Go to Post I wouldn't recommend using steel because it will eat up your weight budget pretty quickly. - Scott Morgan [more]
View Poll Results: Tall Shooter or Short Shooter
Tall 63 52.50%
Short 57 47.50%
Voters: 120. You may not vote on this poll
Unread 24-02-2012, 21:19
Grim Tuesday's Avatar
AKA: Simon Bohn
FRC #0639 (Code Red)
Re: Tall Shooters vs Small Shooters
We have a short shooter (24" at the very top, yeah we have a small robot), and our rationale was:
  • Less weight-you don't need to build a huge superstructre on the shooter
  • Lower Center of Gravity-you can cross the barrier and the bridge without tipping over.
Unread 24-02-2012, 22:55
Donut Donut is offline
The Arizona Mentor
AKA: Andrew
FRC #2662 (RoboKrew)
Another short shooter here. Our robot is under 3 feet to make sure we won't flip in the event of a bridge mishap. It made mounting electronics interesting but also cut out a good chunk of aluminum weight. We're at 119 still so we definitely took advantage of it.
Unless you're shooting at a low angle I don't see having a short shooter being a huge factor in competition. Those shooting from the key will ensure anyone close enough to block them takes penalties and those shooting from the fender will need to have no one in front of them to score anyway.
Unread 25-02-2012, 00:14
PayneTrain's Avatar
PayneTrain PayneTrain is offline
please put down the gun
AKA: Lizard King
FRC #0422 (The Meme Tech Pneumatic Devices)
Team Role: Mascot
PayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond repute
Mid shooter at 48". It allows our camera to be around 42" up, and we never tipped in practice on bumpr or bridge (thanks to a lot of clever placements from yours truly, giant wheels, and a wheelie bar.
Unread 25-02-2012, 08:43
Siri's Avatar
Siri Siri is offline
Dare greatly
AKA: 1640 coach 2010-2014
FRC #2641 (PCCR; Refs & RIs)
~55in because we have a feeding shot (in addition to a key shot) that we don't want to have blocked in the opposing zone. Still she's a little tipp-y in wide snake (another unicorn drive this year). We'll fix that.
Unread 25-02-2012, 09:22
GilaMonsterAlex's Avatar
GilaMonsterAlex GilaMonsterAlex is offline
Lead Team Mentor
FRC #3785 (Gila Monsters)
GilaMonsterAlex is an unknown quantity at this point
Our shooter is ~ 24" and the robot is 39" tall I think. Our plan was that we would have a lower cg for the bump and bridge plus reducing weight. We also figured there wouldn't be many opposing robots blocking.
2014 - AZ Regional Finalist
2013 - AZ Regional Finalist
2013 - AZ Gracious Professionalism Award
2011 - AZ Motorola Quality Award
Unread 25-02-2012, 18:13
Orion.DeYoe Orion.DeYoe is offline
FRC #5413 (Stellar Robotics)
Orion.DeYoe is a splendid one to beholdOrion.DeYoe is a splendid one to beholdOrion.DeYoe is a splendid one to beholdOrion.DeYoe is a splendid one to beholdOrion.DeYoe is a splendid one to beholdOrion.DeYoe is a splendid one to beholdOrion.DeYoe is a splendid one to beholdOrion.DeYoe is a splendid one to behold
Originally Posted by Kohala2460 View Post
easier to block the short guy . why do you think you dont see any...... shorter ethnicities playing basketball
That's not true based on our design. Our robot launches the ball from aprozimately 36 inches above the ground with an angle of 65 degrees. And even if a 60 inch robot is parked right up against our front bumper we can still shoot over them without a problem.
Unread 25-02-2012, 18:17
tomy tomy is offline
FRC #3038 (I.C.E. Robotics)
tomy has a spectacular aura abouttomy has a spectacular aura about
our team is very very fast to stop blockers
Unread 25-02-2012, 18:20
Andrew Lawrence
Posts: n/a
We're a mid shooter, just a little under 50", and we may end up shortening it. We don't have too many tipping problems, and I doubt anyone can block us from shooting.
