Go to Post Maybe LabView needs to have a watchdog for goofy programmers... - johncap100 [more]
Unread 24-02-2012, 21:58
msimon785 msimon785 is offline
Fusing Function with Form
AKA: Mathew Simon
msimon785 has a brilliant futuremsimon785 has a brilliant futuremsimon785 has a brilliant futuremsimon785 has a brilliant futuremsimon785 has a brilliant futuremsimon785 has a brilliant futuremsimon785 has a brilliant futuremsimon785 has a brilliant futuremsimon785 has a brilliant futuremsimon785 has a brilliant futuremsimon785 has a brilliant future
MorTorq 1515: Robot and Website Unveils
Hey CD!
Team 1515 is ready to unveil both the 2012 robot and website. We are very proud of our work, and hope you all enjoy.
To start, I would like to introduce MetaBot World Piece.
The robot utilizes a dual stage conveyor system which allows for exactly 3 balls in each stage. The turreted dual-FP shooter shoots the ball approximately 6-8', but that is subject to change. We intend to substitute the 4" wheels for 6". Our bridge mechanism functions passively. Brought down by pneumatics, it serves as a wedge with which the drivetrain pushes down the bridge.
As always, our electronics are fully modular, such that all of the boards can be removed in the course of less than a minute. We utilize sliding rails in which the E-boards slide and clip in. All onboard wiring is run through industry standard WAGO mass connectors which allow for a single unplug to separate all of the actuators from the PDB.
Expect to see our famous touchscreen interface again, but with a new look and feel. As a result of the size constraints for the OI, we have rebuilt the Operator's Interface to allow for an entirely new touchscreen. Instead of running through an industrial PLC, we will be using a touch-capacitive display which runs a ruby application along side the FRC Driver's Station.
Additionally, 100% of the processing for our 2012 robot is now done offboard, on the classmate. This essentially makes the robot "dumb", such that it only runs the commands it is given.
Finally, our website crew put in many long and hard hours to revamp the BHRobotics Website.
Please take a look around. We made the decision to make the website entirely open source, so we encourage other teams to draw inspiration from what we have done.
Mathew Simon
CAD/Design
[2013-20xx]: 973 "Greybots"
[2011-2013]: 1515 "MorTorq"
[2008-2010]: 1836 "MilkenKnights"
Unread 24-02-2012, 22:00
AKA: Mathew Simon
Re: MorTorq 1515: Robot and Website Unveils
Website Screenshot:
Mathew Simon
CAD/Design
Unread 24-02-2012, 22:01
Matt, it was awesome seeing this robot come together through the season, especially when you had to overcome some machining hurdles.
Best of luck to you all this season.
Unread 24-02-2012, 22:02
AKA: Mathew Simon
Thanks, Akash!
Best of luck to the Atomic Dragons as well!
Mathew Simon
CAD/Design
Unread 25-02-2012, 00:38
rsisk's Avatar
rsisk rsisk is offline
The GURU Channel
AKA: Richard Sisk
FRC #2493 (Robokong)
Looking awesome! Can't wait to see you in LA, or maybe even before that!
The views expressed are mine and should not be construed to represent the views of anyone else.
Unread 25-02-2012, 01:36
FRC #1836 (MilkenKnights)
It was so awesome working closely with you guys this year. We can't wait to do it again next year. Also, the new website is awesome!
Unread 25-02-2012, 20:43
AKA: Mathew Simon
Thanks, Michael. It was a pleasure on my part and we'd love to do it again next year.
And for those who care, I forgot to mention drivetrain specs.
Almost 19 fps 6WD center-dropped with 8" Plaction wheels (roughtop)
Mathew Simon
CAD/Design
Unread 26-02-2012, 12:37
otherguy's Avatar
otherguy otherguy is offline
sparkE
AKA: James
Would you mind sharing some more detailed shots of your electronics/wiring setup? It sounds interesting.
http://team2168.org
Unread 26-02-2012, 12:40
mdiradoorian mdiradoorian is offline
FIRST Alum
AKA: Matthew
FRC #0696 (CircuitBreakers)
mdiradoorian has a brilliant futuremdiradoorian has a brilliant futuremdiradoorian has a brilliant futuremdiradoorian has a brilliant futuremdiradoorian has a brilliant futuremdiradoorian has a brilliant futuremdiradoorian has a brilliant futuremdiradoorian has a brilliant futuremdiradoorian has a brilliant futuremdiradoorian has a brilliant futuremdiradoorian has a brilliant future
Definitely a nice looking robot cannot wait until LA regional to see it up close and in a match.
Best of luck to Team 1515 at the LA regional
Unread 26-02-2012, 14:49
AllenGregoryIV's Avatar
Engineering Coach
AKA: Allen "JAG" Gregory
FRC #3847 (Spectrum)
I second that, your controls sound fantastic. Any chance of a white paper on how you are using the touch screen?
Unread 26-02-2012, 19:59
AKA: Mathew Simon
Working on getting a few pictures of the control system. I'm not sure if I can get them today, but I will definitely have some come monday.
Mathew Simon
CAD/Design
