Go to Post Volunteer...it will make you see a totally different side of FIRST. - Collin Fultz [more]
  #106   Spotlight this post!
Unread 23-02-2012, 02:56
Koko Ed's Avatar
Koko Ed Koko Ed is online now
Serial Volunteer
AKA: Ed Patterson
FRC #0191 (X-Cats)
Re: How much does your robot weigh?
116 pounds (most likely 118 when the signage is added at FLR).
  #107   Spotlight this post!
Unread 23-02-2012, 03:02
ttakashima's Avatar
ttakashima ttakashima is offline
T^2
AKA: Travis
FRC #2504 (The Crusaders)
ttakashima has a spectacular aura aboutttakashima has a spectacular aura about
We are at 122.5 lbs. We kept the shooter back, it Currently weighs 21lbs which in my opinion is very heavy. We have many holes to drill! We also still need to add our 2lb side plates at the comp with our sponsor logos!
Travis Takashima
Team Leader: Team 4270 - 2016-beyond
Mentor and Team Leader: Team 2504 - 2009-2016
Team 2504 Alum 09'
Attending
-FIRST Hawaii Regional
-FIRST San Francisco Regional
  #108   Spotlight this post!
Unread 23-02-2012, 03:08
ThirteenOfTwo's Avatar
ThirteenOfTwo ThirteenOfTwo is offline
College...
FRC #2438 (`Iobotics)
ThirteenOfTwo is a name known to allThirteenOfTwo is a name known to allThirteenOfTwo is a name known to allThirteenOfTwo is a name known to allThirteenOfTwo is a name known to allThirteenOfTwo is a name known to all
103 when we weighed without the wiring (but with electronics like CRIO/radio/jags), 108 when we put expected wiring materials on the scale too. Sixteen-pound withheld intake and eleven-pound withheld scoring mechanism leave about 80 lbs in the bag right now. At least eight of the withheld pounds come from COTS gearboxes and motors which will be brought to competition not as a part of the weight allowance.
  #109   Spotlight this post!
Unread 23-02-2012, 10:23
Cal578 Cal578 is offline
Passionate FIRST-er, CD donor
AKA: Gerry
FRC #0578 (Red Raider Robotics)
Cal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant future
We were at 119 lb with a couple days to go. Since the scale didn't seem to be quite accurate, and we can't be 100% sure that our manual calibration is perfect, being that close to the 120 lb limit made us a little nervous. Even if we believed our scale was perfect, it may not be the same as the one used by inspectors at competition, and we can't argue with their scale. So, we worked on a few things to give us some safety margin.
Many people talk about the "swiss cheese diet". Here are some points to consider:
  1. Drilling holes shouldn't be your first option. We changed to a lighter sprocket, and made a lighter mount for the camera. These were engineering improvements, in addition to saving weight.
  2. It takes a lot of holes in plastic to make any difference in weight, and that often compromises strength before much weight is shed. Target metal, especially thick items, first.
  3. You can remove weight from any part of the main robot to get under the limit, but the location of the removed weight can impact performance. Removing weight up high makes your robot more stable and easier to balance. Removing weight down low can make things worse.
  4. If you have decoration like lights, they count against the weight limit. We have some cool lights that everyone likes, but we had to make the decision that if we're overweight at competition, lights are the first thing to remove (I really hope we don't have to, they look too good). You might be tempted to remove panels that display sponsors, but remember that [R04] requires displaying school and sponsors during competition (plus, it's just right).
Good luck, everyone!
