Go to Post When we learn physics, we almost always "ignore friction". The real world never does... - Mike Betts [more]
Go Back   Chief Delphi > Technical > Kit & Additional Hardware
  #31   Spotlight this post!
Unread 24-02-2012, 01:44
Justin Stiltner's Avatar
Justin Stiltner Justin Stiltner is offline
The big guy
Justin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud of
Send a message via ICQ to Justin Stiltner Send a message via AIM to Justin Stiltner Send a message via MSN to Justin Stiltner Send a message via Yahoo to Justin Stiltner
Re: Lost Bag and Tag
Get your robot sealed up in whatever bag you have, you will have to fill out the non compliance form, and if the same procedure as last year is followed there will need to be signatures from the head inspector(s), head ref, and it seems like one other person. Just to alert you to the gravity of the situation, this could prevent your team from competing this year in any event.
I recall doing two of these forms last year for teams simply forgetting their lock up form, and it does take a while to track down everyone that needs to sign it and tell them the story, all the while your team will be sitting looking at your robot in the bag not allowed to open it or begin working on it until the forms have been completed.
Good Luck.
Justin Stiltner
Lead Robot Inspector, VCU Regional
Unmanned Systems Lab, Virginia Tech
KI4URQ
  #32   Spotlight this post!
Unread 24-02-2012, 07:29
Originally Posted by fox46 View Post
You are correct- However, I do remember a number of years back being very upset by a team that had built a clone robot after Stop Build day. They brought the clone with them as a giant replacement part! The inspectors had reportedly scrutinized each one and had determined that they were identical. The team used them in a tag-team setup when their shipped robot broke, the clone was brought in to take its place. I think they swapped the control system though.
fox,
I have not heard of this scenario but there is no way that a competition team (Head Ref, FTA, LRI) would allow them to tag team two robots. Most regionals would/should not even allow the second clone into the building. This competition is about one and only one robot built during the current build season. While you can build a second robot and use it for spares, (lot's of teams do this) you can't bring a complete second robot to compete.
  #33   Spotlight this post!
Unread 24-02-2012, 07:34
To jump way back in the thread Joe and Wetz,
The answer still is confusing. Why answer the question with a reference to fabricated items when the question is about upgrades?
  #34   Spotlight this post!
Unread 24-02-2012, 08:39
O-H
FRC #0048 (Delphi E.L.I.T.E.)
FIRST seems to have omitted the term glossary it usually includes in the Introduction section of the Game Manual that clearly defines capitalized terms such as "Fabricated Items" and "Mechanism". If they stuck it somewhere else, please point it out - I sure as heck couldn't locate it.
So all teams have to go by is the 2011 definitions. If FIRST didn't take it upon themselves to provide definitions for 2012, teams must presume that the definitions didn't change. At this point, if FIRST released the definitions and any were significantly different from the 2011 defines, I think you'd have pitchforks and torches lining up in Manchester.
Anyway:
MECHANISM, 2011 – a COTS or custom assembly of COMPONENTS that provide specific functionality on
the ROBOT. A MECHANISM can be disassembled (and then reassembled) into individual
COMPONENTS without damage to the parts
FABRICATED ITEM, 2011 – any COMPONENT or MECHANISM that has been altered, built, cast,
constructed, concocted, created, cut, heat treated, machined, manufactured, modified, painted,
produced, surface coated, or conjured partially or completely into the final form in which it will be
used on the ROBOT.
[R26, 2012 Manual] - Teams may bring a maximum of 30 lbs of Fabricated Items to each competition event to be used to repair and/or upgrade their Robot at the competition site. The Operator Console and any battery assemblies (see [R03]-A) are not applicable.
Shooters, bridge tenders, etc. are "custom assemblies of components that provide specific functionality on the robot". They are therefore MECHANISMS.
A MECHANISM, by definition, is a FABRICATED ITEM.
Conclusion: teams may bring a maximum of 30 lbs of FABRICATED ITEMS - including MECHANISMS - to each competition.
Also, just because a team may have had a shooter on their bot at some point in the build, they do not HAVE to put that shooter in the bag. The team has full control over the functionality they choose to put in the bag. They have a right to withhold a portion of that functionality, putting the balance in the bag. They work to improve the shooter mechanism after stop build, they bring it to the venue legally as part of the allowable 30 lbs., and they then UPGRADE their robot's functionality with the shooter once they remove the bot from the bag.
  #35   Spotlight this post!
