Go to Post If people really want to see "better" refereeing, they should see what they can do to help FIRST make better. - petek [more]
Unread 23-02-2012, 14:46
Re: Buttons on Dashboard (please help)
The robot can't read the Dashboard directly, but the Dashboard can send data to the robot. You'll have to open a UDP (or TCP) socket on the robot, and send to that socket from the Dashboard program.
It might be easier to use the Cypress PsoC I/O that the Driver Station and WPIlib routines already support. You don't have to have a physical switch; the I/O tab on the Driver Station gives you access to an array of emulated on/off switches and analog values.
Unread 23-02-2012, 15:43
zaphodp.jensen zaphodp.jensen is offline
Alumni and Mentor of 3130
AKA: Pierce Jensen
FRC #3130 (East Ridge Robotics Ominous Raptors (E.R.R.O.R.'s))
zaphodp.jensen is a jewel in the roughzaphodp.jensen is a jewel in the roughzaphodp.jensen is a jewel in the rough
If you do not have the cypress board working, you can always use the DIP switches that are under the IO tab on the driver station. Failing that, the throttle controls on each of the Attack 3 Joysticks make good autonomous selectors.
Unread 23-02-2012, 21:43
kentwedeking's Avatar
kentwedeking kentwedeking is offline
LabVIEW Zealot
FRC #0967
kentwedeking is on a distinguished road
So what I tell teams who've asked me this question is that if you use the DIO buttons on the Drivers station, they can be read in your code using "WPI_Driver StationGet Digital Input.vi."
If you take the array out of, cast it to a number using a "Boolean Array to Numeric" method, and you then run that number into a case structure. After that, its Binary math on the 8 bit number you'd end up with (010). If you use just two switches, 00 could be Option 1, 01 could be option 2, 10 could be option 3, and 11 could be option 4 ....
