Go to Post We don't build robots because it's easy, we do it because it's hard. Maybe we can work on giving new members a warmer and gentler welcome, because it's hard ;). - Winged Globe [more]
Unread 23-02-2012, 21:43
kentwedeking's Avatar
kentwedeking kentwedeking is offline
LabVIEW Zealot
FRC #0967
kentwedeking is on a distinguished road
Re: Buttons on Dashboard (please help)
So what I tell teams who've asked me this question is that if you use the DIO buttons on the Drivers station, they can be read in your code using "WPI_Driver StationGet Digital Input.vi."
If you take the array out of, cast it to a number using a "Boolean Array to Numeric" method, and you then run that number into a case structure. After that, its Binary math on the 8 bit number you'd end up with (010). If you use just two switches, 00 could be Option 1, 01 could be option 2, 10 could be option 3, and 11 could be option 4 ....
