Go to Post Teams that are consistently designing and end up with weight problems need to look at their design process and make corrections in "Weight Management". - Mike Martus [more]
Unread 22-02-2012, 00:05
farmersvilleRob's Avatar
farmersvilleRob farmersvilleRob is offline
FRC #4084
farmersvilleRob is infamous around these parts
Don't feel down!
To all the fellow teams that may no have finished, this is to you! Even as a rookie, our team understands that this competition is truly a time crunch and always will does and can leave any team needing code, materials, fabricated parts, sleep. But that's no reason to feel down! With the weight rules as they are and the COTS items being unlimited coupled with a month of time to develop what is needed, any team, given the same work ethic they have given during the build season can and should create a robot capable of being a top seeder!
Get back into your CAD, into your language, into your ideas and create!
Unread 22-02-2012, 22:00
DonRotolo's Avatar
Back to humble
FRC #0832
Re: Don't feel down!
There is no shame in showing up at your first competition with only most of a robot. There was once a team that showed up with no robot - just a kit of parts. They thought you weren't supposed to build it until you showed up!
If you find yourself in a situation where your robot isn't completed, when you get to competition ASK FOR HELP. Virtually EVERY team will fall over themselves to help you get your robot working and inspected. Don't be shy.
Good luck!
Unread 22-02-2012, 22:08
Walter Deitzler's Avatar
Walter Deitzler Walter Deitzler is offline
UAH Class of 2019
FRC #3397 (Robolions)
Walter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond repute
Even us, a 3 year veteran team, is still working on building extra parts for our robot. As farmsvilleRob is saying, keep working and do not feel down due to an imcomplete bot.
(Hanging out with my buddies at 610)
Robotics, it's not just a club, it's a career.
FLL Referee (2012-Present)
2014 Gateway Robotics Challenge winners (With 2481 and 1985)
2011 St. Louis Regional Winners (With 1985 and 3284)
2010 Highest Rookie Seed
I am the guy in the golden hat, say "Hi!" to me at WORLD CHAMPIONSHIPS!!!
Unread 22-02-2012, 23:07
Grim Tuesday's Avatar
AKA: Simon Bohn
FRC #0639 (Code Red)
We, an 11 year veteran team bagged a non-working shooter. Backstory: It broke last minute and we didn't have time to fix it before putting it in the bag. The entire robot is connected to it, so we can't take it out in withholding. We pulled off the offending gearboxes, and are making the necessary arrangements to have it fixed within 10 minutes of entering competition. You have between 8 and 11 hours on Thursday, use them well.
Unread 23-02-2012, 00:13
sgreco's Avatar
sgreco sgreco is offline
AKA: Steven Greco
FRC #2079
sgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond repute
As organized, and well prepared as some team look, it's perfectly normal to be working on robot parts after the build season is done. I've never been on a team that went to rest in the weeks leading up to the competition. There is absolutely no shame in continuous improvement (whether it be finishing an incomplete subsystem, or perfecting an already functioning one). It's an iterative process, and there's almost always something that can be improved.
Unread 23-02-2012, 01:09
Team 3705's Avatar
Team 3705 Team 3705 is offline
FRC #3705
Team 3705 is an unknown quantity at this point
I feel bad for not having our autonomous mode perfected, or having variable speed control for our shooters...
Our robot is done, but the code is never done...
Unread 23-02-2012, 01:18
its da PAT!!!'s Avatar
its da PAT!!! its da PAT!!! is offline
AKA: Pat Miller
FRC #0829 (Digital Goats)
its da PAT!!! has a spectacular aura aboutits da PAT!!! has a spectacular aura aboutits da PAT!!! has a spectacular aura about
Send a message via AIM to its da PAT!!!
A robot is NEVER done. I know and along with others on my team, that as soon as our robot was bagged there are thing we want to change and fix. But we are lucky enough to have a practice bot and we have a some what small team (13 FRC kids on a good night) this year.
2010 Boilermaker Rockwell Automation Innovation in Control Award
2007 St. Louis Regional Champion
Unread 23-02-2012, 11:14
Daniel_LaFleur's Avatar
Mad Scientist
AKA: Me
FRC #2040 (DERT)
Whos got a month? We've only got a week (were in a week 1 regional).
But your sentiments are correct. Now is not the time to be depressed at what doesn't work (or work well). Now is the time to get prepared and plan for what needs to be done.
