Go to Post They already tried that... But here is the thing: it wasn't a bunch of guys in white coats. It was 3 guys: 1 in denim, 1 with a pony-tail, and 1 with a bright colored shirt.... - FIRSTtm134 [more]
Unread 26-02-2012, 23:50
apalrd's Avatar
apalrd apalrd is offline
More Torque!
VRC #3333
Re: PID In-Range Ideas
You combine a check of error with a timer.
The psudocode would be:
int timer = 0; //Make sure you use a signed type to prevent underflow
int delta_t = time_now - time_last; //delta_t is millisecond loop time - in LabVIEW it would be a Tick Count block and a shift register/feedback node to store the last time
if(abs(error) < threshold) timer += delta_t;
else timer -= delta_t;
if(timer <= 0) timer = 0;
if(timer >= threshold) fire();
Kettering Motorsports
