Go to Post All I wanted was a game hint.... :( - JohnBoucher [more]
Unread 24-02-2012, 20:54
da johnny boy da johnny boy is offline
FRC #4142 (Shorebots)
da johnny boy is an unknown quantity at this point
Re: Programming help
Here is another program that reduces the output of the joystick whenever the 2 button on the joystick is pressed. You could also program the button to toggle the motor speed instead of having to hold the button.
Unread 24-02-2012, 22:18
Back @ it again with the white vans
AKA: Brandon Liatys
FRC #2180 (Zero Gravity)
There is a difference between a less sensitive joystick and supplying less power to the motors. To make it less sensitive (I'm guessing maybe the problem could be its sending values to the motors when your not touching it or something) you could try something like this:
EDIT: Wow, I didn't read the first post full through. Oops. Well, now you know how to add a deadzone xD
Unread 25-02-2012, 09:41
Team 1824's Avatar
Team 1824 Team 1824 is offline
FRC #1824
Team 1824 is an unknown quantity at this point
Thank you for all of the replies. I understand how to do it now.
Team 1824
