Go to Post To borrow a slogan from the last place KC Royals "It's Our Time" The curse will be broken! ;) - Alpha Beta [more]
Unread 25-02-2012, 17:38
neal's Avatar
neal neal is offline
Neal
FRC #1777 (Viking Robotics)
neal is an unknown quantity at this point
Complex math equation
I was wondering if someone could help me figure out an equation for:
I want to scale a double (between 8-13) to be from 0 - 100.
So 8 will be 0, 9 will be 20, 13 will be 100, 12.5 will be 90 and so on.
I hope that makes sense and would appreciate if someone could help.
Thanks in advance!
Unread 25-02-2012, 17:42
Re: Complex math equation
Thanks in advance!
y = 20*x - 160
connor.worley's Avatar
connor.worley connor.worley is offline
connor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond repute
Well, you have a range of 5 and you want to scale that to a range of 100, so you'll need to multiply by 20. You want to start at 8 though, so you need to subtract 8 * 20.
output = 20*input - 160
Team 973 (2016-???)
Team 5499 (2015-2016)
Team 254 (2014-2015)
Team 1538 (2011-2014)
2014 Driver (25W 17L 1T)
日本語でOK
Unread 25-02-2012, 17:46
neal's Avatar
Neal
Thanks Ether and Connor!
Unread 25-02-2012, 19:33
Cal578 Cal578 is offline
Passionate FIRST-er, CD donor
AKA: Gerry
FRC #0578 (Red Raider Robotics)
Cal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant future
You should know the general process for figuring this out, just in case your situation changes and you want a new formula.
You want:
y = m * x + b
and you want this to be true for x=8 -> y=0, and for x=13 -> y=100.
So, you have two equations to solve for two variables:
0 = m * 8 + b
100 = m * 13 + b
If you subtract the first equation from the second, the b terms will cancel out:
100 = m * (13 - 8)
100 = m * 5
20 = m
Substitute 20 into either of the equations (the first is easier):
0 = 20 * 8 + b
b = -160
I hope this is helpful. When I saw the thread title "Complex math equation", I thought we were going to discuss real and imaginary numbers. A math geek gets easily excited...
Cal
R3: Red Raider Robotics (FRC Team 578)
Fairport, NY, USA
www.FairportRobotics.org
2016 Finger Lakes Regional: Semifinalist on Alliance 7 (1128, 2010, 578)
2016 NYC Regional: Finalist on Alliance 3 (3419, 578, 3017), 4th seed team, Team Spirit Award
2015 Finger Lakes Regional: 8-3-0 in qualification, 7th seed, Quarterfinalist
2014 NY Tech Valley Regional: 8-4-0 in qualification, 13th seed, Semifinalist
2013 Finger Lakes Regional: 4-5-0 in qualification, 26th seed, Alliance 6, 1-2 in tournament
2012 Buckeye Regional: Gracious Professionalism Award, 7-3-0, 14th seed
2011 Finger Lakes Regional: Engineering Inspiration Award
Unread 25-02-2012, 20:04
Just use the two-point formula:
y = y1+(x-x1)/(x2-x1)*(y2-y1)
with x1=8, x2=13, y1=0, y2=100 this gives y = 20*(x-8)
or plot your data in Excel
8,0
9,20
12.5,90
13,100
to see the shape, and then
click on "add trendline" and select an appropriate model (linear in this case) to fit (and it will give you the equation)