Unread 24-02-2012, 11:37
Siri's Avatar
Siri Siri is offline
Dare greatly
AKA: 1640 coach 2010-2014
FRC #2641 (PCCR; Refs & RIs)
R22: "...Once a COTS item is modified in any way, it becomes a Fabricated Item [emphasis mine]." It's, oddly, the only place they defined Fabricated Item, but it seems like a reasonable definition. Bring in as many unmodified COTS parts as you like, and 30lbs of modified COTS parts (=Fabricated Items). i.e., There is no restriction on what these modified COTS parts can be upgrading or used for, so long as they total less than 30lbs. It's one of the GDC's "read the rules, there's no restriction beyond them" calls. I don't think it even requires the 2011 definitions, though it certainly works that way.
  #36   Spotlight this post!
Unread 24-02-2012, 12:07
fox46's Avatar
fox46 fox46 is offline
FRC #2013 (Cybergnomes)
fox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond repute
Never the less it did indeed happen and I confirmed it with a couple of my former teamates. If my memory serves me right, it was the second year of the GTR regional - 2002? - stack attack. I remember discussing it amongst ourselves and when we asked if they had entered two robots the team confirmed that the second was their practice robot which they brought as a backup. Their intention as was explained was to swap their modular control system if they were to experience a mechanical breakdown and then continue competing with the clone. One of my former team mates recalls them boasting about how they could swap the control system in under a minute.
Mentor, Team 2013 Cybergnomes 2010 - 2014, 2016
Mentor, Team 3756 RamFerno 2011 - 2013
Mentor, Team 854 Iron Bears 2005-2007
Founding member, Team 854 Iron Bears 2000-2005
Mech.Eng.+Mgt University of Ontario 2009
B.Ed OCT Trent University 2015
Professional Education and Product Knowledge Consultant - Toyota Canada Inc.
  #37   Spotlight this post!
Unread 24-02-2012, 14:41
Rules were much different in 2002 but it was still one robot only.
1.2.2 Basic Gameplay
Each team competes using one team-built robot.
or in 2003 the WildStang rule...
M5 At the time of robot inspection, you must present all mechanisms that you will use on the robot during the entire competition event. It is acceptable, however, for a robot to play matches with a subset of the mechanisms that were present during inspection. Only mechanisms that were present during the inspection may be added,removed or reconfigured between matches. If subsets of mechanisms are changed between matches, the robot must still meet all inspection criteria. Robots must satisfy Rule M6 at all times.
  #38   Spotlight this post!
Unread 24-02-2012, 14:52
fox46's Avatar
I think we are on different wavelenths on this one-
They did indeed only have one robot, but they brought an entire robot's worth of replacement parts assembled in one cohesive machine. When the mechanical mechanism on their machine broke, they removed the mechanical mechanism from the robot (which was the portion which excluded the control system) and installed an identical replacement part in the form of the entire mechanical mechanism to their control system. Basically, there was no definition of a replacement part- this could be a single piece, or an entire mechanism- in their case, they called the entire mechanical system a mechanism and brought an identical replacement part.
  #39   Spotlight this post!
Unread 24-02-2012, 18:54
DonRotolo's Avatar
Back to humble
FRC #0832
If their second robot weighed 30 lbs or less, they could do that this year too. Highly unlikely, but that was then and this is now.
Did timwinget ever contact FIRST or find a bag? I wonder.
Me, I'd have run off to Home Depot or Lowe's and got me a roll of clear polyethylene sheeting, wrapped the robot like a candy apple and tagged it shut at the top. Better than nothing.
  #40   Spotlight this post!
Unread 25-02-2012, 14:08
tomwinget tomwinget is offline
FRC #2367
tomwinget is an unknown quantity at this point
Here is the final verdict.
I contacted FIRST and they got back to me saying that any bag, FIRST or non FIRST works perfectly fine and wouldn't have made a difference as long as FIRST is contacted.
Secondly, we are still in the competition as long as we fill out the lock-up form and bring in the email giving us the permission to use a different bag.
Thanks for all the suggestions which ultimately led to us working our way out of the mess and especially to Mountain View High School Robotics (Spartan Robotics 971) who gave us one of their extra bags.
  #41   Spotlight this post!
Unread 25-02-2012, 14:34
Thanks for the follow up.
I'm sure some other team in similar straits will benefit from knowing how you handled this kind of situation.
  #42   Spotlight this post!
Unread 25-02-2012, 18:34
DominickC DominickC is offline
FRC #0023 (PNTA)
Rookie Year: 1620
DominickC is an unknown quantity at this point
Glad you got your issue resolved. Good luck competing!
