Go to Post My contention is that there is not a whit of difference between noting that a change like that has to be made, and making the change. - Kris Verdeyen [more]
Unread 26-02-2012, 19:56
baronep's Avatar
baronep baronep is offline
Student President
FRC #2848 (Jesuit All-Sparks)
baronep is on a distinguished road
PID In-Range Ideas
Does anyone have any ideas about how to determine if a PID loop has settled out yet? We have our PID loop running relatively well, but I am trying to find a way to sense if the loop has settled out in order to trigger our intake system to shoot the ball. I tried if ERROR < 5 then RUN INTAKE. But it runs momentarily on the overshoot and undershoot. I was able to partially fix this by only allowing it to shoot after 3 seconds, but I feel that there is a better way to do this?
Patrick
Unread 26-02-2012, 19:59
~Cory~'s Avatar
~Cory~ ~Cory~ is offline
Student
AKA: Cory Rypkema
FRC #0706
~Cory~ is a splendid one to behold~Cory~ is a splendid one to behold~Cory~ is a splendid one to behold~Cory~ is a splendid one to behold~Cory~ is a splendid one to behold~Cory~ is a splendid one to behold~Cory~ is a splendid one to behold
Re: PID In-Range Ideas
We accomplished by averaging. If the average was in range, then fire.
corin.rypkema.org
WPI Class of '17
'12 Dean's List Finalist, Mentor of 706 - Cyberhawks
Unread 26-02-2012, 20:41
baronep's Avatar
Student President
Is there a VI that will do averaging for you? If not, how do you do it?
Unread 26-02-2012, 23:50
apalrd's Avatar
apalrd apalrd is offline
More Torque!
VRC #3333
You combine a check of error with a timer.
The psudocode would be:
int timer = 0; //Make sure you use a signed type to prevent underflow
int delta_t = time_now - time_last; //delta_t is millisecond loop time - in LabVIEW it would be a Tick Count block and a shift register/feedback node to store the last time
if(abs(error) < threshold) timer += delta_t;
else timer -= delta_t;
if(timer <= 0) timer = 0;
if(timer >= threshold) fire();
Kettering Motorsports
