Go to Post Robots can be fixed, glory is forever - Brandon Holley [more]
  #46   Spotlight this post!
Unread 25-02-2012, 09:54
Cal578 Cal578 is offline
Passionate FIRST-er, CD donor
AKA: Gerry
FRC #0578 (Red Raider Robotics)
Cal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant future
Re: Teams: Check Your Bumpers
Originally Posted by jyh947 View Post
The frame perimeter was extended by one inch, from 6.25 inches, to satisfy the rules.
If this means you now have 7.25" of frame, measured from the corner to the inside opening, then I'm afraid it's still not legal. You must have 8" of frame on each side of the vertex (the outside corner of the frame) per [R27]. I presume you have 3/4" of plywood extending past the corner, to overlap with the other bumper, but that doesn't count toward the 8".
I would spend the time between now and your first competition cutting two pieces of 8" channel, and making new front bumpers, so your team can do a quick replacement on practice/inspection day.
Best of luck to you.
Cal
R3: Red Raider Robotics (FRC Team 578)
Fairport, NY, USA
www.FairportRobotics.org
2016 Finger Lakes Regional: Semifinalist on Alliance 7 (1128, 2010, 578)
2016 NYC Regional: Finalist on Alliance 3 (3419, 578, 3017), 4th seed team, Team Spirit Award
2015 Finger Lakes Regional: 8-3-0 in qualification, 7th seed, Quarterfinalist
2014 NY Tech Valley Regional: 8-4-0 in qualification, 13th seed, Semifinalist
2013 Finger Lakes Regional: 4-5-0 in qualification, 26th seed, Alliance 6, 1-2 in tournament
2012 Buckeye Regional: Gracious Professionalism Award, 7-3-0, 14th seed
2011 Finger Lakes Regional: Engineering Inspiration Award
  #47   Spotlight this post!
Unread 25-02-2012, 10:40
ZipTie3182's Avatar
ZipTie3182 ZipTie3182 is offline
AKA: Anna Sklenar
FRC #3182 (Athena's Warriors)
ZipTie3182 is a jewel in the roughZipTie3182 is a jewel in the roughZipTie3182 is a jewel in the roughZipTie3182 is a jewel in the rough
I'm sorry if this has already been said. I skimmed through and didn't see it.
Is there a definitive rule that requires all numbers to be on one side of the short bumpers and not split? We already made our red pair and would like to know if we need to redo the fabric before we make our blue pair. We'll need to make new stencils as the ones we have won't fit on the small bumper.
-Anna
  #48   Spotlight this post!
Unread 25-02-2012, 10:47
dodar's Avatar
dodar dodar is offline
FRC #1592 (Bionic Tigers)
dodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond repute
A lot of teams are taking the safe route and moving all to one side of a split bumper but some are going ahead with split numbers because the ruling is kinda vague on that point. But I believe the ones that did do the split numbers have also made some that are all on one side just in case they are wrong.
1592(Student and Mentor) 2007-Present
Blue Banners: 2008 Colorado, 2012 Orlando, 2012 South Florida, 2014 Orlando, 2015 Buckeye
Mechanical Engineering - University of Central Florida(Class of 2016)
  #49   Spotlight this post!
Unread 25-02-2012, 10:53
one4robots one4robots is offline
AKA: Vince Wagner
FRC #2530 (Inconceivable)
one4robots is on a distinguished road
Originally Posted by Duke461 View Post
Maybe someone should make a robot that purposely follows the bumper rules exactly, yet all 4 sides get completely obscured and no one can ever see the numbers.
I'm kidding, of course.
But seriously, why does FIRST need to this? It is so superfluous!
Tangent question (and this is just a thought, my team did not do this): Would one be allowed to securely/rigidly mount a piece of polycarbonate, or some mounted "plate" to the bumper, that actually extended past the 8 inches of bumper into the "U" area such that i could much more easily write out a number?
Just my thoughts, complaints, jokes, concerns, or something......
-Duke
Perhas it is to prepare our students for the eventuality of a customer demanding something in the product that is completely superfluous and ridiculously unnecessary. Does that ever happen in real life?
It's Inconceivable!
2015 Wisconsin Regional Winner - Thanks 2826 and 2062!
2014 Wisconsin Regional Semi-finalist and Alliance Captain - Thanks 167 and 4296!
2014 MSHSL Finalist and Alliance Captain - Thanks 3018 and 4607!
2013 Northern Lights Gracious Professionalism Award
2012 MRI Champions - Thanks, 3883 and 3630!
2012 MSHSL State Tournament Semi-finalist
2012 10,000 Lakes Regional Finalist
2012 10,000 Lakes Regional Delphi Engineering Excellence Award
2012 Lake Superior Regional GM Industrial Design Award
2011 Minnesota Robotics Invitational (MRI) Champions - Thanks, 2052 and 2450!
2011 Inaugural Lake Superior Regional Finalist
2011 Lake Superior Regional Judges Award
  #50   Spotlight this post!
Unread 25-02-2012, 10:56
AKA: Vince Wagner
Unfortunately, Cal is correct. You need 8" of frame (not plywood, which is considered part of the bumper). Spend the time befre your regional making 8 inch front frames. Sorry and good luck!
