Go to Post Is that severed hand legal? I think it's a COTS assembly from previous years. - Taylor [more]
Unread 22-02-2012, 23:50
flameout flameout is offline
AKA Ryan Van Why
FRC #0957 (SWARM)
flameout is a name known to allflameout is a name known to allflameout is a name known to allflameout is a name known to allflameout is a name known to allflameout is a name known to all
Encoder ticks/revolution change?
We're running a mix of old and new encoders on our bot this year. I recently noticed that two of our encoders were reading significantly lower than the other two, but were reliable (and matched with each other), suggesting that it's not a failure.
Did kit encoders ever had a ticks/revolution value not equal to 360? I didn't have the opportunity to check counts/rev for each wheel before bagging... I don't know if I'll have time at regionals to verify, but I want to be ready to re-tune our drivetrain code if this is the case (and come prepared with the correct ticks/rev count per wheel).
Thank you.
Unread 22-02-2012, 23:56
Re: Encoder ticks/revolution change?
Yes. 250. 2009 KoP
Unread 22-02-2012, 23:57
andreboos andreboos is offline
FRC #3021 (The Agency)
andreboos is a jewel in the roughandreboos is a jewel in the roughandreboos is a jewel in the roughandreboos is a jewel in the rough
In the past (2010 or before), US Digital supplied 250 CPR encoders, because we had some lying around last year that were 250 CPR. Last years', and those offered in FIRST Choice this year, are 360 CPR. I believe CPR is solely a property of the hub disks, so you should be able to swap out the disks without having to unmount your encoder.
apalrd's Avatar
apalrd apalrd is offline
More Torque!
VRC #3333
The 2009 kit had 250 count/rev encoders. Later kits had 360 count/rev encoders.
AndyMark sells 250 count/rev encoders.
Kettering Motorsports
Unread 22-02-2012, 23:58
We have used E4P encoders with 250 and 360 counts per revolution. I believe both types were provided along with AndyMark gearboxes in the Kit of Parts in various years, but I don't have definitive documentation to that effect.
Unread 23-02-2012, 00:26
slijin's Avatar
slijin slijin is offline
Pockets
AKA: Samuel Lijin
FRC #0694 (StuyPulse)
2009 KoP
Originally Posted by 2009 KoP
OEM Miniature Optical Kit Encoder
E4P-250-250-D-D-D-B
250 CPR, 1/4” bore
2010 KoP and the 2011 KoP
Originally Posted by 2010 KoP and 2011 KoP
Encoder - Codewheel
E4P-360-250-S4149
360 CPR
2010-12 CT Chairman's
2011 Galileo 5th seed
2010 NY Regional Winners
Unread 23-02-2012, 00:32
AKA Ryan Van Why
FRC #0957 (SWARM)
Thank you for all the help. I'll have the fix (adjusted drivetrain parameters and tuning constants) prepared for regionals.