Cal
R3: Red Raider Robotics (FRC Team 578)
Fairport, NY, USA
www.FairportRobotics.org
2016 Finger Lakes Regional: Semifinalist on Alliance 7 (1128, 2010, 578)
2016 NYC Regional: Finalist on Alliance 3 (3419, 578, 3017), 4th seed team, Team Spirit Award
2015 Finger Lakes Regional: 8-3-0 in qualification, 7th seed, Quarterfinalist
2014 NY Tech Valley Regional: 8-4-0 in qualification, 13th seed, Semifinalist
2013 Finger Lakes Regional: 4-5-0 in qualification, 26th seed, Alliance 6, 1-2 in tournament
2012 Buckeye Regional: Gracious Professionalism Award, 7-3-0, 14th seed
2011 Finger Lakes Regional: Engineering Inspiration Award
  #110   Spotlight this post!
Unread 23-02-2012, 11:40
artdutra04's Avatar
VEX Robotics Engineer
FRC #0148 (Robowranglers)
Originally Posted by Cal578 View Post
[*]It takes a lot of holes in plastic to make any difference in weight, and that often compromises strength before much weight is shed. Target metal, especially thick items, first.
Don't be so quick to immediately discredit lightening plastic components; if the plastic part is large enough, the weight savings become valuable. If you have sheets of Lexan/polycarbonate on your robot, these add up almost deceptively quick in the weight department.
For example, a 24"x36" sheet of 1/16" polycarbonate weighs in at just under 2.4 lbs; the same size panel from 1/8" polycarbonate weighs in at about 4.75 lbs (which is about the same weight as the older Thomas air compressor).
Be warned through: while it is possible to use large hole saws (2-3" diameter) in sheets of Lexan, it's not the easiest thing to do in the pits. It's much easier ahead of time to only use the thinnest possible Lexan.
Art Dutra IV
世上无难事,只怕有心人.
  #111   Spotlight this post!
Unread 23-02-2012, 12:02
AKA: Gerry
I'm not discrediting it; I'm actually agreeing with what you just said. It would take a very large piece of polycarbonate to make a good target for weight savings, and then you need to put lots of holes in it to make a difference. If you have large metal pieces on your robot (sprockets, plates, mounts), you can get more weight savings with fewer, or smaller, holes. I've seen several teams (including mine, four years ago) drill a bunch of holes, get reweighed, and find that they hardly made a difference.
Cal
Fairport, NY, USA
  #112   Spotlight this post!
Unread 23-02-2012, 12:10
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
We took about two pounds of Lexan off our shooter...we didn't cut holes in it, we just cut off the excess material that wasn't needed.
As usual, you have to keep weigh in mind all thru the design and build process. If you do this, you shouldn't have a weight problem. We have a really heavy steel chassis, but we're still underweight, because we were pretty careful to use mostly only light materials on the "upper" parts of the robot.
  #113   Spotlight this post!
Unread 23-02-2012, 12:36
Garret's Avatar
Garret Garret is offline
Standing on the Shoulders of Giants
AKA: Garret Smalley
FRC #0691 (Hart District Robotics)
Garret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond repute
Without the motherboard for controlling the camera our robot came in at 105 lbs. Very surprising for the amount of stuff on the robot this year.
7 Years of FRC
"You students are at the top of the mountain, at the pinnacle of success, and what is it that you do?
You become the future guides to help others climb the mountain."
  #114   Spotlight this post!
Unread 23-02-2012, 22:53
Ekcrbe's Avatar
Ekcrbe Ekcrbe is offline
MIssin' the MItten
AKA: Erik Boyle
FRC #4640 (Metallic Panthers)
Ekcrbe has a reputation beyond reputeEkcrbe has a reputation beyond reputeEkcrbe has a reputation beyond reputeEkcrbe has a reputation beyond reputeEkcrbe has a reputation beyond reputeEkcrbe has a reputation beyond reputeEkcrbe has a reputation beyond reputeEkcrbe has a reputation beyond reputeEkcrbe has a reputation beyond reputeEkcrbe has a reputation beyond reputeEkcrbe has a reputation beyond repute
Originally Posted by CalTran View Post
Well, 15ish lbs, give or take
The last battery I checked that we had was 12.55 lbs, but I haven't averaged any more.
