Go to Post We want you here, and we want you back. Welcome. - Gary Dillard [more]
Go Back   Chief Delphi > Competition > Rules/Strategy > Scouting
Unread 26-02-2012, 09:10
fovea1959's Avatar
fovea1959 fovea1959 is offline
Herder of programmers
AKA: Doug Wegscheid
FRC #3620 (The Average Joes)
fovea1959 will become famous soon enough
what are people doing for wireless at venue for scouting
since we can't use 802.11 at an event, what alternatives are people exercising for wirelessly communicating at an event? cellular data (3G/4G)? has anyone tried 802.15 yet, or X-Bee?
I sure wish the FIRST would just cave and set up a 2nd 802.11 just for scouting; so many teams just defy the rules and set up a private one anyway....
Unread 26-02-2012, 10:48
PAR_WIG1350's Avatar
AKA: Alan Wells
FRC #1350 (Rambots)
Re: what are people doing for wireless at venue for scouting
We use the original wireless network, paper and people who walk quickly. Cellular data should also work, as long as you can get a signal. Also, cellular data can't be used during the matches, so all data that might want during a match should be gathered before the match begins, but this should already be true. Matches are too short to waste time fumbling around to find notes about the opposing alliance.
Unread 26-02-2012, 10:57
ebarker's Avatar
ebarker ebarker is offline
AKA: Ed Barker
FRC #1311 (Kell Robotics)
ebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond repute
that's unfortunate !!
paper, pencil, and texting
Ed Barker
Unread 26-02-2012, 11:00
DonRotolo's Avatar
Back to humble
FRC #0832
Sometimes sneakernet (lots of memory sticks!), usually actual wired ethernet, sometimes the venue allows 802.11 on 2.4 GHz (it's happened!), and twice 900 MHz with borrowed equipment.
A bigger problem for us is 110VAC in the stands.
Unread 26-02-2012, 11:10
Well, the field crew does have a network finder. Presumably, they know what the standard venue networks are, and what should be up due to the teams on the field. If there's an issue, it's not that hard to locate a network base to shut it down (or make an announcement that a given network needs to be shut down).
Sneakernet is always a viable option. Sometimes, the simplest tools are the best ones!
[IMG] code is Off
