Re: Team 16, Baxter Bomb Squad, 2012
We decided to go short, so we went short. No trouble shooting over taller robots. The camera is mounted a little higher up. The "packaging" of the 119.7 lbs. was pretty intense.
We have 4 wheel modules - we went with 4 in 2011 and really liked the performance. It makes it a bit harder to manage the weight. We have made some significant changes to our driving capabilities; Austin will have his hands full with all the driving modes. |
That robot is 119.7 lbs? That sounds impressively compact.
I'd love to get background on your design process for this season or the decision making that went into the launcher. Definitely was something unexpected from you folks.
Digging the drive as usual, and your driver's slalom looks impeccable. |
Love the catapult, love the swerve, heck... love everything
![]() What is your control layout? We tried swerve last year but had difficulties creating an intuitive control system. |
If you mean OI: we use a steering wheel and single joystick. The joystick buttons change modes. Not sure if it is intuitive - it is what our current driver prefers. There are about 8 modes this year...he may not prefer it after that!
As for a steering wheel, that's a good idea. Thanks. Good luck this year ![]() |
#7
.Nice 'bot! |
#8
We have hard stops for different shooting positions and a load cell to measure the force before firing. The driver better be impeccable. No pressure, Austin... |
#9
Expect nothing less from an original team!
Good job pulling off a swerve robust enough to go over the bump! Since we're consider swerve next year, I'd love to get a closer look at that thing. Aren't you scared of using surgical tubing to power your catapult though? If either end ever snapped, calibration sounds pretty painful. Unless your load sensor somehow can adjust to compensate? |
#10
And surgical tubing has been very good to us. We are sponsored by a medical plastics manufacturer... ![]() |
#11
Awesome robot! I've been waiting for this one all year!
Only question I have is: What is your reasoning behind the catapult? I know earlier you said wheeled shooters were getting "boring", but what was the tactical advantage you thought it gave you? Just curious. Thanks a bunch for sharing this! I can't wait to watch the webcast! |
#12
What is a "load cell" and how does it compensate for tubing and belt stretch?
#13
A load cell measures force. In this case the force the catapult is applying to the winch. Surgical tubing will relax when it is stretched for an amount of time. We use the load cell to quantify that relaxation and account for it to make our catapult more consistent.
#14
Would you be willing to share your design for the winch, belt and release mechanism for your catapult?
Our mechanism (cam that grabs a bar attached to catapult) is not as effective as we thought it would be. Our original linear catapult was scrapped because of weight and consistency problems, so we are scrambling to get a traditional one working. |
#15
Our original design was based on the Andymark dog shifter design. We bought all the parts individually and built the winch around that. We machined a pulley which rides on bearings and fastened the gear with the dog to it. this is driven by the dog which in turn is driven by a 26:50 gear drive from two window motors. In 2010 we used a fisher price driven dewalt transmission with locking pins. This year the window motor gearboxes are preventing backdriving.
Since the shifter was not designed to work with the load of surgical tubing we have, We had to use a much larger cylinder than the original design called for. This put a lot of stress on the pin holding the dog and it broke often. We fixed that by limiting the stroke so it never put full pressure on the pin. The belt we use is standard Gates 9mm GT2. It has held up better than the cable we first used. I don't have the inventor drawings but they exist. I can give you the part numbers for the shifter parts too if you need them. Our current design is totally fabricated here and includes some EDM work. It may be too difficult to pull off fast. |
