Go to Post Just goes to show that you don't need to be like everyone else to make it to Einstein. - O'Sancheski [more]
Unread 25-02-2012, 19:31
Re: A real puzzle - Electromechanical fault
The two PDP protected 12v & 24v outputs are good down to about 4.5v, maintaining their 12v/24v.
The 5v PDP output get cut off at around 5.5v.
Beware sharp sudden spiky dips at low voltages.
See Power Distribution Board.pdf, pages 6 & 7 Specifications for minimum voltages for the 24v protected supply, 12v protected supply and 5v outputs.
P.S.
Correction: the regular 12v outputs do not get cut off at low voltage. They follow the battery on down.
But, something cuts controlling PWM/relay outputs at less than 6v, so the effect is the same.
