Go to Post PS. Never write to a forum when your cat is trying to lie on the keyboard while you type. It made my bad spelling worse. - Seth Mallory [more]
Unread 05-01-2003, 14:42
rmadsen55 rmadsen55 is offline
#0213 (Dirty Birds)
rmadsen55 is an unknown quantity at this point
Send a message via AIM to rmadsen55
anish,
you are correct that you do not need calculus to create the equation of the score (which is a quadratic) but it is necessary to optimize it. in order to find the maximum score for any given number of bins you need to take the derivative of the scoring formula and find the relative maximum.
Perhaps there is another way to optimize it but I am not aware of any.
-Robin
Unread 05-01-2003, 15:45
Caleb Fulton's Avatar
Caleb Fulton Caleb Fulton is offline
Z = Z^2 + C ......WHEEEE!
AKA: aXvXiA
#0461 (West Side Boiler Invasion)
Caleb Fulton has a spectacular aura aboutCaleb Fulton has a spectacular aura aboutCaleb Fulton has a spectacular aura about
Send a message via AIM to Caleb Fulton
Hmmm
You don't need calculus because you are dealing with integer values only. This is more of a pattern/series problem to me.
The quadratic formula merely approximates the maximum score based upon how many boxes you have to work with, but even this is irrelevant.
The maximum score will ALWAYS occur when N_boxes/2 are in the stack if N_boxes is even and it will ALWAYS occur when (N_boxes-1)/2 are in the stack if N_boxes is odd. The reason I say N_boxes-1 is illustrated by this example:
Say you have seven boxes to work with. It is easier to have a stack of three than a stack of four based upon the laws of physics. You will get the same score if you have three stacked and four on the ground or vice versa, but it is probably easier to "maintain" a stack of three.
Unread 05-01-2003, 15:56
rbayer rbayer is offline
Blood, Sweat, and Code
no team (Teamless Orphan)
You do need calc to maximize this function. Yes, you can do it in your head, and you can do it by looking at a graph, but both of these use the techniques of calc without touching any derivatives. Alternatively, you can complete the square on the quadratic and look at its vertex.
Unread 05-01-2003, 16:55
Ashley Weed Ashley Weed is offline
Rookie Year: 1995
Ashley Weed has a reputation beyond reputeAshley Weed has a reputation beyond reputeAshley Weed has a reputation beyond reputeAshley Weed has a reputation beyond reputeAshley Weed has a reputation beyond reputeAshley Weed has a reputation beyond reputeAshley Weed has a reputation beyond reputeAshley Weed has a reputation beyond reputeAshley Weed has a reputation beyond reputeAshley Weed has a reputation beyond reputeAshley Weed has a reputation beyond repute
Unhappy Please Help
Just crunching numbers and being completely exhausted at the same time.... I was wondering if someone could verify the equation.....
if a = (-1) x = (# of boxes in highest stack) b = (# of boxes in your scoring zone for one point) c = (points from alliances robots)
that being.... if you had a stack of 8 bins... with 10 others in your scoring zone....and both of the robots on the platform
(-1)(8)^2 + (10)(8) + 50 =
(-64) + (80) + 50 =
66 pts.
This is without opposing alliance points if you win...........
Is this correct???? If not, would someone please clarify my mistake.
Unread 05-01-2003, 16:59
Instead of having b as the number of boxes in your scoring zone worth one point, have b represent the total number of boxes then your equation works just fine. Your score for this scenario should be:
8*10+50=130
Unread 05-01-2003, 17:08
Rookie Year: 1995
then what happens to the a = (-1) and (x^2)..... from the equation?
Unread 05-01-2003, 17:51
BandChick's Avatar
BandChick BandChick is offline
Superpower: Knows Everyone
AKA: Sara Reffler
FRC #1089 (Team Mercury)
BandChick has a reputation beyond reputeBandChick has a reputation beyond reputeBandChick has a reputation beyond reputeBandChick has a reputation beyond reputeBandChick has a reputation beyond reputeBandChick has a reputation beyond reputeBandChick has a reputation beyond reputeBandChick has a reputation beyond reputeBandChick has a reputation beyond reputeBandChick has a reputation beyond reputeBandChick has a reputation beyond repute
Send a message via AIM to BandChick
Re: possible scores
Originally posted by Caroline
If there is a fixed number of boxes in your scoring zone, if you plot the possible scores using the number stacked as the X component and the total score as the y component, it forms a parabola.
