Go to Post I'm sure an inflatable Dean Kamen action figure would be quite the sight around the home. lol - Elgin Clock [more]
Unread 23-02-2012, 18:58
Arcade drive method bug?
While looking at the RobotDrive.cpp file, I found what looks like a bug.
 * Arcade drive implements single stick driving.
 * Given a single Joystick, the class assumes the Y axis for the move value and the X axis
 * for the rotate value.
 * (Should add more information here regarding the way that arcade drive works.)
 * @param stick The joystick to use for Arcade single-stick driving. The Y-axis will be selected
 * for forwards/backwards and the X-axis will be selected for rotation rate.
 * @param squaredInputs If true, the sensitivity will be increased for small values
void RobotDrive::ArcadeDrive(GenericHID *stick, bool squaredInputs)
	// simply call the full-featured ArcadeDrive with the appropriate values
	ArcadeDrive(stick->GetY(), stick->GetX(), stick->GetTrigger());
It seems like the it should be
ArcadeDrive(stick->GetY(), stick->GetX(), squaredInputs);
This would match the java library. Am I missing anything?
Unread 23-02-2012, 21:09
mikets's Avatar
mikets mikets is offline
Software Engineer
FRC #0492 (Titan Robotics)
mikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of light
Re: Arcade drive method bug?
We also found a potential bug in ArcadeDrive. According to the code below, a positive rotateValue will make the robot turn left and negative will make it turn right. As far as I understand it, this is opposite to convention. I cross checked this with MecanumDrive_Cartesian where positive rotation will turn right and negative rotation will turn left (which agrees with convention). We found this by accident because we had to change our wheels from Mecanum to regular and all the sudden the robot turns the other way.
void RobotDrive::ArcadeDrive(float moveValue, float rotateValue, bool squaredInputs)
    if (moveValue > 0.0)
        if (rotateValue > 0.0)
            leftMotorOutput = moveValue - rotateValue;
            rightMotorOutput = max(moveValue, rotateValue);
        else
            leftMotorOutput = max(moveValue, -rotateValue);
            rightMotorOutput = moveValue + rotateValue;
    else
            leftMotorOutput = - max(-moveValue, rotateValue);
        else
            rightMotorOutput = - max(-moveValue, -rotateValue);
