Go to Post Rule 1. Never take Dave's hint's seriously. Rule 2. Watergame. - AndyB [more]
Unread 27-02-2012, 20:11
DominickC DominickC is offline
FRC #0023 (PNTA)
Rookie Year: 1620
DominickC is an unknown quantity at this point
Re: Team Fusion 364 2012 Code
Wow! Your code is quite professional and certainly highly sophisticated at first glance. I'll be taking a closer look tonight and seeing if I can't learn anything from it!
Unread 29-02-2012, 15:08
Doc Wu's Avatar
Doc Wu Doc Wu is offline
AKA: Al Gritzmacher
FRC #1507 (Warlocks)
Doc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant future
Very impressive code. I'm hoping to learn a lot from it.
You use a lot of flat sequences in both begin.vi and teleop.vi. They are single frames that seem to group subsystems together and make the code very easy to read, but is there more to them than that? Why not just a decorative frame? Or do you want each subsystem to execute together?
Our teleop.vi, for example and most others I've seen, are just one big mess of code.
I'd be interested to hear your reasons behind this.
-= Mentor Lockport Warlocks -=- Team 1507 =-
Amateur Radio Callsign: AE2T
2016 Robot Inspector - Fingerlakes, Pittsburgh
2015 Robot Inspector - Pittsburgh, Champs. Judge Observer - Champs
2014 Robot Inspector - Tech Valley, Fingerlakes, Buckeye, Championship
2013 Robot Inspector - Fingerlakes, Buckeye, Championship
2012 Robot Inspector - Fingerlakes, Buckeye, Championship - Website Evaluator - Fingerlakes, Buckeye, Championship
2011 Robot Inspector - Fingerlakes 2011 Safety Advisor - Fingerlakes
Unread 29-02-2012, 19:16
RyanN's Avatar
RyanN RyanN is offline
RyanN
AKA: Ryan Nazaretian
FRC #4901 (Garnet Squadron)
The flat sequences serve no purpose other than to just separate subsystems, which could be done with decorative frames. I generally don't like using decorative frames as they aren't as modular as the flat sequence. I can simply click and drag flat sequences to move them. Nothing wrong with using decorative blocks though. It probably adds a little overhead, but it's not much.
Garnet Squadron
FRC 4901
Controls Mentor
@rnazaretian
Previous mentor and student from Team Fusion, FRC 364
Unread 29-02-2012, 19:35
plnyyanks's Avatar
Data wins arguments.
AKA: Phil Lopreiato
I'm impressed with your code. It looks really well done (and well documented, which is almost as important). Kudos to your team for some nice software. One question: in your autonomous, was there any reason for using a bunch of sequential while loops instead of using a state machine(s)? Maybe it's just me, but I tend to prefer state machines for this kind of thing - we have many in our code....
Unread 01-03-2012, 00:18
RyanN's Avatar
RyanN
The student that did it went off of the demo autonomous code. It's in multiple while loops because of the safety configuration for the drive motors. If a value is not fed within 100ms, the motors will cut off. Since we're driving the motors for longer than 100ms in each pass, the motors would error out and cease to work. It's easier to see sequentially like the way it's done. State machines are often hard to follow in LabVIEW since they will most likely involve a case structure, which will hide code from you.
He could have just disabled the safety config on it, but in the long run, it doesn't matter either way.
Garnet Squadron
FRC 4901
Controls Mentor
@rnazaretian
