Go to Post The code is hopefully pretty self-documenting, but I haven't had time to comment it (kinda trying to build a robot at the moment). - RyanCahoon [more]
Unread 27-02-2012, 12:55
lauraleeane's Avatar
lauraleeane lauraleeane is offline
Co-Captain
FRC #0771 (SWAT)
lauraleeane is an unknown quantity at this point
Re: Banebot Gearbox no longer working
Originally Posted by Akash Rastogi View Post
Steps for using banebots gearboxes:
1: Grease your internals and assemble
2: Run your gearbox for about 15-20 minutes. Or in 10 minute periods
3: Disassemble
4: Clean
5: Re-grease but do NOT overgrease. White lithium may be a little too thick so I usually just scoop some grease from FP gearboxes and drop it into the banebots gearboxes.
6: You should be good to go
Gear dust + thick grease without going through this process will bind up your 16:1 gearbox.
Is it bad that I am using white lithium grease? It's the only grease my team has. And do we need to disassemble the gearbox so often?
