Go to Post Patents are an issue of law which, alas, has little to do with engineering or common sense. - Mike Betts [more]
Unread 05-01-2003, 18:00
Rob Colatutto's Avatar
Rob Colatutto Rob Colatutto is offline
Roboticsrob
FTC #10092 (Green.Griffins;)
Rob Colatutto is a splendid one to beholdRob Colatutto is a splendid one to beholdRob Colatutto is a splendid one to beholdRob Colatutto is a splendid one to beholdRob Colatutto is a splendid one to beholdRob Colatutto is a splendid one to beholdRob Colatutto is a splendid one to behold
The 1 bin confusion.....
one big thing my team discovered today....if you have 1 bin has your tallest stack, so all the bins are jsut randomly on the floor. and if there is one bin thats on its side, does it count as two? its clearly more than 1 unit of measure the stack height, but 1 container is technically not a stack. the rules say it will be release at a later date, the exact height of all the measurements on the stick woodie had at kickoff. so does any have any ideas? is it counting as a stack of 1....or of 2
Follow me on twitter @roboticsrob and my FTC team @griffins10092
Unread 05-01-2003, 18:03
FotoPlasma FotoPlasma is offline
FotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond repute
Send a message via AIM to FotoPlasma
According to everything I've seen (from the kickoff, Dave Lavery's demonstration), stacks are based on height, not bin amount.
A bin on its side, breaking the plane of the second level, counts as a stack two bins high, nested properly.
Additionally, one bin sitting bottom down on the floor, with another bin, short side down, sitting on top of it, is worth a stack three tall.
This is just what I believe to be viable in the rules, and game scoring methods. If I'm wrong, someone please correct me.
I played hacky sack with Andy Baker.
2001-2004: Team 258, The Sea Dawgs
2005: Team 1693, The Robo Lobos
Unread 05-01-2003, 18:53
MikeWherley's Avatar
MikeWherley MikeWherley is offline
#0116 (Epsilon Delta)
MikeWherley is on a distinguished road
Send a message via AIM to MikeWherley
Correct, but remember that if you have one bin one its side (counting as a multiplier of 2) and 4 other bins on the floor, then you total points is 6, not 8. Stack height (2) times your base bin amount: Total number of bins (5) minus stack height (2) times for a total of 3.
Hope this helps!
Unread 05-01-2003, 18:57
Mark Garver's Avatar
Mark Garver Mark Garver is offline
AKA: Garver
Mark Garver is a splendid one to beholdMark Garver is a splendid one to beholdMark Garver is a splendid one to beholdMark Garver is a splendid one to beholdMark Garver is a splendid one to beholdMark Garver is a splendid one to behold
Send a message via AIM to Mark Garver
What about only 1 bin?
If your alliance only has 1 bin total in the scoring position at the end of the match that bin counts as the multiplier and then your box score is 0.
Unread 05-01-2003, 19:00
Winged Globe Winged Globe is offline
Don't Panic
AKA: Xiao-Yu Fu
FRC #0481 (The Hitchhikers)
Winged Globe is a glorious beacon of lightWinged Globe is a glorious beacon of lightWinged Globe is a glorious beacon of lightWinged Globe is a glorious beacon of lightWinged Globe is a glorious beacon of lightWinged Globe is a glorious beacon of light
Send a message via AIM to Winged Globe
Hope this helps!
No......
SC8:
All containers in the tallest stack located in the scoring zone (the “multiplier stack”) are worth zero points. Containers in additional stacks of the same height will be
scored normally;
There's only 1 container in the stack. Hence, it would be a score of 8.
Unread 05-01-2003, 19:09
Roboticsrob
where did you get 8?? ok, say there is 7 boxes, all just thrown about your scoring zone. so the tallest stack is 1, but now, say 6 of those 7 boxes are right side up, but one is on its side. so now that one counts as your tallest box, and does it count as 2 or 1 box? so is your score 6 or 12
Unread 05-01-2003, 19:12
AKA: Garver
It would...
The way I read the rules is it would be 12.
Unread 05-01-2003, 19:16
Actually, no:
Check out rule 7.6: "The total base score is then multiplied by the height in
whole Stack Height Units (SHU) of the multiplier stack. A whole Stack Height Unit (15-1/4 inches)
is the height of an individual container as it sits flat on its bottom."
The key here is the value of Stack Height Units, regardless of the number of bins actually used. So, if 1 box created a SHU of 2, then 2 (not 1) is subtracted from the total number of bins to calculate your base score.
Unread 05-01-2003, 19:18
Stack Height Units (SHU) = 2 (The 1 of 7 boxes on its side)
Base Score = 5 (7 total minus SHU of 2)
Total Score = 2 * 5 = 10
Unread 05-01-2003, 19:24
Don't Panic
AKA: Xiao-Yu Fu
7.6
"All containers within the alliance’s scoring zone will be worth one point each EXCEPT the containers in the tallest stack."
and
"Containers in the multiplier stack are worth zero points each."
The multiplier does depend on height.
Base score does not. There, it's just how many physical bins are not in the tallest stack.
And the answer is 12.
Unread 05-01-2003, 19:31
Joe Matt's Avatar
Joe Matt Joe Matt is offline
Wake Up Get Up Get Out There
Joe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond repute
From what I hear, if it is one bin, then it only counts as ONE. NOT two, NOT three.
Unread 05-01-2003, 19:45
Roboticsrob
we assumed as well that if its one bin, regardless or orientation, that it counts as one, since one is technically not a stack anyway. so the score would be 6
Unread 05-01-2003, 20:08
One bin can give you a stack height of 2 since it will be above the 2-line, as measure by an "Official
Stack Height Measuring device," as stated in rule 7.6.
Unread 05-01-2003, 20:10
AKA: Garver
Disagree...
I beleive that a stack can be considered one. What if there is only one box in the scoring position. This is the stack multiplier correct? Then it would be considered a stack and count for zero points.
Unread 05-01-2003, 20:13
Re: Disagree...
A 1-bin stack can have a multiplier of either 1 or 2, depending on its orientation, as measured by the pole that Woodie demonstrated during the kickoff.
Tossing a bin at the ramp in HP Cory Rules/Strategy 12 04-06-2003 12:13
Illegal human player bin placement Mike Soukup General Forum 29 01-04-2003 21:17
Where to find a bin? Krystal314 3D Animation and Competition 3 18-01-2003 12:56
Bin Stacks Brad Swindell Rules/Strategy 7 05-01-2003 19:47
Additional Hardware list confusion archiver 2001 4 23-06-2002 22:29
