Go to Post Could you explain this concept of a break from FIRST? Did my wife put you up to this? - Gary Dillard [more]
Unread 25-02-2012, 23:12
Re: Our programmer left...
The Solenoid Set function's value input expects an enumerated value of Off, On, Forward, or Reverse. Those are mapped to integers 0-3, respectively. If you provide a boolean input, a single solenoid is supposed treat a false as Off and a true as On. I don't know if it would work right for a double solenoid. It's likely that you'll see the solenoid engaged as both forward and reverse at the same time, leading to an indeterminate state when the button is released.
The typical way to control a double solenoid from a button is to use a case block controlled by the button boolean value. In the true case, set the solenoid Forward, and in the false case set it Reverse. You can also use a Select (found in the Comparison subpalette) to choose between a Forward and a Reverse constant to feed to the Solenoid Set value.
Unread 26-02-2012, 12:34
DeadlyJohny DeadlyJohny is offline
FRC #3417
DeadlyJohny is a splendid one to beholdDeadlyJohny is a splendid one to beholdDeadlyJohny is a splendid one to beholdDeadlyJohny is a splendid one to beholdDeadlyJohny is a splendid one to beholdDeadlyJohny is a splendid one to behold
I get what your saying but is what I've done serve my purpose of pulling the trigger and releasing it causing the piston to fire and retract back?
Unread 26-02-2012, 13:06
No, what you wrote will not work, because it's a double solenoid.
It would only work with a single solenoid.
Unread 26-02-2012, 13:17
Team3417 Team3417 is offline
FRC #3417
Team3417 is an unknown quantity at this point
Crap, that's the only way I thought I could do it. How can I fix this?
Unread 26-02-2012, 13:39
vhcook's Avatar
vhcook vhcook is online now
Reader of Things
AKA: Victoria
FRC #1939 (Kuh-nig-its)
vhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond repute
First, disconnect the boolean from the solenoid set. Then hover over the port it was connected to. You will see that it is blue indicating either an integer or enum value is expected. Right click on this, and select create -> constant. This will make you an enum with the right values in it. Copy this so that you have two of them.
Now, use a Select from the comparisons palette (row three, icon 3 - looks like a big triangle with a ?, T, and F). Feed your button into the S port of that, wire one of the enums into each of the T and F ports, and set the value of the dropdowns to Forward and Reverse (in the appropriate places). Wire the output to the Solenoid Set.
Unread 26-02-2012, 19:38
Doc Wu's Avatar
Doc Wu Doc Wu is offline
AKA: Al Gritzmacher
FRC #1507 (Warlocks)
Doc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant future
Because a picture is worth a thousand words...
-= Mentor Lockport Warlocks -=- Team 1507 =-
Amateur Radio Callsign: AE2T
2016 Robot Inspector - Fingerlakes, Pittsburgh
2015 Robot Inspector - Pittsburgh, Champs. Judge Observer - Champs
2014 Robot Inspector - Tech Valley, Fingerlakes, Buckeye, Championship
2013 Robot Inspector - Fingerlakes, Buckeye, Championship
2012 Robot Inspector - Fingerlakes, Buckeye, Championship - Website Evaluator - Fingerlakes, Buckeye, Championship
2011 Robot Inspector - Fingerlakes 2011 Safety Advisor - Fingerlakes
