Go to Post By the way, safety glasses are so in style now, :) - LightWaves1636 [more]
Unread 27-02-2012, 22:04
nitneylion452's Avatar
AKA: Joe Lee
Re: cRio-FRC in BOM
Originally Posted by RufflesRidge View Post
A careful reading of R13-A should solve your problem
Emphasis mine
The cRIO-FRC was on last year's checklist in quantity 1 so you're all set and can document the cost as $0.
But it's not listed on this year's, so there is no quantity of it that we would be permitted to use. That rule is in place to allow teams to use old parts from previous robots without having to count for the cost of some. For example, we have 4 cims on our bot but none of them are from this year's kit, but since 2 are included, we can write 2 of them off as kop and not have to include the cost of 2 of the 4 motors.
EDIT:
Originally Posted by Kevin Sevcik View Post
Hrm. You're correct that it should technically be costed since it's not in the 2012 KoP nor listed as an explicit exception. Practically speaking, it's a simple oversight by the GDC, since they didn't mandate the FRCII and they're not about to make about a thousand veteran bots illegal.
Definitely needs to be Q&A'd. If you can't/won't, then I will. Whoever does should point out that any exception written for it should exclude the possibility of a team using both an FRC and FRCII for free. (Someone totally would.)
I don't have access to Q&A, so your asking would be ideal.
Joe
"The ones who will one day rule the world rule the basketball court today."
http://www.fatherjudgerobotics.webs.com
Volunteer 2012 MAR Region Championship - Field Reset
Volunteer 2013 MAR Region Championship - Field Reset
