Go to Post I personally think a large trophy and that warm, fuzzy feeling you get inside is a satisfactory prize for winning a competition. - Dan Petrovic [more]
Unread 24-02-2012, 23:06
mickey mickey is offline
FRC #3843
mickey is an unknown quantity at this point
weird clicking and buzzing on power distribution board
Im trying to deploy labview code to my cRIO but it almost always doesn't complete the deployment process. The power distribution board was clicking like an ossilating relay, but our electrical team found a bad jaguar controller and removed it. The clicking stopped and I could deploy some code, but about an hour later, the power distribution board started buzzing and I get the "waiting for real-time target to respond" message. The code should be good, and the ip communications is also correct. I think the problem is electrical, but I cannot isolate the cause.
Unread 24-02-2012, 23:11
drwisley's Avatar
drwisley drwisley is offline
FRC Coach
AKA: Dave
FRC #1756 (Argos)
drwisley has a brilliant futuredrwisley has a brilliant futuredrwisley has a brilliant futuredrwisley has a brilliant futuredrwisley has a brilliant futuredrwisley has a brilliant futuredrwisley has a brilliant futuredrwisley has a brilliant futuredrwisley has a brilliant futuredrwisley has a brilliant futuredrwisley has a brilliant future
Re: weird clicking and buzzing on power distribution board
Try pulling each fuse until the clicking goes away. That should isolate the electrical problem.
Unread 24-02-2012, 23:15
FRC #3843
Once the defective jaguar was removed, the clicking stopped. But even when I removed everything from the power dist. except the crio, the power dist. still buzzes. Is the buzzing normal?
Unread 25-02-2012, 00:19
drwisley's Avatar
FRC Coach
AKA: Dave
FRC #1756 (Argos)
That's not normal, sorry I haven't come across that issue yet.
Unread 25-02-2012, 00:38
Clicking usually means that something is drawing enough current to trip a circuit breaker. The breakers are auto-resetting, so the clicks will repeat rapidly. (You mentioned a "bad" Jaguar? The typical cause of that would be connecting power to the motor output instead of the power input.)
Buzzing would be coming from one or more of the boost power supplies providing up-regulated 12 and 24 volts. If the battery voltage drops low enough, they can get noisy. I've also heard a squeal at a very high pitch when I used a 12-to-5 volt converter other than the one from the Kit of Parts.
Unread 25-02-2012, 11:07
FRC #3843
So why can't I deploy code to the robot? Should I try a more charged battery? Or is this not an electrical problem?
Unread 25-02-2012, 12:03
Certainly, the first thing to use is a freshly charged battery.
Unread 25-02-2012, 12:49
RoboTigers1796 RoboTigers1796 is offline
FRC #1796 (RoboTigers)
RoboTigers1796 is a glorious beacon of lightRoboTigers1796 is a glorious beacon of lightRoboTigers1796 is a glorious beacon of lightRoboTigers1796 is a glorious beacon of lightRoboTigers1796 is a glorious beacon of lightRoboTigers1796 is a glorious beacon of light
Its either the an amp breakers on the board that needs to be replaced, but our team encountered this problem also...in our situation the polarities on one of the victors was reversed.
2014 Attended: NYC Regional, SBPLI Regional NYC Regional- Imagery Award in honor of Jack Kamen
2013 Attended: NYC Regional, SBPLI Regional, FIRST Championships NYC Regional- Gracious Professionalism Award sponsored by Johnson & Johnson,SBPLI Regional- #4 Alliance Captain & Regional Winner- With our impeccable alliance 358 and 3171
2012 Attended: NYC Regional, SBPLI Regional, FIRST Championships NYC Regional- #7 Ranked Seed & Semi-Finalists, SBPLI Regional- #3 Seed & Regional Winner- With our very awesome alliance 527 and 870, Industrial Design Award sponsored by General Motors
2011 Attended: NYC Regional, SBPLI Regional SPBLI Regional- Xerox Creativity Award and #5 Alliance Captain
2009 Attended: NYC Regional, FIRST Championships NYC Regional Winner- With our amazing alliance 1807 and 56
Unread 25-02-2012, 15:16
PAR_WIG1350's Avatar
AKA: Alan Wells
FRC #1350 (Rambots)
When the cRIO's power consumption is low, the 24volt supply hums (could also be called a whine, or a buzz). It's on page 7 here.
Unread 25-02-2012, 15:28
FRC #3843
Thanks for the help. Once I used a fully charged battery, the buzzing stopped. I also reformatted the cRIO. The code now does deploy to the robot correctly. I think the reformatting helped the most, but I'm glad to know that the buzzing is normal for weak batteries, rather than a sign of a defective part.
