Go to Post Success is realizing that anything is possible, persistence is the key. - SlamminSammy [more]
Go Back   Chief Delphi > Technical > National Instruments LabVIEW and Data Acquisition
Unread 24-02-2012, 22:14
Kevin Thorp's Avatar
Kevin Thorp Kevin Thorp is offline
AKA: Kevin Thorp
FRC #3489 (Category 5)
Kevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond repute
All our motors are weak (low voltage)
We have quite a few motors on our robot and they all have the same problem. We noticed they seemed weak, so we put a multimeter on them. They're cycling 5-7-9 volts, never getting to the full 12. However if we bypass the Jags & Victors the motors run much stronger and we measure 12 volts.
What could cause this issue in Labview?
Unread 24-02-2012, 23:24
Re: All our motors are weak (low voltage)
Opening a motor as a Victor but using a Jaguar will give less than full-scale output, so it could possibly be a programming issue.
I'd be looking at the wiring, though. It sounds like something close to the battery is dropping a lot of voltage.
Unread 24-02-2012, 23:58
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
All the motors, though? That's some epicly bad wiring, if so. Sometime you can get effects like this if your code sends different values to a jaguar during a single loop cycle. If you're accidentally zeroing out the motor command as well as setting it to full on, you can get a weird effect similar to this.
Unread 25-02-2012, 08:04
AKA: Kevin Thorp
Our electrical mentor used to do wiring on the Space Shuttle, so I think he's made sure the kids did a good job wiring our robot.
We're not as confident in our programming skills though. We'll try to find out if we're cycling our motor voltages.
Thanks!
Unread 25-02-2012, 09:39
Feel free to post the relevant file(s) and someone will take a look at them.
Unread 26-02-2012, 03:09
372 lives on 372 lives on is offline
FRC #0372 (Robo-Knights)
Team Role: Mascot
372 lives on has a spectacular aura about372 lives on has a spectacular aura about372 lives on has a spectacular aura about
have you calibrated your motor controllers; from my experience the factory calibration will allow a much lower voltage then the maximum.
cole?
Unread 26-02-2012, 07:32
AKA: Kevin Thorp
I'm not sure what our programming team did, but it seems to be working well now. Thanks again!
Unread 26-02-2012, 09:27
Since you're a mentor, you might want to find out. That kind of knowledge can be useful going forward.
