Go to Post Playing fields outdoors in the snow and the only field faults were when you ran out of gas!...ahh the old days - ExTexan [more]
Unread 23-02-2012, 08:00
Cal578 Cal578 is offline
Passionate FIRST-er, CD donor
AKA: Gerry
FRC #0578 (Red Raider Robotics)
Cal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant future
Re: Teams: Check Your Bumpers
It amazes me how much misunderstanding there is regarding fitting the team number on the bumper. It's easy to fit your number, even if you have a 4-digit number with no 1's, without compromising your design.
The minimum size of a bumper, as measured at the surface where the team number goes, is 11.25". It's not 8", as many people post. You have 8" of frame per [R27], plus 3/4 inches for the overlapped plywood (see figure 4-4 under [R28]), plus 2.5" for the noodle in the corner space per [R31]. Even if you use the vertical noodle as shown in the lower left of figure 4-6 and you don't want your team number to go into the rounded corner, you have 10.5 inches you can realistically work with.
There have been several posts (like this one and another) that offer fonts that make it easy to fit your team number within 10.5-11 inches. If you need to work on your bumpers at competition to pass inspection (my team has done that, but I hope not this year), then I hope this advice helps you get to a direct and fairly easy solution. Good luck!
Cal
R3: Red Raider Robotics (FRC Team 578)
Fairport, NY, USA
www.FairportRobotics.org
2016 Finger Lakes Regional: Semifinalist on Alliance 7 (1128, 2010, 578)
2016 NYC Regional: Finalist on Alliance 3 (3419, 578, 3017), 4th seed team, Team Spirit Award
2015 Finger Lakes Regional: 8-3-0 in qualification, 7th seed, Quarterfinalist
2014 NY Tech Valley Regional: 8-4-0 in qualification, 13th seed, Semifinalist
2013 Finger Lakes Regional: 4-5-0 in qualification, 26th seed, Alliance 6, 1-2 in tournament
2012 Buckeye Regional: Gracious Professionalism Award, 7-3-0, 14th seed
2011 Finger Lakes Regional: Engineering Inspiration Award