It's Inconceivable!
  #51   Spotlight this post!
Unread 25-02-2012, 11:02
JohnBoucher JohnBoucher is offline
Blue Shirt
FRC #0237
JohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond repute
See this post
http://www.chiefdelphi.com/forums/sh...6&postcount=29
  #52   Spotlight this post!
Unread 25-02-2012, 11:04
The Q&A response is clear and unmistakeable:
[Numbers] may not be inverted, obscured, fragmented, upside down, etc.
Split numbers fall under the "fragmented" category.
  #53   Spotlight this post!
Unread 25-02-2012, 11:05
engunneer's Avatar
Alumni turned Mentor
AKA: Branden Gunn
FRC #4761
-Anna
There are multiple Q&A Answers that say you cannot Fragment your numbers
A. Per [R35], team numbers must be clearly visible. This means that they may not be inverted, obscured, fragmented, upside down, etc. Bumpers that wrap around a corner are likely to be considered fragmented and not able to be seen in their entirety.
is just one of them.
  #54   Spotlight this post!
Unread 25-02-2012, 11:13
Koko Ed's Avatar
Koko Ed Koko Ed is offline
Serial Volunteer
AKA: Ed Patterson
FRC #0191 (X-Cats)
Maybe FIRST made these bumper rules so IRI would have something to blow off come July.
  #55   Spotlight this post!
Unread 25-02-2012, 11:24
johnr johnr is offline
FRC #0910
johnr has a reputation beyond reputejohnr has a reputation beyond reputejohnr has a reputation beyond reputejohnr has a reputation beyond reputejohnr has a reputation beyond reputejohnr has a reputation beyond reputejohnr has a reputation beyond reputejohnr has a reputation beyond reputejohnr has a reputation beyond reputejohnr has a reputation beyond reputejohnr has a reputation beyond repute
Q&A has answered the question about blocking your team numbers. It's ok too. Now all teams go build that cow catcher.
  #56   Spotlight this post!
Unread 25-02-2012, 11:29
Michael Hill's Avatar
I'm sorry, but FIRST has really missed the mark when it comes to bumpers. What real difference does it make if a team displays their number more than 4 times? I know FIRST is supposed to get kids interested in STEM, but emulating the pointless bureaucracy and red tape that actually exists in the real world is not the way to do it.
end rant.
  #57   Spotlight this post!
Unread 25-02-2012, 12:21
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
I think it's good that FIRST is letting our students get a taste of the real world....you gotta have a lot of fortitude to make it in STEM, after all
  #58   Spotlight this post!
Unread 25-02-2012, 17:58
Duke461's Avatar
Duke461 Duke461 is offline
Boiler Strong.
AKA: Ben Carson
Duke461 has a reputation beyond reputeDuke461 has a reputation beyond reputeDuke461 has a reputation beyond reputeDuke461 has a reputation beyond reputeDuke461 has a reputation beyond reputeDuke461 has a reputation beyond reputeDuke461 has a reputation beyond reputeDuke461 has a reputation beyond reputeDuke461 has a reputation beyond reputeDuke461 has a reputation beyond reputeDuke461 has a reputation beyond repute
Originally Posted by PAR_WIG1350 View Post
Wouldn't this defeat the purpose of having a 'U' shaped opening, That would effectively make it an 'O' again.
No, the polycarbonate that was hanging off the end would be flexible, but i suppose that would only retain its "U" functionality if the robot had a ball manipulator outside of the frame of the robot. I was more just wondering the legality of doing so.
The opposite of excellence is good enough.
2012-2013 President; 2011-2012 Vice President
2011-offseason FRC Student Drive Coach; 2010-11, 2011-2012 VEX Drive Coach
2011, 2010-offseason FRC Driver/Operator
2012, 2011-offseason, 2010-offseason FRC Human Player
Find me on: Facebook, Gmail, Twitter, Tumblr, Blogger/Blogspot
  #59   Spotlight this post!
Unread 25-02-2012, 18:28
pyroslev's Avatar
pyroslev pyroslev is offline
VirginiaFIRST FTA
AKA: Jack of all trades, Master of few
no team (Forget not 616)
pyroslev is on a distinguished road
I already know we're gonna have to redo ours on one ...
Unless they come out and amend some of those rules for the numbering. At this point, I can see an update post First week regional, if not by this Friday Lunch time.
"Complications arose, ensued...were overcome." "I'd trade 500 CNC machines for one good hearted student."
From December to April, since 2002, I forfeit my mental sanity for perfect insanity.
  #60   Spotlight this post!
Unread 25-02-2012, 19:14
JosephC's Avatar
JosephC JosephC is offline
FF: Breakfast Company
AKA: Joseph Cupchack
no team (FiM Volunteer Extraordinaire)
JosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond repute
end rant.
Let's pretend we're team number 16. Under the current bumper rules you may only have 1 number per side.
--------16---------
Lets say the rules were changed to allow more then 4 numbers, and we decide to put our number twice on each side.
-----16---16----
Which team are we, 16 or 1616?
Referee: 2015 - ?
Field Reset/Supervisor: 2013 - ?
68 Team Member: 2011 - 2013
