Go to Post but you can rest assured: I have restored the balance by letting the GDC know that I know that they know that you know they have a pattern. -Leav - Leav [more]
View Poll Results: How much room do you need?
<10" 6 5.41%
10"-15" 2 1.80%
15"-20" 15 13.51%
20"-30" 40 36.04%
30"-38" 33 29.73%
>38" 15 13.51%
Voters: 111. You may not vote on this poll
Unread 26-02-2012, 11:08
Bjenks548's Avatar
Bjenks548 Bjenks548 is offline
AKA: Brendan
FRC #0548 (Robostangs)
Bjenks548 has a reputation beyond reputeBjenks548 has a reputation beyond reputeBjenks548 has a reputation beyond reputeBjenks548 has a reputation beyond reputeBjenks548 has a reputation beyond reputeBjenks548 has a reputation beyond reputeBjenks548 has a reputation beyond reputeBjenks548 has a reputation beyond reputeBjenks548 has a reputation beyond reputeBjenks548 has a reputation beyond reputeBjenks548 has a reputation beyond repute
How much Bridge Space does your robot need?
We've all seen 179's robot that takes ~3" of space. 118 showed us a side hang that essential takes up no room. Many people built a widebot to take up less of the 88" of the bridge. How much room does your robot need (including bumpers) on the bridge (without falling off)?
Toronto Regional quarter finalists. Northville Winners/ Chairman's Winners. Troy Finalist/ GM Industrial Design Award. Michigan State Championship Finalists. CMP Newton Division winners! Triple Balance count 13. Thanks to 1075, 4307, 67, 3656, 217, 2604, 2054, 245, 118, and 2194! Photo credit for my avatar Dan Ernst
Unread 26-02-2012, 13:19
Kellen Hill's Avatar
Kellen Hill Kellen Hill is online now
Strategist
AKA: The user formerly known as 'hill'
FRC #1746 (OTTO)
Kellen Hill has a reputation beyond reputeKellen Hill has a reputation beyond reputeKellen Hill has a reputation beyond reputeKellen Hill has a reputation beyond reputeKellen Hill has a reputation beyond reputeKellen Hill has a reputation beyond reputeKellen Hill has a reputation beyond reputeKellen Hill has a reputation beyond reputeKellen Hill has a reputation beyond reputeKellen Hill has a reputation beyond reputeKellen Hill has a reputation beyond repute
Re: How much Bridge Space does your robot need?
This is an interesting subject, as I feel like many people view 179 and 118 as robots that allow you to easily get 3 robots on a single bridge. The problem here is that while these robots require little to no room on top of the bridge, they still have a large footprint on top of the bridge. While they may not be physically using the space, their weight is still hanging there, meaning that other robots can't use the space. Depending on these robot's weights and where their center of gravity is, they aren't really making the bridge balancing challenge much easier.
In fact, 179 might be making it a little more difficult as all of their weight is out at the edge of the bridge (not sure what 179 weighs, but hopefully it would be somewhere south of 100lbs). If they do weigh the entire 120lbs plus all the goodies, they would have a much larger than average foot print on top of the bridge, forcing their two teammates to drive as far as they can to the other edge of the bridge in order to balance it.
I think I prefer 118's balancing technique due to their ability to have their weight more towards the center of the bridge when it comes to balancing. While I do highly enjoy both of these unique designs, they still have many of the drawbacks that any other robot on top of the bridge would have. I will be interested in seeing if these designs can make the bridge balancing act any easier than 3 'standard' robots trying to do it.
Overall point being that space occupied on the bridge, especially for these two bots, does not always equate to the actual amount of space needed on the bridge. To properly gauge a robot's footprint, you should consider other characteristics such as weight and center of gravity along with actual room required on top of the bridge.
1625 Winnovation Member: 2005-07
1625 College Mentor: 2007-11
525 Swartdogs Mentor: 2011-12
1746 OTTO Lead Mentor: 2013-Present
Unread 26-02-2012, 13:25
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
26 + 2 (3.25) = 32.5" if between two other robots
With the 18" wheelbase and 6" wheels, we take up a bit less room on an end of the bridge. Three of our robots could fit on the bridge, but I don't know how the balancing would work out...it would be "exciting" Also we could interlock front bumpers with another robot like ours, reducing the total length needed.
Unread 26-02-2012, 13:26
Bjenks548's Avatar
AKA: Brendan
I assumed the reason 179 showed their bridge technique so early was to inspire other teams to do something similar. Imagine how easy the triple balance would be with 2 179 type robots on opposite ends.
Unread 26-02-2012, 13:31
Andrew Lawrence
Posts: n/a
While I see robots like 179's being successful bridge balancers, they still don't play as much of an offensive role to their team like teams such as 118. With 118, they not only take up less physical room for balancing, but they are also an offensive beast. I think the only robots that will be able to get by later on in the competitions are the ones who score really well, and balance on the bridge, because once you get to the championships, most everyone's going to be balancing.
