Go to Post There are laws of physics, useful rules of thumb, and cold hard economics that come into play to be sure but at it's core Engineering is Art. For these artists, there is no substute for the sound engineering judgement. - Joe Johnson [more]
Unread 25-02-2012, 21:20
Re: Periodic Tasks
You don't have to do anything in Periodic Tasks, other than what you've done with the compressor loop.
The rest of that is just an example and an empty framework of what you could do.
Unread 25-02-2012, 21:46
DeadlyJohny DeadlyJohny is offline
FRC #3417
DeadlyJohny is a splendid one to beholdDeadlyJohny is a splendid one to beholdDeadlyJohny is a splendid one to beholdDeadlyJohny is a splendid one to beholdDeadlyJohny is a splendid one to beholdDeadlyJohny is a splendid one to behold
Re: Periodic Tasks
Should I delete the example code? And am I done with the compressor code?
Unread 25-02-2012, 21:48
DominickC DominickC is offline
FRC #0023 (PNTA)
Rookie Year: 1620
DominickC is an unknown quantity at this point
Re: Periodic Tasks
It depends. Are you using a compressor?
Unread 25-02-2012, 23:17
FRC #3417
Re: Periodic Tasks
Yes i am.
Unread 26-02-2012, 07:45
FRC #0023 (PNTA)
Rookie Year: 1620
Re: Periodic Tasks
Alright, then all you need to do is remove the Diagram Disable/Enable Structure from the Loop in Periodic Tasks.vi. Then you're all set to use the compressor elsewhere in the code!
Unread 26-02-2012, 12:32
FRC #3417
Re: Periodic Tasks
So in other words, this:
Unread 27-02-2012, 16:06
FRC #0023 (PNTA)
Rookie Year: 1620
Re: Periodic Tasks
Pretty much. To get rid of unneeded code, delete everything other than the While loop controlling the LED flash rate and your compressor code. I'd also right click on the Diagram Enabled structure and click Remove Diagram Enable Structure, as it's not needed.
