Go to Post Everyone is wrong! - Chris is me [more]
Unread 22-02-2012, 16:42
Mk.32's Avatar
Mk.32 Mk.32 is offline
AKA: Mark
FRC #2485 (W.A.R. Lords)
Mk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud of
0673 Pinion pressfit...
So we were lucky enough to get some FP 0673 and some pinions for them to interface them with an AM Planetary Gearbox. However when we tried to pressfit them on they were really tight and we ended up bending a shaft of a motor....
For these are we supposed to heat them up or is there something we are missing?
Engineering mentor: Team 2485: WARLords 2013-
Team President: Team 3647 2010-2013
Unread 22-02-2012, 16:47
Jared Russell's Avatar
Taking a year (mostly) off
Re: 0673 Pinion pressfit...
We had this happen recently as well. Our older sun gears press right on; I wonder if the bore is ever so slightly too small on this batch.
Unread 22-02-2012, 16:49
Mk.32's Avatar
AKA: Mark
The ones we are using were just ordered.
Would order new gears now help? This is part of our withholding.
Unread 22-02-2012, 16:54
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
We had a CIM-sim pinion pressed halfway onto the shaft when it just stopped moving as it reached the knurled part of the shaft. Since I didn't want to bend the shaft on our precious 0673's, we pulled the gear off and lightly sanded some of the knurling off of the shaft. After that, pressing the pinion on went smoothly.
Unread 22-02-2012, 20:09
Grim Tuesday's Avatar
AKA: Simon Bohn
FRC #0639 (Code Red)
We had precisely the opposite problem: We had to get a 19 tooth gear off of one of our FP's, and in the process managed to pull the shaft out. We then let the team have their wrath upon the motor with the arbor press. We fixed it up good.
Unread 22-02-2012, 21:25
You do realize you've probably just brought tears to the eyes of a large number of people who couldn't get their hands on any 0673's?
Unread 22-02-2012, 22:00
wireties's Avatar
wireties wireties is offline
Principal Engineer
AKA: Keith Buchanan
Include 1296 on that long list!
Unread 22-02-2012, 22:02
Mk.32's Avatar
AKA: Mark
Why I am being wary about how to get the pinon's on....
Unread 22-02-2012, 22:59
wireties's Avatar
Principal Engineer
AKA: Keith Buchanan
A good arbor press, right-sized tooling, good alignment and a deft touch are required. We took pinion gears (as delivered in 2011 KOP) off 2 673s and replaced them with something else (since we thought we going to be able to order them sans gears and had already built a matching transmission).
Unread 23-02-2012, 23:55
AKA: Simon Bohn
Just so the sad people don't get too sad, this was a 9013, not a 0673. We'll be bringing all of our 1 0673's to competition to give to whomever asks.
Unread 24-02-2012, 01:34
wireties's Avatar
Principal Engineer
AKA: Keith Buchanan
Our team will pay your team for it!
Unread 24-02-2012, 02:31
tzjin tzjin is offline
AKA: Tony Jin
FRC #0192 (Gunn Robotics Team)
tzjin has a spectacular aura abouttzjin has a spectacular aura abouttzjin has a spectacular aura about
For those pressing gears on or off, make sure you only have forces acting on the gear and the shaft. So when you want to take a gear off, use a piece of steel with a slot and slip the shaft into it. Then press down on the shaft, so the motor itself takes no load.
If you have trouble pressing gears on, pop the gear into a lathe with soft jaws or a correct-sized collet and run a 1/8" bit through a few times. Make sure the gear is spinning true!
This worked for our aluminum inserts, but if the steel gear is still resisting, follow Kevin's suggestion and sand the knurls down a tad.
Do be kind to the most sought after motors in FRC right now. Best of luck!
With a smile,
Tony