___________________
- Tennyson, Ulysses
Unread 23-02-2012, 11:21
pyroslev's Avatar
pyroslev pyroslev is offline
VirginiaFIRST FTA
AKA: Jack of all trades, Master of few
no team (Forget not 616)
pyroslev is on a distinguished road
My first year, the team next to us in the pits either built their robot from scratch cause they did the same thing or their bot broke in transit. Heard of both happening before. Practice day might as well be the Wednesday after Bag and Tag. Even those veteran, super team types are tweaking and modifying.
"Complications arose, ensued...were overcome." "I'd trade 500 CNC machines for one good hearted student."
From December to April, since 2002, I forfeit my mental sanity for perfect insanity.
Unread 23-02-2012, 11:33
Taylor's Avatar
Taylor Taylor is offline
Professor of Thinkology, ThD
AKA: @taylorstem
FRC #3487 (Red Pride Robotics)
Among the feel-good stories of rookieness and redemption is this. - consider the source and realize the impact.
Hi!
Unread 23-02-2012, 11:37
Jon Stratis's Avatar
Jon Stratis Jon Stratis is online now
Mentor, LRI, MN RPC
FRC #2177 (The Robettes)
And even if you don't have anything you can do for your robot, there's still plenty you can do for your team!
We only have 1 thing on our "to-do" list when we get to Duluth - change out a plastic sprocket for a new steel one on our bridge manipulator. We had two of the plastic ones in our "sprocket bin", and they gave us the gear reduction we were looking for... then one split in half on us Sunday. We put the other one on for additional testing, and have a good steel one on order.
So, for the next two weeks until Duluth, we get to focus on some other items. We just got a new trailer, and we're working on having it wrapped with our team and sponsor info. We also have to figure out exactly how everything is going to fit in it without rolling around too much. We've finally gotten rid of our old pit banner holder (two cement buckets and some PVC pipe), and are working on an entirely new system - a 4-foot tall rolling cart that splits in half to provide storage in the corners (including mounts for wire spools, drawers for electrical equipment, vertical storage for long stock, and mounts for our bolt drawer set) and a place to mount the banner framework (old tent poles cut to a proper length). Hopefully we'll have it completely finished and painted before Duluth... then we can post pictures!
Our students are also working on setting up our scouting database and preparing for the Chairman's presentation. Drivers are coming in and practicing with last year's robot (at least they can chase balls around and balance).
And if nothing else... remember, this is the time of year where you can get excited and pumped up for competition!
PS. And if you were wondering... this might be the shortest "to-do" list we've ever gone to competition with! It helps that we set an internal target date of finishing construction of two weeks ago... even though we were a week late delivering it to Programming, we still had plenty of time to fix everything that wasn't working right over the weekend!
Unread 23-02-2012, 13:39
PayneTrain's Avatar
PayneTrain PayneTrain is offline
Q&A Dartboard Detractor
AKA: Lizard King
FRC #0422 (The Meme Tech Pneumatic Devices)
Team Role: Mascot
PayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond repute
I can tell you that FRC 422, for the first time in years, has a short list of fixes and attachments that need to be addressed before we take our robot to the inspection line in the early Thursday morning (not at night when they are trying to kick us out!). I'm excited to hand off the robot for the programmers to go over in practice rounds and go scout for teams that need any help. A few members of ours had the opportunity to do this last year at VCU--I remember helping with a team's deployment system that could run our 2-3 second minibots to ensure their matches could be won... even the quarterfinals where they beat us.
Rookies, DON'T FREAK OUT when you get there on Thursday. Teams of every color will be in your pit to help you. It's cool seeing three or four teams in a pit working on one robot together. It is so important every robot makes it to every match possible. Not only may your team be matched with a rookie that can only help you, but wouldn't you want other teams to help you when needed?
Unread 23-02-2012, 16:15
RoboMom RoboMom is offline
people expediter on Team Kluge
AKA: Jenny Beatty, no relation
no team (they are all my teams)
RoboMom has a reputation beyond reputeRoboMom has a reputation beyond reputeRoboMom has a reputation beyond reputeRoboMom has a reputation beyond reputeRoboMom has a reputation beyond reputeRoboMom has a reputation beyond reputeRoboMom has a reputation beyond reputeRoboMom has a reputation beyond reputeRoboMom has a reputation beyond reputeRoboMom has a reputation beyond reputeRoboMom has a reputation beyond repute
One of my annual favorites: http://www.chiefdelphi.com/forums/sh...t=dear+rookies
Co-Founder of NEMO (Non-Engineering Mentor Organization) www.firstnemo.org
Volunteer Director, STEMaction, Inc. www.stemaction.org
FIRST Senior Mentor: Nov. 2004 to June 2009: "Experience is that marvelous thing that enables you to recognize a mistake when you make it again"
This is How I Work: http://www.chiefdelphi.com/media/papers/2862
