beyond reputeAcesJames has a reputation beyond reputeAcesJames has a reputation beyond reputeAcesJames has a reputation beyond reputeAcesJames has a reputation beyond reputeAcesJames has a reputation beyond reputeAcesJames has a reputation beyond repute
Send a message via AIM to AcesJames Send a message via MSN to AcesJames
Do it right the first time. If you don't, you'll waste enough time and material to build a second robot.
FRC 176 - Aces High - 09-12 - Student
FRC 229 - Division By Zero - 13-14 - "Mentor"
FRC 2170 - Titanium Tomahawks - 17-Now - Mentor
  #34   Spotlight this post!
Unread 22-02-2012, 20:36
Leeebowitz Leeebowitz is offline
AKA: David
FRC #2115 (Nightmares)
Leeebowitz is an unknown quantity at this point
It sounds cliche, but the most important ingredient for a successful robot is devoted team members. Our team lost access the machine shop we had always used in years past, and all we were left with was a drill press, a band saw, and some hand tools. It took some serious stripping down of designs to work with these limitations. And yet, if anything, our robot came out better this year than in previous years because there was a small group of students and mentors who were willing to work hard and stay to all hours of the night to get the robot done.
  #35   Spotlight this post!
Unread 22-02-2012, 20:59
andreboos andreboos is offline
FRC #3021 (The Agency)
andreboos is a jewel in the roughandreboos is a jewel in the roughandreboos is a jewel in the roughandreboos is a jewel in the rough
An 8" ball has no traction in an 8" wide chute.
Sometimes, science must defer to progress.
Any tests performed with damaged equipment can and should be ignored retrospectively when damage is discovered. Particularly, multimeter continuity checks.
Corollary 1: Case shorts in motors (BaneBots, in particular) aren't revealed by damaged multimeters.
Corollary 2: Re-test said motors after replacing the multimeter.
Bumpers can, and in some cases, should, be made and painted as soon as the frame is available and interferences can be tested.
Victors and Spikes are very picky about PWM cable insertion angle.
Wiring takes twice as long as you expect, especially when you plan around this fact.
Hands are not reliable encoder mounts.
Our statistics would indicate that one of our flathead screwdrivers is more dangerous than the entire machine shop.
Laryngitis improves communication quality by raising the "vocalization threshold". This is supported by multiple cases in our leadership this season.
Success tends to occur when or where cameras are off or pointed elsewhere.
6-conductor modular terminals do not crimp correctly in a 4-pin crimper.
5 volts means 5 volts, not 12 volts.
The cRIO can read from a controller after being disabled, and act accordingly when it is re-enabled.
Digital inputs read "true" unless pulled low, by a limit switch, for example. Input values should be verified in hardware and software before being used as limits.
Corollary: Hard stops are advisable.
  #36   Spotlight this post!
Unread 22-02-2012, 21:41
daltonmead daltonmead is offline
FRC #3021 (The Caiman Agents)
daltonmead is an unknown quantity at this point
When problems within your team arise (ie drama, rivalry, jealousy, etc) address it immediately. Pull in a nuetral person to mediate. A team in discord cannot accomplish the mission no matter how hard you try. So step up and be a leader where no else will.
  #37   Spotlight this post!
Unread 22-02-2012, 22:12
Chris86 Chris86 is offline
FRC #4064 (Inzombiacs)
Chris86 is a splendid one to beholdChris86 is a splendid one to beholdChris86 is a splendid one to beholdChris86 is a splendid one to beholdChris86 is a splendid one to beholdChris86 is a splendid one to beholdChris86 is a splendid one to behold
As a former FIRST student, freshman in college, and new lead mentor for a rookie team... I learned that as much as I thought my mentors did for my team and I, they actually did 10x more. I never would have believed the amount of time and effort mentors have to spend doing things for the team beyond what the students even see.
As far as technical things go: I also taught myself wiring, serial programming, motor curves, and a couple other things to be able to be the best mentor I could be for my new team.
Current mentor for Team #4064
Proud former member of Team #86: Team Resistance 2007-2011
  #38   Spotlight this post!
