Go to Post NASA rarely launches another rocket just so the programmers can see if they've fixed a bug. - Greg McKaskle [more]
Unread 24-02-2012, 22:18
Jim Giacchi's Avatar
Jim Giacchi Jim Giacchi is offline
FRC #0041 (Robo-Warriors)
Jim Giacchi will become famous soon enoughJim Giacchi will become famous soon enough
Send a message via AIM to Jim Giacchi
Team 41 - Full Court Shooter
Greetings everyone, just wanted to post a picture and video of Team 41's 2012 Robot.
http://www.youtube.com/watch?v=FWj5C...ature=youtu.be
Our robot is capable of traversing the barrier, balancing on the bridge and making full court shots. The turret can rotate 220 degrees and the shooter is powered by two CIM motors.
*Cause I know it will come up. :-) We have already fixed the illegally numbered bumpers.
Good luck everyone!
Build first ask questions later.
Unread 25-02-2012, 02:27
AllenGregoryIV's Avatar
AllenGregoryIV AllenGregoryIV is online now
Engineering Coach
AKA: Allen "JAG" Gregory
FRC #3847 (Spectrum)
Re: Team 41 - Full Court Shooter
That is impressive, if you can make that shot 10% you would still be helping your alliance by passing balls across the field and keeping them away from your opponents.
I wish you the best of luck.
Unread 25-02-2012, 08:34
Siri's Avatar
Siri Siri is offline
Dare greatly
AKA: 1640 coach 2010-2014
FRC #2641 (PCCR; Refs & RIs)
Very cool! We had that just about shot on our prototype, but the robot can't seem to get it even when we're hand-feeding. Glad you made yours work and good luck this season!
However, your bumpers are illegal. As per the Q&A, [R35] means:
A. Rule [R35] requires that the team number be displayed in four locations, no more or fewer.
You can't have 41 on both sides of your front bumper.
Unread 25-02-2012, 12:21
Timz3082 Timz3082 is offline
FRC #3082 (Chicken Bot Pie)
Timz3082 is a jewel in the roughTimz3082 is a jewel in the roughTimz3082 is a jewel in the roughTimz3082 is a jewel in the rough
looks like our bot with more cnc, haha
2011 Record (11-3-0)
Unread 26-02-2012, 12:23
Pun-isher's Avatar
Pun-isher Pun-isher is offline
Gotta Go Fast
AKA: Shakeel Madhav
FRC #1759 (P.O.T.A.T.O.E.S.)
Team Role: Driver
Pun-isher is an unknown quantity at this point
According to the OP, the team already fixed it before the post
Hey bro can you pass the 7/16ths wrench? I only need it for a second hold on...
Unread 26-02-2012, 12:51
Why put two CIMs on your shooter? I hope you beefed up your drivetrain with a couple 775s then.
Unread 26-02-2012, 17:10
DampRobot's Avatar
Physics Major
AKA: Roger Romani
Well, for that full court shot. We are using a similar setup with CIMs in the shooter, and FPs in the drivetrain. We certainly aren't getting range like that, though!
Unread 26-02-2012, 17:13
Andrew Lawrence
Posts: n/a
We're making full shots with 775's. If you could. I highly suggest you make the switch from CIMs to 775's (first find some that work), and put the CIMs in the drivetrain.
Otherwise, awesome robot! I love the design and intake mechanism.
Good luck!
Unread 26-02-2012, 18:30
Chris86 Chris86 is offline
FRC #4064 (Inzombiacs)
Chris86 is a splendid one to beholdChris86 is a splendid one to beholdChris86 is a splendid one to beholdChris86 is a splendid one to beholdChris86 is a splendid one to beholdChris86 is a splendid one to beholdChris86 is a splendid one to behold
It looks like a 775 running a chain to a drive wheel in the bottom right of the picture - I might be wrong, but it looks like they've got their drive covered.
Current mentor for Team #4064
Proud former member of Team #86: Team Resistance 2007-2011
Unread 26-02-2012, 20:23
PAR_WIG1350's Avatar
AKA: Alan Wells
FRC #1350 (Rambots)
That would appear to be an AM gearmotor connected to the intake. That being said, a lane dweller like this doesn't need to have a terribly powerful drivetrain. If an opposing 'bot even touches them it would be a penalty (unless they left the lane).
Unread 26-02-2012, 23:27
Yes, we decided to use two CIM motors on the shooter, they were the best option available to do what we wanted to do (go full court). We wanted to do direct drive to minimize complexity and to limit the vibration and noise of the shooter. While it's possible to build a really nice shooter with a gearbox, it was more difficult then we were willing to bite off.
Our drive is a single CIM per side into an Andymark Toughbox Nano. No, it's not as powerful as it could be, but it saves us significant weight that we could then put into the turret and the ball manipulator. Ideal, no, but everything is a tradeoff right :-), that's engineering.
You were right about the Gearmotor in the front, that powers the ball roller.
Thanks for all the nice comments, we're really happy with how the robot turned out this year!
Unread 27-02-2012, 02:32
SpiffyDresser's Avatar
SpiffyDresser SpiffyDresser is offline
AKA: Avery
Team Role: Communications
SpiffyDresser is an unknown quantity at this point
Very cool! If you don't mind me asking, how much success have you guys been getting out of this guy?
Unread 27-02-2012, 20:00
With manual aiming and manual adjusting of the speed of the shooter wheels, we can pretty consistently hit the rim... we are hopping that once our codemonkeys get the camera and shooter wheel encoders working we can tighten that shot group.
As it stands right now we feel its accurate enough to make shooting from the back worth it, but it could definitely stand some improvement if we can squeeze it out of the machine.
Unread 28-02-2012, 18:17
Siri's Avatar
Dare greatly
Good luck everyone!
do'h. Sorry, guys. Looks like you've really got the ultimate robot here! Awesome job.
Unread 04-03-2012, 00:00
logicbomb's Avatar
logicbomb logicbomb is offline
AKA: Matthew Hoerning
FRC #0271 (mechanical mauraders)
logicbomb is an unknown quantity at this point
i was wondering what did you mean when you said your bumpers were illigeal?
