Go to Post You have not only joined a robotic competition, you will discover that you are becoming a member of a very large and wonderful family. The more years that you participate, the larger your FIRST family will become. - Car Nack [more]
Unread 26-02-2012, 21:09
matthewdenny's Avatar
matthewdenny matthewdenny is offline
FRC #6054 (Dukes)
matthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant future
Tipped robot
Rookie question here: what happens if a robot get tipped over? Does it get set back up? Is it out? What if one team knocks over another bot on accident? On purpose?
Unread 26-02-2012, 21:11
wireties's Avatar
wireties wireties is offline
Principal Engineer
AKA: Keith Buchanan
Re: Tipped robot
It just stays there till the end of the match. There is a penalty for purposefully doing such things.
Unread 26-02-2012, 21:20
GaryVoshol's Avatar
Cogito ergo arbitro
Re: Tipped robot
The rules allow your alliance partner to try to help you back up. But with only 14" of appendage to work with this year, that possibility seems remote.
Also, your opponents are not allowed to touch you in the first 10 seconds you are down.
In ref training, we were reminded that dead robots can both score points and commit fouls.
(since 2004)
Unread 26-02-2012, 21:22
LeelandS's Avatar
LeelandS LeelandS is offline
Robots don't quit, and neither do I
AKA: Leeland
FRC #1405 (Finney Falcons)
Team Role: Tactician
LeelandS has a reputation beyond reputeLeelandS has a reputation beyond reputeLeelandS has a reputation beyond reputeLeelandS has a reputation beyond reputeLeelandS has a reputation beyond reputeLeelandS has a reputation beyond reputeLeelandS has a reputation beyond reputeLeelandS has a reputation beyond reputeLeelandS has a reputation beyond reputeLeelandS has a reputation beyond reputeLeelandS has a reputation beyond repute
Re: Tipped robot
As wireties said, a tipped robot will be left tipped for the rest of the match, unless it, or another robot, rights itself. I'm guessing the answer you're looking for is, no, the event staff (referees, field techs, etc.) will not right a fallen robot. That would be dangerous.
Intentionally tipping a robot is illegal and will incur fouls (the exact fouls escape my mind now), but accidental tipping is "okay" ("okay" meaning not penalized, though not necessarily a nice thing to do). I believe if it is noticed that a robot repeatedly tips other robots, they may be called for egregious behavior (a yellow card, or a red card for continued occurance).
Hope this helps,
Leeland
My heart will forever lie with SparX
1126: 2008 - 2011; Where it All Began.
1405: 2013 - Present; A Wanderer is Born.
Work hard, play hard. And maybe someday...
Unread 26-02-2012, 21:26
slijin's Avatar
slijin slijin is offline
Pockets
AKA: Samuel Lijin
FRC #0694 (StuyPulse)
Re: Tipped robot
Specifically, a technical foul & yellow card per G26.
Strategies aimed at the destruction or inhibition of Robots via attachment, damage, tipping or entanglement of Robots are not in the spirit of the FRC and are not allowed.
Violation: Technical-Foul plus Yellow Card
Unless the robot itself can re-right itself (if a robot could use its bridge tipper, for instance, to do so) or another robot can help it regain its position, the robot's staying down. Per G30, there is a 10 second grace period following the tip where the opponent isn't allowed to interfere with you.
Fallen (i.e. tipped over) Robots attempting to right themselves (either by themselves or with assistance from an Alliance partner) have one 10-second grace period per fallen Robot in which they may not be contacted by an opposing Robot. This protection lasts for either 10 seconds or until the protected Robots have completed the righting operation, whichever comes first.
Violation: Foul for inadvertent contact; Technical-Foul for obviously intentional contact.
Also take note of G24, which bans intentionally tipping over your own robot.
2010-12 CT Chairman's
2011 Galileo 5th seed
2010 NY Regional Winners
Unread 26-02-2012, 21:27
Andrew Lawrence
Posts: n/a
Re: Tipped robot
To add onto the question: If it's after the 10 second grace period, can you attempt to right an opponent's robot? You know, the whole GP thing.
Unread 26-02-2012, 21:34
GaryVoshol's Avatar
Cogito ergo arbitro
Re: Tipped robot
Nothing specifically disallows that, but you have to watch out for things like contact inside the frame perimeter.
