Go to Post Mentor: How is that held in place? CAD Lead: Go to the hardware store and buy a bag of constraints and put the constraints on the robot. - Kenyow [more]
Unread 26-02-2012, 16:24
marccenter's Avatar
marccenter marccenter is offline
FRC #3548 (RoboRavens2)
marccenter has a spectacular aura aboutmarccenter has a spectacular aura about
Question 2012 Driver Station PWM display doesn't work
CD Labview folks,
The Driver Station PWM display doesn't seem to work properly out of the box (base software). Last year I found this display to be very helpful in debugging. Has anyone figured out what the trick is to reenable this feature for 2012?
Marc Center
FIRST FRC Mentor/Coach - Team 3548 Royal Oak RoboRavens#2 - on Sabbatical 2017 season
marc.center@gmail.com
Mobile: 248-255-7377
Unread 26-02-2012, 16:42
Re: 2012 Driver Station PWM display doesn't work
There's a bug on the robot side.
It's defaulting to looking at the second Digital Module.
Joe Ross pointed this out: http://firstforge.wpi.edu/sf/go/artf1439
Open up Build Dashboard Data.vi
Look for the +1 feeding DIO Ref Open and remove it.
Unread 26-02-2012, 19:17
JChavis's Avatar
JChavis JChavis is offline
Team 3490's "Pro./Electrician"
FRC #3490 (Vyper Drive)
JChavis is an unknown quantity at this point
Originally Posted by billbo911 View Post
A picture is worth a 1000 words.
And Just Like that, I got mine to Work Too!!!
Name:	BDD Before.PNG
ID:	12118  Click image for larger version
Name:	BDD After.PNG
Hmmm....I wonder if I can create a robot lawnmower with the knowledge I have gained from FRC.....
Unread 26-02-2012, 19:49
marccenter's Avatar
Smile Re: 2012 Driver Station PWM display doesn't work
CD,
THanks for chiming in, Mark. Will patch my local files to make it work.
THanks also for posting graphic of solution, JChavis
Marc Center
Unread 28-02-2012, 07:39
JChavis's Avatar
Originally Posted by marccenter View Post
CD,
Your Welcome!
Unread 28-02-2012, 09:27
wilsonmw04's Avatar
Coach
FRC #1086 (Blue Cheese)
Having the same problem with the C++ side of things as well. Is the fix the same?
Unread 28-02-2012, 09:37
Nope, the C++ side has no built in Dashboard code. There is a Dashboard example that might help though.
Unread 17-03-2012, 22:01
ConcreteKahuna's Avatar
ConcreteKahuna ConcreteKahuna is offline
AKA: Bryan
FRC #4128 (Singularity)
ConcreteKahuna is an unknown quantity at this point
noobie at labview... can anyone tell me where i can find this vi so i can fix my dashboard?
_______________________________________________
Team 4128 Holmdel NJ
Unread 17-03-2012, 23:20
If you open Robot Main, it is called on the right side of the main loop. Or you can open the Team Code folder in the project window and locate it there.
Greg McKaskle