It forms a parabola. In this situation, the equation is y=(-x)(x-8)
If you look at that above you will realize, she just explained the equation. that is the same as y=ax^2 + bx + c
2016 Championship userbars are here!
1089 Mentor & Alum | 2016 MAR Championship Finalists, Innovation in Control Award Winners
2015 Archimedes Champions | 2015 Einstein Semi-Finalists
2014 MAR Championship Finalists | 2014 Bridgewater District Finalists | 2013 Lenape District Finalists | 2011 NJ Regional Finalists
2014 & 2015 Excellence in Engineering Award | 2014 Xerox Creativity Award
2009, 2011, 2013 KCP&B Entrepreneurship Award Winners | 2012 Gracious Professionalism Award Winners | 2009 NJ Regional Chairman's Award Winners
"Success in life is a matter not so much of talent or opportunity as of concentration and perseverance." C.W. Wendte
Unread 05-01-2003, 18:44
Mark Garver's Avatar
Mark Garver Mark Garver is offline
AKA: Garver
Mark Garver is a splendid one to beholdMark Garver is a splendid one to beholdMark Garver is a splendid one to beholdMark Garver is a splendid one to beholdMark Garver is a splendid one to beholdMark Garver is a splendid one to behold
Send a message via AIM to Mark Garver
Well then assuming...
Well if you think of always having 45 boxes on your side and both of your robots on the top of the ramp,
x(45-x)+50
works well.
But if you assume the following terms,
a=highest stack
b=number of boxes
c=number of robots
1=your alliance (side or robot)
2=opponents alliance (side or robot)
These equations work
If: [a1(b1-a1)+c1] > [a2(b2-a2)+c2]
Then: [a1(b1-a1)+c1] + 2*[a2(b2-a2)+c2] = your winning score
If: [a1(b1-a1)+c1] < [a2(b2-a2)+c2]
Then: [a1(b1-a1)+c1] = your losing score
Sorry, maybe to many terms, haha.
Unread 05-01-2003, 19:05
Rookie Year: 1995
ok.. I think I was just reading way into the equation thing... the equation is to detemine the QP score if you win... and also used for QP if you loose..... you have to know how/where the bins are placed for each alliance to use the equation properly then???
Unread 05-01-2003, 20:05
AKA: Garver
Correct....
I was using the information from a previous post,
"no need for calculus.
Lets say you have all the bins in your zone and you have 2 robots on the platform.
lets let x equal stack height.
Now, scoring is the highest stack height * number of bins not in the stack. If you have all 45 bins, thats 45-x (the bins in the heighest stack). Additionaly, 50 for both robots on the platform.
x(45-x) + 50 = y
that expands to:
y = -x^2 + 45x + 50"
Using this you have to have all 45 bins. Using mine you can have any number of bins. Of course there is a down side, but its not hard to calculate it. The downside is having to count the boxes on both sides of the field. But if you change b2 to being 45-b1 then it becomes a little easier.
So assuming the same variables as I had before,
If: [a1(b1-a1)+c1] > [a2((45-b1)-a2)+c2]
Then: [a1(b1-a1)+c1] + 2*[a2((45-b1-a2)+c2] = your winning score
If: [a1(b1-a1)+c1] < [a2((45-b1)-a2)+c2]
This is good for both QP and EP scoring, if I am reading the rules correctly.
I am trying to get the EPs all done right now too.
Unread 05-01-2003, 20:29
AKA: Garver
The rest of the EP scoring...
This may get confusing, but it does work.
For QP
If: [a1(b1-a1)+c1] = [a2((45-b1)-a2)+c2]
Then: [a1(b1-a1)+c1] + [a2((45-b1)-a2)+c2] = Both alliance's score
For EP
If: [a1(b1-a1)+c1] = [a2((45-b1)-a2)+c2] For Match one and Match two then addition matches are played until [a1(b1-a1)+c1] > [a2((45-b1)-a2)+c2] or [a1(b1-a1)+c1] < [a2((45-b1)-a2)+c2].
Also for EP (1 in front of a term means match 1 and 2 in front of a term means match 2)
If: [1a1(1b1-1a1)+1c1] > [1a2((45-1b1)-1a2)+1c2]
Then: [1a1(1b1-1a1)+1c1] + 2*[1a2((45-1b1-1a2)+1c2] = your winning score for match 1
If: [1a1(1b1-1a1)+1c1] < [1a2((45-1b1)-1a2)+1c2]
Then: [1a1(1b1-1a1)+1c1] = your losing score for match 1
This is true for match two as well.