(since 2004)
Unread 27-02-2012, 02:52
remulasce remulasce is offline
remulasce is a splendid one to beholdremulasce is a splendid one to beholdremulasce is a splendid one to beholdremulasce is a splendid one to beholdremulasce is a splendid one to beholdremulasce is a splendid one to beholdremulasce is a splendid one to behold
Re: Tipped robot
Illegal, as per [G27]:
Deliberate or damaging contact with an opponent Robot on or inside its Frame Perimeter is not allowed.
Violation: Technical-Foul and potential Yellow Card
Unless you can right the opponent purely through their bumpers and apendages, the rules disallow this. It's a toss up as to whether the refs would actually call it though. While I think they probably wouldn't let the rules interfere with GP, righting a robot without its owners' consent is not an ok thing to do. You could damage the 'bot even more, especially depending upon the style manipulator you use to do the righting and what you 'determine' is a structural component of their bot. On your own alliance, the fallen can actually talk and direct the righter and stop them if necessary, while no such communication exists among opponents.
Don't do it unless you know for sure everybody's OK with it.
Protip: You'll never know for sure who's OK with it.
Student 294: 2007-2011
Mentor 597: 2013-2015
Google SWE: 2015-
Unread 27-02-2012, 09:27
Chexposito's Avatar
Chexposito Chexposito is offline
AKA: Expo
FRC #1730
Chexposito is a glorious beacon of lightChexposito is a glorious beacon of lightChexposito is a glorious beacon of lightChexposito is a glorious beacon of lightChexposito is a glorious beacon of lightChexposito is a glorious beacon of light
Re: Tipped robot
if your robot does tip, and there's no hope of righting it within the 10 seconds, E-STOP IT not doing so might result in a penalty towards your alliance
Unread 27-02-2012, 09:51
Matt C's Avatar
Matt C Matt C is offline
FRC #1468 (J-Birds)
Matt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond repute
Send a message via AIM to Matt C
Re: Tipped robot
Bad choice. Hitting the E-stop for a non-safety hazard (robot tips over) would likely result in a technical foul.
In seasons past, this would have been acceptable. The rule changed last year I believe, and continued into this year.
[G35]
If a Robot becomes unsafe (e.g. the Robot begins to smoke, the battery falls out, etc.) it may be disabled for the remainder of the Match by any player by pressing the E-Stop button. The E-Stop buttons are intended for remote shutdown in the event of safety hazards and will not otherwise affect Match score or duration.
Violation: Technical-Foul if used for any other reason.
Unread 27-02-2012, 10:37
JohnBoucher JohnBoucher is offline
Blue Shirt
FRC #0237
JohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond repute
Re: Tipped robot
Make sure you ask this question in the drivers meeting.
Unread 27-02-2012, 11:44
FrankJ's Avatar
FrankJ FrankJ is offline
Robot Mentor
FRC #2974 (WALT)
Re: Tipped robot
A good argument can be made that once you give up righting a tipped robot, disabling it is the safe thing to do. So E stopping a tipped over robot should not be against the rules. To my way of thinking, using the e stop should never be almost never penalized. Maybe the actions just prior can carry the heavy penalty to prevent a team from stopping a robot in a critical area. Or a team obviously using the estop solely for an competitive advantage.
Do not confuse my thoughts with official interpretation of the rules.
Unread 27-02-2012, 17:12
PAR_WIG1350's Avatar
AKA: Alan Wells
FRC #1350 (Rambots)
Re: Tipped robot
If you really want to e-stop your robot if it tips over, design it so the battery falls out in such circumstances. Then again, it might fall out at other times too.
Unread 27-02-2012, 17:55
Alex.q Alex.q is offline
FRC #2220 (Blue Twilight)
Alex.q is on a distinguished road
Re: Tipped robot
While there is a penalty for tipping a robot on purpose, a defending bot could still play very aggressive defense that causes the opposing robot to tip. In my experience, refs don't call it intentional very often. The best strategy is to not have a high center of gravity and watch out for getting hit when on bridges or crossing the barrier.
Unread 27-02-2012, 19:25
Siri's Avatar
Siri Siri is offline
Dare greatly
AKA: 1640 coach 2010-2014
FRC #2641 (PCCR; Refs & RIs)
Re: Tipped robot
(No offense is directed at you.) We got red-carded at Champs last year for E-Stopping our robot when we lost driver control and it started visibly deforming a lane divider. Don't E-Stop unless it's obvious and absolutely necessary.