Unread 26-02-2012, 13:32
pyroslev's Avatar
pyroslev pyroslev is offline
VirginiaFIRST FTA
AKA: Jack of all trades, Master of few
no team (Forget not 616)
pyroslev is on a distinguished road
This is gonna be a situation in the Alliance pickings where you're gonna see teams look for two types.
-Ball Manipulator: Shooter/Feeder that can rack points up or keep feeding a shooters
-Odd ball/Small ones: Something I can shove in the middle or that hangs off the edge, or even holds a robot on top in the middle.
I think the #8 seed is gonna have the best pick. They can pick their shooter right off the bat and then grab a 179/118 type or something similar to 701.
Then if you add in the shorter robots (28" frame), easy turning robots, mecanums, etc., That bridge is gonna be very entertaining in that bracket.
"Complications arose, ensued...were overcome." "I'd trade 500 CNC machines for one good hearted student."
From December to April, since 2002, I forfeit my mental sanity for perfect insanity.
Unread 26-02-2012, 14:06
Grim Tuesday's Avatar
AKA: Simon Bohn
FRC #0639 (Code Red)
I find it interesting that Chief Delphi has ruled 118's hanger legal. I wonder if we'll see the same ruling at a regional?
Unread 26-02-2012, 15:32
Aren Siekmeier's Avatar
on walkabout
23.5" + 6.5" makes us 30" from bumper to bumper. We'd be able to chop about 8" off one side if we're at the end of the bridge, bringing us to 22". So 3 of ours would have 14" of breathing room.
Unread 26-02-2012, 16:02
PayneTrain's Avatar
PayneTrain PayneTrain is offline
Q&A Dartboard Detractor
AKA: Lizard King
FRC #0422 (The Meme Tech Pneumatic Devices)
Team Role: Mascot
PayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond repute
We built our bumpers high and drive base wide to negate as much bridge space as possible. I fully intend on balancing 3 as much as possible if we are lucky enough to be playing in elims. The bumper locking should help us only take up <30 inches of space on the bridge.
Unread 26-02-2012, 16:22
n1ckd2012's Avatar
n1ckd2012 n1ckd2012 is offline
oRyon Labs
AKA: Nick Dulworth
FRC #2587 (DiscoBots)
n1ckd2012 will become famous soon enoughn1ckd2012 will become famous soon enough
We, 2587 DiscoBots, can balance with ~1/3 of the robot hanging off the edge. This allows another robot to drive up next to us. We are still figuring out how to get up the bridge with only half of our drivetrain. See image:
https://picasaweb.google.com/lh/phot...e mbedwebsite
Our release video:
https://vimeo.com/37359670
Our daily build log:
http://2012.discobots.org/node/31
Ri3D Team oRyon, 2014-Present
Ri3D 2015: Betelgeuse | Ri3D 2014: Draconis
2587 DiscoBots, 2010-Present
FRC 2012: Laser Dragon, Film, Build Log, Lone Star 3rd Seed Alliance
Vex 2012: Mini Dragon, Film, Math Division Finalists
FRC 2011: DiscoSlide, Film, 118 Parody, Lone Star Regional Finalists
Unread 26-02-2012, 16:46
RRLedford RRLedford is offline
FTC 3507 Robo Theosis -- FRC 3135
AKA: Dick Ledford
FRC #3135 (Robotic Colonels)
RRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond repute
We take up only 13"+ of bridge width as we cantilever the other 20" of our width, hanging off the center-of-field side of the bridge, extending most of our bot into the air well beyond the guide rail (which we do not grip). We are a six wheel "kitbot on steroids" size with severe weight concentration right forward. Our plan is to facilitate three bots on the bridge by allowing a pair of 34+" max width bots to drive right past us while we hold bridge down for them with us parked on side edge and overhanging toward center of field, just past tipping (toward them) point of the bridge. Since we can all three stay nearer the center of the bridge with this scheme, this makes balancing much easier and faster. We are thinking only 10-15 seconds for all three to balance -even with no practice.
We can tip the bridge and drive it end to end along the rail. We can balance it alone in a few seconds after our first wheel goes up. We can pre-tip the bridge downward and hold it there, allowing for our arriving alliance partners to just simply and accurately drive right up and balance (assuming they are not over 34.5" wide). We play defense and shoot returned balls the length of court, but shots go only where robot points (no aiming turret). We are still trying to get a ball pickup scheme working.
If we are partnered with wide bots in qualifying rounds, then we can go for the middle bridge coompertition points . Wide bot alliances will know not to pick us for the elimination round, In the elimination round we hope to be on an alliance with too good shooting offensive minded partners. Our 4-CIM drives lets us play decent defense and/or park at the return slot to fire balls back up the full length of the court - over any defender parked in front of it..