Four years of FRC 68 Truck Town Thunder
2012 Championship Newton Division Finalists—Thanks 330 and 639 for the Full Court Press!
2013 Kettering University District Chairman's Award Winners!
2014 Great Lakes Bay Region District Winners—Thanks 288, 4819, and 5166! | 2014 Waterford District Chairman's Award Winners! | 2014 Michigan FRC State Championship Chairman's Award Winners—Congratulations 33 and 503!
2015 Center Line District Chairman's Award Winners! | 2015 Lansing District Winners—Thanks 314 and 1684! | 2015 FIRST in Michigan District Championship Chairman's Award Winners—Congratulations 503 and 2137!
  #115   Spotlight this post!
Unread 23-02-2012, 23:13
gracie.'s Avatar
gracie. gracie. is offline
forgot the heat shrink...
FRC #2399 (The Fighting Unicorns)
gracie. is an unknown quantity at this point
Our final weight before bag & tag was 111 lbs. With the extra bumper and battery weight to lower our center of gravity, we're not too worried to be under the weight limit. If you're over, the universal advice is to start drilling holes. We've done it in the past, and I'm sure we'll do it again. Start with lightweight stuff in the first place, and if that fails, bring large drill bits.
2399: The Fighting Unicorns! - Alumna, team sister | Dean's List Finalist 2013
Anyone need a mentor in west LA?
  #116   Spotlight this post!
Unread 24-02-2012, 08:04
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
FRC #0095 (The Grasshoppers)
FWIW 95's rule of thumb, from the old-school days when we weighed robots with batteries, was 13lbs/battery with the typical-length 6awg leads. Some batteries could be up to 2lbs less than this if they were older.
I definitely agree that 15lbs is a a few lbs too generous for battery weight.
  #117   Spotlight this post!
Unread 24-02-2012, 09:51
kendra21093's Avatar
kendra21093 kendra21093 is offline
Drive Train Leader
AKA: Kendra
FRC #1719 (Rex)
Team Role: Student
kendra21093 is on a distinguished road
Send a message via AIM to kendra21093
121.2 LBS...WHYYYY??????? D:
--2010 Washington DC regional winners
--2010 Chesapeake Engineering Insperation Award
--2011 Chesapeake Spirit Award
--2011 Washington spirit award
Drive train leader
Scouting leader
1719 Umbrellacorp!
-Business manager =D
Chesapeake Regional
--Imagery Award
Washington
--4th seed
--made a team cry of happiness
  #118   Spotlight this post!
Unread 25-02-2012, 19:52
reymac's Avatar
reymac reymac is offline
FRC #0073 (Visioneers)
reymac is an unknown quantity at this point
We are at 105 pounds. We may consider adding weight to our robot depending on its performance in practice rounds
Corey Mack
Team Leader
Team 73: The Illumination
  #119   Spotlight this post!
Unread 25-02-2012, 19:56
stundt1's Avatar
stundt1 stundt1 is offline
Steve
FRC #4930 (Electric Mayhem)
stundt1 will become famous soon enoughstundt1 will become famous soon enough
We are around 120 pounds. Our scale wasnt calibrated correctly so we are really unsure but we should be around the 118-120 pound area.
If we are over our cathodes and side panels will the first to come off. Though if we are under weight we decided we might add a second camera to assist the operator and driver.
Steve
-Programming Mentor
- Team 578 Alumni
  #120   Spotlight this post!
Unread 25-02-2012, 20:10
peter1626 peter1626 is offline
FRC #1626 (Falcon Robotics)
peter1626 is an unknown quantity at this point
Three days before the deadline we finally got a hold of a scale... We were 139, after redesigning the entire front of the robot and the pickup system then we removed the protective 1/4" Plexiglass and replacing it with 1/8" with holes we were 118
2010 SBPLI Long Island-Regional-Imagery Award in honor of Jack Kamen
2011 New York City Regional-Industrial Design sponsored by General Motors
2011 SBPLI Long Island Regional-Regional Winner
