Go to Post Mentors need to be sure that the team is on track to have a working robot ready. Students can do almost everything, but they need help watching the calender. Even if your ideas turn out bad, if your robot is inspectable and running when you arrive at your first event, anything can happen. - AcesPease [more]
Unread 27-02-2012, 11:19
Originally Posted by dbeckwith View Post
Try just using the Encoder class. That should have everything you need.
The AS5030 is not a quaderature encoder. It won't work with the encoder class.