Unread 22-02-2012, 22:21
Generator of Entropy
FRC #2973 (The Mad Rockers)
Set screws don't.
You can never own too many power tools. For graduation you might want a car or some furniture. Ask for a nail gun and a miter saw instead - you'll thank me later.
If your wife is an RN, she can accurately tell what your blood pressure is just by looking at the swelling around your eyes when you get home.
  #39   Spotlight this post!
Unread 22-02-2012, 22:31
hurtzmyhead hurtzmyhead is offline
AKA: Shane
hurtzmyhead is a glorious beacon of lighthurtzmyhead is a glorious beacon of lighthurtzmyhead is a glorious beacon of lighthurtzmyhead is a glorious beacon of lighthurtzmyhead is a glorious beacon of lighthurtzmyhead is a glorious beacon of light
Summary, Trust but verify. This goes for:
  1. Motors (Rs-775s)
  2. Models (Downloaded a model a motor and the mounting holes were off)
  3. Welded Parts (Squareness, Measurements, etc...)
  4. Window Motor movement (This can screw up attempts at precision movement)
  5. and is a generally good idea
  #40   Spotlight this post!
Unread 22-02-2012, 23:08
Grim Tuesday's Avatar
AKA: Simon Bohn
FRC #0639 (Code Red)
Originally Posted by Gary Dillard View Post
Set screws don't.
Quoted for truth.
We used set screws on our RS550's in double doozy's, and after a bit of mild use, they both broke within seconds of each other, chewing up the gears in the process.
  #41   Spotlight this post!
Unread 28-02-2012, 16:31
moonlight's Avatar
moonlight moonlight is offline
3574 Alumni-Wiring & Awards Mentor
AKA: Karina Adame
FRC #3574 (High Tekerz)
moonlight will become famous soon enoughmoonlight will become famous soon enough
Wink Re: Things Learned During Build Season
i don't think it's cliche what you say it's actually true. If you have a great place with all the tools you need, but your team doesn't really function as a team, then things won't get done the way they should.A small team can accomplish big things as long as they are passionate about what they do and work hard towards the same goal. I honestly believe that the problems we face and the challenges we overcome together makes us stronger as a team, and i think it's amazing that you guys kept on going no matter the circumstances. That's what FIRST is about and i have no doubt your team will do great at competition! good luck!
Karina Adame
Team Captain
Chairman's award Lead
"Scientist study the world as it is; Engineers create the world that's never been"
  #42   Spotlight this post!
Unread 28-02-2012, 16:40
flippy147852's Avatar
flippy147852 flippy147852 is offline
respect the hat
AKA: Felipe Agurto
FRC #1918 (NC GEARS)
flippy147852 is an unknown quantity at this point
Stock up on colored hair spray NOW. You'll forget the day before your first event.
NC GEARS = Newaygo County Geeks Engineering Awesome Robotics Solutions
2009: 5 Events, 60-25-2. 1 District Win, 3 Finalists
2010: 4 Events, 51-13-6. 1 District Win, 1 Regional Win, 1 Finalist
2011: 4 Events, 58-18-4. 2 District Wins
2012: 4 Events, 46-25-0. 1 District Win, 1 Finalist
Total: 17 Events, 215-81-12. 308 matches in 4 years
Scouting it all: Priceless
  #43   Spotlight this post!
Unread 28-02-2012, 16:48
Sean Raia's Avatar
Sean Raia Sean Raia is offline
Curious spectator & alumn
Sean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond repute
I learned several things...
- It IS possible to shave 8 pounds off of a robot without losing functionality.
- Jaguars wired under CAN communication can cause major headaches.
- Position mode is not fun to program.
- 4 traction wheels in a wide configuration will not turn on carpet.
- Always remember to "Set project as main" in Netbeans.
  #44   Spotlight this post!
Unread 28-02-2012, 19:45
Gray Adams's Avatar
Gray Adams Gray Adams is offline
Gray Adams is a splendid one to beholdGray Adams is a splendid one to beholdGray Adams is a splendid one to beholdGray Adams is a splendid one to beholdGray Adams is a splendid one to beholdGray Adams is a splendid one to beholdGray Adams is a splendid one to behold
Or use bleach and permanent dye