In Autonomous, we can get to the center bridge very fast and, since we have most of our weight up front we are going to win most tipping battles there to get those balls, After which we move over to our bridge bringing those two balls down on our way to the other side to play defense and be an up the court ball passer.
We think we will be a good alliance match fro the right capability partners.
-Dick Ledford
Unread 26-02-2012, 16:47
Swampdude's Avatar
Swampdude Swampdude is offline
AKA: Dan Quiggle
FRC #0179 (Children of the Swamp)
Swampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond repute
Good points made. We are currently just under 100lbs, and around 123 with bumpers and battery. So we figured a nominal 145 lb bot needed to have it's CG less than 19" from the other end of the bridge. Which should be easy and should only require a driver to move as far as they can out to the end. I'm hoping and in theory this should be quick and easy. If there were still a weight issue there's a few pounds to play with but I think we're good as long as we balance with 115+ lb bots.
I agree 118's method is better but we'll have to wait and see what the head ref thinks first.
I will say that the reason the bridge balancing became a priority over scoring balls was the realization of different strategies to defend shooting and starve balls etc. I think the great shooters may be in for a surprise when up against good defense, feeders and ?!?! etc. So I think the 3 bot balance will usually be key to winning in the finals.
www.179swampthing.org
Unread 26-02-2012, 18:44
PayneTrain's Avatar
AKA: Lizard King
Team Role: Mascot
I don't want to diverge, but it will be intriguing to see how defense will play out against every shooter on the planet.
I also want to go back and add that we can get by with having 7 inches of our robot hang off the back of the bridge before we get into a hairy situation. We moved most of our weight towards the front because we don't plan on being first on the bridge, unless we are the only team on it.
Unread 26-02-2012, 19:08
Bertman's Avatar
Bertman Bertman is offline
FRC #0418 (Purple Haze)
Bertman has a reputation beyond reputeBertman has a reputation beyond reputeBertman has a reputation beyond reputeBertman has a reputation beyond reputeBertman has a reputation beyond reputeBertman has a reputation beyond reputeBertman has a reputation beyond reputeBertman has a reputation beyond reputeBertman has a reputation beyond reputeBertman has a reputation beyond reputeBertman has a reputation beyond repute
maybe a question should be "how much bridge space does your driver need>"
success is not hocus posus, it's focus focus
Unread 26-02-2012, 20:00
Alpha Beta's Avatar
Alpha Beta Alpha Beta is offline
Strategy, Scouting, and LabVIEW
AKA: Mr. Aaron Bailey
FRC #1986 (Team Titanium)
Alpha Beta has a reputation beyond reputeAlpha Beta has a reputation beyond reputeAlpha Beta has a reputation beyond reputeAlpha Beta has a reputation beyond reputeAlpha Beta has a reputation beyond reputeAlpha Beta has a reputation beyond reputeAlpha Beta has a reputation beyond reputeAlpha Beta has a reputation beyond reputeAlpha Beta has a reputation beyond reputeAlpha Beta has a reputation beyond reputeAlpha Beta has a reputation beyond repute
If in the middle: 3.25 + 28 + 3.25 = 34.5" That leaves (88-34.5)/2 = 26.75" for each end.
As an end robot we take up 25.25 inches.
So, we could fit 3 of ourselves on the bridge, but not alot of room to play around.
I shudder to think what will happen when the last robot on shoves the first robot off the other edge. At least this should only be a serious problem in the elimination rounds.
Regional Wins: 2016(KC), 2015(St. Louis, Queen City), 2014(Central Illinois, KC), 2013(Hub City, KC, Oklahoma City), 2012(KC, St. Louis), 2011(Colorado), 2010(North Star)
Regional Chairman's Award: 2014(Central Illinois), 2009(10,000 Lakes)
Engineering Inspiration: 2016(Smoky Mountain), 2012(Kansas City), 2011(Denver)
Dean's List Finalist 2016(Jacob S), 2014(Cameron L), 2013(Jay U), 2012(Laura S), 2011(Dominic A), 2010(Collin R)
Woodie Flowers Finalist 2013 (Aaron Bailey)
Championships: Sub-Division Champion (2016), Finalist (2013, 2010), Semifinalist (2014), Quaterfinalist (2015, 2012, 2011)
Other Official Awards: Gracious Professionalism (2013) Entrepreneurship (2013), Quality (2015, 2015, 2013), Engineering Excellence (Champs 2013, 2012), Website (2011), Industrial Design (Archimedes/Tesla 2016, 2016, 2015, Newton 2014, 2013, 2011), Innovation in Control (2014, Champs 2010, 2010, 2008, 2008), Imagery (2009), Regional Finalist (2016, 2015, 2008)
