Go to Post I GET that FIRST is about more than winning on the field. BUT... ...it is my experience that the great programs of the FIRST world almost always build on a foundation of competitive robots. Success on the field begets success in other realms. - Joe Johnson [more]
Unread 25-02-2012, 19:40
cooltext cooltext is offline
FRC #0835
cooltext is an unknown quantity at this point
RPM calculator
I have the AS5030 rotary encoders and I was trying to find a way to calculate the RPM of our shooter motors with it. Does any one have any idea how to do so? I tried the counter class but I am having trouble selecting the
  AnalogTriggerOutput.Type triggerType
to use and how to calculate what voltage limits I should use for kTypeState.
Also how could I make it so it had a very small sampling time like .1 of a second?
Unread 27-02-2012, 09:31
dbeckwith's Avatar
dbeckwith dbeckwith is offline
Lead Programmer
AKA: Daniel Beckwith
FRC #3205 (The Patriots)
dbeckwith is an unknown quantity at this point
Re: RPM calculator
Try just using the Encoder class. That should have everything you need. Just make sure you use setDistancePerPulse() with the right units and you can get the speed (this class gives speeds in units per second, not minute, but you can always scale it).
q = (2*b) | ~(2*b);
if (life.getLemons() != null) this.lemonade = new Drink(life.getLemons());
else throw new NoLemonsException("What now?");
Unread 27-02-2012, 11:19
The AS5030 is not a quaderature encoder. It won't work with the encoder class.
Unread 27-02-2012, 17:02
joelg236 joelg236 is offline
4334 Retired Mentor & Alumni
AKA: Joel Gallant
joelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond repute
Re: RPM calculator
And what would you suggest then? That was not helpful.
Unread 27-02-2012, 17:45
Re: RPM calculator
Well, it helped him avoid wasting time going down a rabbit hole.
A bit of advice, if you are open to it: as a newcomer you might want to be a bit more respectful, especially with people like Joe who have helped countless people over the past 10 years.
Unread 27-02-2012, 20:17
FRC #0835
Re: RPM calculator
Thanks for your replies, but I was just wondering if anyone had any ideas for the RPM issue?
thanks
Dimitir
Unread 28-02-2012, 10:37
Re: RPM calculator
You could try opening the P1 solder bridge and connecting the JP3-1 Cos signal to DIO and use the Counter class. Not sure if that would work. Has anyone tried it?
Or you could use a sensor more suited to your purpose.
Unread 28-02-2012, 11:39
ProgrammerMatt ProgrammerMatt is offline
Programmer-Electrical-Mechanical
FRC #0228 (Gus)
ProgrammerMatt is just really niceProgrammerMatt is just really niceProgrammerMatt is just really niceProgrammerMatt is just really nice
Re: RPM calculator
The encoder class works with both i belive..
if so
Encoder myencoder = new Encoder(#);
myencoder.getRate();
the the rate works off ticks per secound you need to scale it down.
Unread 28-02-2012, 16:41
dbeckwith's Avatar
Lead Programmer
Re: RPM calculator
if so
No, I think Joe is right. The Encoder class is for quadrature encoders which use two signals, and this encoder the OP is trying to use only has one signal and if I'm not mistaken produces a different type of signal (the way it counts rotation is different). It's unfortunate that there's no built-in FRC class for those encoders though.
q = (2*b) | ~(2*b);
Unread 28-02-2012, 16:57
Re: RPM calculator
According to the operation manual for the AS5030 adapter board, if you open the P1 solder bridge you can access cos&sin quadrature signals at JP3 pins 1&3. Not sure if the WPILib Encoder class will work with those waveforms without some signal conditioning. Has anyone tried and succeeded?
Unread 28-02-2012, 20:04
Re: RPM calculator
Apparently someone has tried it, and was successful. See Post#3 in this thread:
https://decibel.ni.com/content/thread/11955
Unread 28-02-2012, 23:00
FRC #0228 (Gus)
Re: RPM calculator
Does it output analog or digital? if its digital try using the Counter class, if its analog then use something like
int count
if(encoder.getVoltage() >"voltage when ticked") {
count = count + 1; // or count ++;
P.S i would think it is digital but if its not try that /\
Unread 28-02-2012, 23:09
mwtidd's Avatar
mwtidd mwtidd is offline
AKA: mike
FRC #0319 (Big Bad Bob)
Re: RPM calculator
Get rate is not ideal.
We store a last time variable.
Take counter.getdistance / (current time - last time)
Then reset the counter.
You will get a much stabler speed this way
Unread 01-03-2012, 17:30
FRC #0228 (Gus)
Re: RPM calculator
this is straight out of the encoder class
     * Get the current rate of the encoder.
     * Units are distance per second as scaled by the value from setDistancePerPulse().
its practically the same as current time - last time
Unread 01-03-2012, 19:34
Re: RPM calculator
...its practically the same as current time - last time
GetRate() computes the rate based on the elapsed time of a single encoder pulse (the most recent one).
This is manifestly not the same as the computing the rate using delta counts since the last sample and dividing by the elapsed time since the last sample, for sample periods on the order of 20ms and encoder pulse periods associated with shooter wheel speeds.
