Go to Post ...I tried to pump it up to the 47 inches. I stopped around 42 inches, than tried getting it through a 36" door. It got stuck, I proceeded to dropkick the thing in front of my team and a girl I had gone out with the previous Fri. It didn't move, I hit the floor. Ouch, my pride. - ChrisMcK2186 [more]
Unread 23-02-2012, 15:58
DavisC DavisC is offline
FRC #0539 (Titans)
DavisC is just really niceDavisC is just really niceDavisC is just really niceDavisC is just really nice
Time/timer function
Hello,
I am trying to include a time/timer function so that in a while loop I can keep track of how long it has been and still being able to run other code.
Also I would like to use it so that when I press a joystick button, the button is disable for say 1 second (so that it only registers 1 press and not registering from consistent pressing).
Could demonstrate how this function works?
Thanks,
Davis
FRC Team 539
Student Member: 2010 Breakaway - 2014 Aerial Assist
Mentor: 2015 Recycle Rush - present
Unread 23-02-2012, 16:02
Re: Time/timer function
The boolean expression
(button_is_pressed && button_was_not_pressed_in_previous_iteration)
does what you want.
It's true only in the iteration immediately after the button is pressed, and doesn't become true again until the button is released and pressed again.
Unread 23-02-2012, 17:11
FRC #0539 (Titans)
Thanks, that helps a lot!
Although I am still interested in learning how to use the time/timer feature.
I'm not sure if there is a specific function that can be used as a timer, or if I have to get the time off the cRIO (if possible) and do my own math.
Thanks!
FRC Team 539
Unread 23-02-2012, 17:16
mikets's Avatar
mikets mikets is offline
Software Engineer
FRC #0492 (Titan Robotics)
mikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of light
I use this macro.
#define GetMsecTime()           (GetFPGATime()/1000)
Unread 23-02-2012, 20:43
FRC #0539 (Titans)
So i just add the #define up with the includes and use the function wherever I need to and do the math from there.
Thanks.
FRC Team 539
Unread 23-02-2012, 20:54
mikets's Avatar
Software Engineer
Thanks.
That's right. Typically, it looks like this:
UINT32 startTime = GetMsecTime();
// Do something that you want to time.
printf("Elapsed time = %d msec\n", GetMsecTime() - startTime);
Unread 24-02-2012, 00:01
WizenedEE's Avatar
AKA: Adam
FRC #3238 (Cyborg Ferrets)
There is also a Timer class, but I don't like it much. Remember to call the Start() method if you use it.
