Go to Post F.I.R.S.T. Troubleshooting Rule #1 - If you work on software, the problem is always with hardware. If you work with hardware, the problem is always with software ;) - Redneck [more]
Unread 26-02-2012, 23:09
Joshuamunson Joshuamunson is offline
FRC #2996
Joshuamunson is an unknown quantity at this point
Distance to RPMs
currently we are using the camera to find the distance to the back boards and have been using encoders to find the RPMs needed at certain distances away.
Is there a way to mathematically and/or programmatically take a table with distances and RPMs to make the robot take any distance to the backboard and automatically give it that set RPM?
Unread 26-02-2012, 23:14
Timz3082 Timz3082 is offline
FRC #3082 (Chicken Bot Pie)
Timz3082 is a jewel in the roughTimz3082 is a jewel in the roughTimz3082 is a jewel in the roughTimz3082 is a jewel in the rough
Re: Distance to RPMs
I would try just manual data logging (good ol pencil and paper) comparing distance value to RPM. Then put that into a spreadsheet or a math site like Geogebra and fit an equation. Then implement that equation into your program!
2011 Record (11-3-0)
Unread 27-02-2012, 00:06
FRC #2996
how would I go about doing that if I have a gap in the 2 RPMs
I have a top shooter wheel and a bottom
the top goes at 300 RPMs slower than the bottom
maybe 2 equations?
Unread 27-02-2012, 00:21
It sounds like you're looking for the Interpolate 1D function. It's in the Mathematics > Interpolation & Extrapolation palette. Give it a pair of arrays for the independent and dependent values, and it will find the appropriate output for a given input.
