Go to Post Robots will consume you if you are not careful. - JohnBoucher [more]
Go Back   Chief Delphi > Competition > Rules/Strategy > Scouting
Unread 05-01-2003, 13:48
Hailfire Hailfire is offline
AKA: Jason
Hailfire has a little shameless behaviour in the past
Send a message via AIM to Hailfire
FIRST Robotics Information Database
Just to inform you, Rob Bayer and I are working on a project that will make scouting easier. This will reduce the risk of losing those scouting papers by doing it electronically! I don't know when it will be done though.
Unread 05-01-2003, 14:49
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
There are numerous numerous threads about this recently in the scouting forum. Maybe your time would best be spent helping with these since it seems as if there is talk of a standard going around.
Cory
2001-2004: Team 100
2006-Present: Team 254
Unread 05-01-2003, 17:00
Brandon Martus's Avatar Unsung FIRST Hero
Brandon Martus Brandon Martus is offline
busy.
AKA: B. Slash Kamen
Brandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond repute
Send a message via ICQ to Brandon Martus Send a message via AIM to Brandon Martus Send a message via Yahoo to Brandon Martus
A standard of exporting the data to share with others, if desired. The program itself can be made however people want...
Brandon Martus
e-mail
Unread 05-01-2003, 18:20
Jeff Waegelin's Avatar
El Jefe de 148
AKA: Midwest Refugee
FRC #0148 (Robowranglers)
I would talk to Jack on my team. He and a few others (whom I do not recall) are working on a standard system for scouting data.
EDIT: You can find some of his info here: http://www.chiefdelphi.com/forums/sh...threadid=15885
Jeff Waegelin
Unread 10-01-2003, 21:59
AKA: Jason
Well, maybe if we combine our ideas, we can make one big database that works properly. Here is the following of what the main page looks like:
Unread 10-01-2003, 22:14
Jack's Avatar
Jack Jack is offline
FIRST Scouting Network
AKA: Andrew Schenk
FRC #0201 (The FEDS)
Jack is a jewel in the roughJack is a jewel in the roughJack is a jewel in the rough
Send a message via AIM to Jack
that looks good. I'm guessing that was made in either VB or VC++ (or something like that)
Once again, i'd check out the thread about the standard. It looks like you are off to a good start, but missing a few key things.
First, i'd hate to have to type in each team name. What i would do, is for the regionals you want to go to the list of all teams and what events i compliled in the General FIRST fourm. Insert that data into a table, and whenever a team_number is entered, have it pull the name and location.
Second, a few fields i personally don't think are needed. (# ppl on team) Also, i dought that most teams will know their actual ft/sec. Or they will just pull a value that sounds good to them, or just have a 'well w/o friction' thing
Then, you will also want standart answers to strenghts/weeknesses. Finally, i'd think that you would want to also gather data for each match.
Good Luck!
PS: I know, i'll try to get around to making an Access DB that will be complient with the 'standard' and allow uploading to www.feds201.com However, I need to write code for our 'Team Profiles' first, then the actual uploading/downloading/viewing code, then I need to learn access XP (which is more different from 95 in terms of SQL than i thought ) Another team member is making a Win CE app that teams will be able to use.
Team 201 - 2003 Great Lakes Semifinalists & 2003 Archimedes Division Finalists :|: Webmaster of www.feds201.com -> FBI Scouting
Winner of The 2003 ChiefDelphi Web Award for: User That Started The Most Non Chit Chat Threads
Winner of: 2003 FIRST Ventures with 5451.68 End Points
All about me: http://knehcsa.vze.com
**Check out the New FIRST Scouting Network**
Unread 10-01-2003, 22:20
AKA: Jason
The last time I edited it was probably 2 weeks ago and I used VC++ to make it. If you have any other suggestions, or additions, please post them. Thanks.
[IMG] code is Off
The Science Channel to broadcast FIRST documentary Andy Baker General Forum 49 01-03-2004 14:03
Renaming the FIRST Robotics Competition patrickrd General Forum 23 21-03-2003 00:03
Curie Division Robots information... (not complete) archiver 2001 3 24-06-2002 03:13
We have to organize to win archiver 2001 18 24-06-2002 00:00
Robotics Program Director Needed at FIRST archiver 1999 0 23-06-2002 22:31