Unread 25-02-2012, 18:33
Peter Matteson's Avatar
Ambitious but rubbish!
FRC #0177 (Bobcat Robotics)
Originally Posted by artdutra04 View Post
Not necessarily. It's entirely possible to design short shooters that shoot at an angle that's impossible to block. (E.g. the ball is over 60" above the ground by the time it leaves the robot's frame perimeter).
Just like 25 in 2006. Everyone thought they shot low but the ball left their frame perimeter very high in actuality.
Thank-you 294 & 67
www.bobcatrobotics.org
Unread 25-02-2012, 19:53
stundt1's Avatar
stundt1 stundt1 is offline
Steve
FRC #4930 (Electric Mayhem)
stundt1 will become famous soon enoughstundt1 will become famous soon enough
We originally planned as having our shooter at 58 inches high. Yikes we would have tipped easily. We then wanted to reduce as much weight and still have the same ability to shoot over tall defenders from blocking our shots.
So we did the math and psychics and calculated that, using our shooter would still be able to go over a 60 inch defender if we lowered the height to 48 inches. Thats about 10 inches shorter lowering our center of gravity.
So I guess we are a median shooter at 48 inches.
Steve
-Programming Mentor
- Team 578 Alumni
Unread 25-02-2012, 19:57
jblay's Avatar
jblay jblay is offline
Here comes StuyPulse
AKA: Joe Blay
FRC #0694 (StuyPulse)
jblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond repute
We have a short shooter but because when the ball leaves our perimeter it is above 60 inches it makes no difference. We figured the lower we could put our shooter, the better. This way we keep our center of gravity lower and struggle less with the bump and bridge and overall have more stable driving.
It's pronounced StighPulse like HighPulse
2016 Curie Champions
2016 New York City Champions
2016 New York City Engineering Inspiration
2015 New York City Finalists
2013 New York City Champions
2012 Connecticut Chairman's
2011 Connecticut Chairman's
2010 Connecticut Chairman's
2010 New York City Champions
2008 New York City Engineering Inspiration
2007 New York City Finalists
2006 New York City Finalists
2005 New York City Chairman's
2003 New York City Champions
2002 New York City Engineering Inspiration
2001 New York City Finalists
Unread 25-02-2012, 20:06
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
FRC #0095 (The Grasshoppers)
We built a tall shooter. In our week 0 our autonomous shot over the top of a short shooter, who then shot after us. It worked out quite well, there is definitely a place for both in the game.
Mr. Rogers's Avatar
Mr. Rogers Mr. Rogers is offline
That? That was in the CAD.
FRC #3539 (Byting Bulldogs)
Mr. Rogers will become famous soon enoughMr. Rogers will become famous soon enough
Shoot from the back of the key, the opposing alliance wouldn't risk entering the front of the key to block shorter bots. One possible problem with short bots though, the shot won't be blocked because of the arc, but the linear line of sight of the camera might be.
Grow the roses of success!
2011 Archimedes 2nd seed,
2011 Waterford Champion, 2011 Troy Simi-Finalist,
2011 Waterford Rookie all star, 2011 Troy Rookie all star
http://www.bytingbulldogs.com/
Unread 25-02-2012, 21:16
S2K JDM's Avatar
S2K JDM S2K JDM is offline
FRC #1378 (Hilo Viking Robotics)
S2K JDM is an unknown quantity at this point
we actually put our shooter on a elevator lift so we can choose our heights. it worked out a lot better than i thought. and also put our camera low because we didn't see the point for tracking since we don't have turret.
Team 1378 Hilo Viking Robotics| student | 2007-2009
Team 1056 Warrior Pride| Alumni | 2009-2010
Team 1378 Hilo Viking Robotics| Mentor |2011-present
Unread 26-02-2012, 00:47
WizenedEE's Avatar
AKA: Adam
FRC #3238 (Cyborg Ferrets)
Our shooter is about 40" up, because we already have the x position fixed and the length of the collector (the hypotenuse) fixed.
