Go to Post OMG this topic again. Those who stir the pot should lick the spoon. - nuggetsyl [more]
Unread 20-02-2012, 21:01
Team 1824's Avatar
Team 1824 Team 1824 is offline
FRC #1824
Team 1824 is an unknown quantity at this point
Programming Autonomous
I have never really worked in autonomous but I was able to look up some of the basics online. I am using a simple flat sequence structure with timers in between the motor functions. for example I want the robot to drive forward for 5 seconds so I set the (Wait for) for 5000 milliseconds. When I deploy this to the cRio and run it the robot just jerks forward for about .6 seconds. I might be doing something wrong but if anyone can help that would be great.
Thanks,
Team 1824
Unread 20-02-2012, 21:11
Re: Programming Autonomous
The Safety Config sounds like it is enabled, so after 100ms the motors are disabled. The options are to disable the Config go to the RobotDrive palette and then the Advanced palette.
The other option is to change the autonomous VI to loop setting the speed every 50ms or so to the same value and exiting to move to the next sequence frame.
Greg McKaskle
Unread 21-02-2012, 06:47
Team 1824's Avatar
FRC #1824
I will try that when I get back to the robot.
Thanks for your quick reply,
Team 1824
Unread 24-02-2012, 16:22
Team 1824's Avatar
FRC #1824
Do you disable the safety config in begin.vi or autonomous.vi?
Unread 24-02-2012, 16:58
Since you just need this in Autonomous, keep it in there.
Disable the Safety Config before entering the sequence and re-enable it at the end of the sequence when you turn your drive motors off.
Unread 24-02-2012, 17:28
Team 1824's Avatar
FRC #1824
Alright, I will try that. Thank you.
