Go to Post Words mean what words mean. If your robot is sitting on the ball, then by definition it is not hanging from the bar. NO 50 point bonus. - dlavery [more]
Unread 24-02-2012, 17:24
Supernovapsy Supernovapsy is offline
FRC #1334
Supernovapsy is an unknown quantity at this point
Errors when running
Hi,
Our code uses the command based robot template, and builds and downloads with no problems. However, there is an error message that comes in waves through the console, and sometimes creates lag issues. It looks like this:
Assertion failed: "(rawValue >= GetMinNegativePwn()) && (rawValue <= GetMaxPositivePwn())" in SetSpeed() in C://WindRiver/workspace/WPILib/PWM.cpp at line 241
This message then repeats itself a bunch of times and then stops, and comes back again sometime later.
When it happens, it often creates lag, which might be detrimental when it comes to the competition. Any help would be greatly appreciated.
Unread 27-02-2012, 07:57
frdrake frdrake is offline
FRC #0233
frdrake is on a distinguished road
Re: Errors when running
What's the rest of that statement? Are you calling an ASSERT? Without seeing the entire command one can only guess what the issue may be.
Unread 27-02-2012, 16:07
FRC #1334
The errors happen in the console, and no where in our code do we use anything directly from a PWM class. I'm thinking somehow, the jaguars and victors are causing it. Do you want me to post code that operates on those objects?
Unread 28-02-2012, 08:57
FRC #0233
I'm sure you include WPILib and by extension you are also including the PWM.cpp. I bet if you look in the PWM.cpp file at the line specified there will be an assertion of some kind made by that code that is then failing and that's why you're getting this error. I'm at work and don't have the libraries in front of me to try and find it myself. Some part of your inputs the PWM doesn't like.
Unread 28-02-2012, 11:01
rbmj rbmj is offline
FRC #0612 (Chantilly Robotics)
rbmj is a jewel in the roughrbmj is a jewel in the roughrbmj is a jewel in the rough
 * Set the PWM value based on a speed.
 * This is intended to be used by speed controllers.
 * @pre SetMaxPositivePwm() called.
 * @pre SetMinPositivePwm() called.
 * @pre SetCenterPwm() called.
 * @pre SetMaxNegativePwm() called.
 * @pre SetMinNegativePwm() called.
 * @param speed The speed to set the speed controller between -1.0 and 1.0.
void PWM::SetSpeed(float speed)
	if (StatusIsFatal()) return;
	// clamp speed to be in the range 1.0 >= speed >= -1.0
	if (speed < -1.0)
		speed = -1.0;
	else if (speed > 1.0)
		speed = 1.0;
	// calculate the desired output pwm value by scaling the speed appropriately
	INT32 rawValue;
	if (speed == 0.0)
		rawValue = GetCenterPwm();
	else if (speed > 0.0)
		rawValue = (INT32)(speed * ((float)GetPositiveScaleFactor()) +
									((float) GetMinPositivePwm()) + 0.5);
	else
		rawValue = (INT32)(speed * ((float)GetNegativeScaleFactor()) +
									((float) GetMaxNegativePwm()) + 0.5);
	// the above should result in a pwm_value in the valid range
	wpi_assert((rawValue >= GetMinNegativePwm()) && (rawValue <= GetMaxPositivePwm()));
	wpi_assert(rawValue != kPwmDisabled);
	// send the computed pwm value to the FPGA
	SetRaw((UINT8)rawValue);
What speed are you calling the function with (or some object that calls the function). If it's not x|-1.0<=x<=1.0 then that might be the cause of your issues.
Edit: The assert that's failing is the second-to-last assert
Unread 01-03-2012, 15:53
FRC #1334
Thanks!
I looked through the code again, and I found a place where I divide the driver input value by itself. This gives NaN when the values are 0, and this created the assertion error.
Thank you everyone, I appreciate everyone's help!