So,
If: [1a1(1b1-1a1)+1c1] > [1a2((45-1b1)-1a2)+1c2] and [2a1(2b1-2a1)+2c1] > [2a2((45-2b1)-2a2)+2c2]
Then: You advance
If: [1a1(1b1-1a1)+1c1] < [1a2((45-1b1)-1a2)+1c2] and [2a1(2b1-2a1)+2c1] < [2a2((45-2b1)-2a2)+2c2
Then: You drop out
If: [1a1(1b1-1a1)+1c1] > [1a2((45-1b1)-1a2)+1c2] and [1a1(1b1-1a1)+1c1] < [1a2((45-1b1)-1a2)+1c2] and [1a1(1b1-1a1)+1c1] + 2*[1a2((45-1b1-1a2)+1c2] + [2a1(2b1-2a1)+2c1] > [1a2(1b2-1a2)+1c2] + [2a2(2b2-2a2)+2c2] + 2*[2a2((45-2b2-2a2)+2c2]
Then: You advance
If: [1a1(1b1-1a1)+1c1] > [1a2((45-1b1)-1a2)+1c2] and [1a1(1b1-1a1)+1c1] < [1a2((45-1b1)-1a2)+1c2] and [1a1(1b1-1a1)+1c1] + 2*[1a2((45-1b1-1a2)+1c2] + [2a1(2b1-2a1)+2c1] < [1a2(1b2-1a2)+1c2] + [2a2(2b2-2a2)+2c2] + 2*[2a2((45-2b2-2a2)+2c2]
Then: You drop out
If: [1a1(1b1-1a1)+1c1] < [1a2((45-1b1)-1a2)+1c2] and [1a1(1b1-1a1)+1c1] > [1a2((45-1b1)-1a2)+1c2] and [1a1(1b1-1a1)+1c1] + [2a1(2b1-2a1)+2c1] + 2*[2a1((45-2b1-2a1)+2c1] > [1a2(1b2-1a2)+1c2] + 2*[1a2((45-1b2-1a2)+1c2] + [2a2(2b2-2a2)+2c2]
Then: You advance
If: [1a1(1b1-1a1)+1c1] < [1a2((45-1b1)-1a2)+1c2] and [1a1(1b1-1a1)+1c1] > [1a2((45-1b1)-1a2)+1c2] and [1a1(1b1-1a1)+1c1] + [2a1(2b1-2a1)+2c1] + 2*[2a1((45-2b1-2a1)+2c1] < [1a2(1b2-1a2)+1c2] + 2*[1a2((45-1b2-1a2)+1c2] + [2a2(2b2-2a2)+2c2]
Then: You drop out
Like I said, it should work, maybe I am incorrect some where will a variable tho.
O, I forgot to do the situation where if either one of the matches are tied. You can assume what happens then tho :
Unread 05-01-2003, 21:12
Alex Forest's Avatar
Alex Forest Alex Forest is offline
MadHatter
#0190 (Gompei and the H.E.R.D.)
Alex Forest is an unknown quantity at this point
Send a message via AIM to Alex Forest
Now, you are coming to my team to do this for me in the middle of the match, right??? *big grin*
Ahh...the wonderful and new experience of being a college mentor. Wow. its very disturbing to have people thinking that I know what I am doing....*shudder*
Unread 05-01-2003, 21:18
AKA: Garver
Plams work great for this!!! All you need is 5 simple numbers for most matches. That is if no one takes boxes out!!! So maybe 6 numbers is the easier and more fool proof way.
Working on a program for that now (even bigger grin)
Unread 05-01-2003, 21:21
AKA: Garver
Another way...
You could just count the boxes that have went outside the playing field and subtract them from the the 45, before you minus the b1. Well it will be all done on a computer so it won't be hard to add that in.
Unread 05-01-2003, 22:00
Johca_Gaorl's Avatar
Johca_Gaorl Johca_Gaorl is offline
Pwn3d
#0122 (NASA Knights)
Johca_Gaorl is an unknown quantity at this point
Send a message via AIM to Johca_Gaorl
Actually correction, if it's odd, it doesn't matter whether more are in the stack or on the ground:
i.e. 21 total
11 stack * 10 ground = 110
10 stack * 11 ground = 110
DOX
At VT! Guess I'm unofficially part of 401 now...
Physics of Fiction nwagers Technical Discussion 2 09-01-2003 12:46
Science fiction is becoming science fact Robby O Chit-Chat 0 17-05-2002 00:03
