Go to Post -Our engineering mentor, Mr. Wittel- *crossing arms and sitting down* "Ahhh. I love work. I could watch it all day." - OverdriveAdge [more]
Unread 27-02-2012, 20:33
DominickC DominickC is offline
FRC #0023 (PNTA)
Rookie Year: 1620
DominickC is an unknown quantity at this point
Feedback Nodes?
Hello -
I've seen people use Feedback Nodes in their code when dealing with State Machines, however I've never quite understood them. I've researched them and read help files on them, but I'm still a bit lost. Any help/clarification?
Thanks, Dom
Unread 27-02-2012, 21:18
Re: Feedback Nodes?
Feedback nodes are simple. They have an input and an output. The value that comes out of the output is the value that went into the input the previous time the feedback node executed.
Unread 27-02-2012, 21:21
FRC #0023 (PNTA)
Rookie Year: 1620
Re: Feedback Nodes?
Ah, simple enough. Then, what does the "Initializer Terminal" do?
Unread 27-02-2012, 21:25
AKA: Lars Kamen's Roadie
FRC #0051 (Wings of Fire)
Re: Feedback Nodes?
Since it uses the value from the last time it was executed, what is the output the FIRST time it is executed? (answer: it's the value that you put in as the "Initializer Terminal".)
Unread 27-02-2012, 21:26
FRC #0023 (PNTA)
Rookie Year: 1620
Re: Feedback Nodes?
Awesome, thanks!
Unread 27-02-2012, 21:42
Re: Feedback Nodes?
The first time a Feedback Node runs, it won't have seen an input value yet, so it uses the value wired to its Initializer Terminal as its first output. If you leave that terminal unwired, the first output will be the default value for whatever type is connected to the input.
LabVIEW's help features can tell you all this. If you have contextual help turned on (toggle it with control-H), you can hover the mouse cursor over anything and get useful information in the Help window. There's usually a link to Detailed help at the end of the brief description.
