Go to Post What is this sleep you all speak of...if it wasn't in the KOP than it is not allowed to be used :D - Wayne Doenges [more]
Unread 28-02-2012, 09:28
Andrew Lawrence
Posts: n/a
Re: Robot Tyco Drummer?
You gotta think a little outside the humanoid thing. Maybe instead of arms, it has a few pneumatic cylinders over the drums that extend and retract to hit the drum and play it. Not only would it be fast, but you'll get a pretty repeatable sound each time, and it's much simpler than any arm you'd need to build.
Unread 28-02-2012, 09:31
dbeckwith's Avatar
dbeckwith dbeckwith is offline
Lead Programmer
AKA: Daniel Beckwith
FRC #3205 (The Patriots)
dbeckwith is an unknown quantity at this point
That would be simpler certainly, but I was thinking it would be cooler to have a humanoid one, not to mention more of a challenge.
q = (2*b) | ~(2*b);
if (life.getLemons() != null) this.lemonade = new Drink(life.getLemons());
else throw new NoLemonsException("What now?");
Unread 28-02-2012, 09:37
Andrew Lawrence
Posts: n/a
True, but then you have to deal with encoders, more sensors, and more variables. A suggestion of mine is to look at Team Titanium's Guitar Hero Robot, and see how it used pneumatics to play guitar hero, but still looks like a human.
Unread 28-02-2012, 16:37
dbeckwith's Avatar
Lead Programmer
WOW! That's an awesome robot!
q = (2*b) | ~(2*b);
Unread 28-02-2012, 17:04
ThaineP
Posts: n/a
A taiko drummer robot would be pretty cool. Will it have to play alongside humans and in time?
Unread 28-02-2012, 17:39
dbeckwith's Avatar
Lead Programmer
I didn't intend for that, but that could be an added functionality. It could "listen" to the other drummers and attempt to keep the same tempo!
q = (2*b) | ~(2*b);
Unread 28-02-2012, 17:52
jason701802's Avatar
jason701802 jason701802 is offline
FRC #0753 (The High Desert Droids)
jason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant future
I would recommend using moving the drum sticks in the same manner as the 'fingers' on the Guitar Hero 'bot. I don't think you'll need a flexible mount (as long as you properly tune the maximum position of the drumstick), but you could use some sort of rubber mount for the drumstick(s) to get some flex.
It doesn't look to me like it uses pneumatics to me, I see electromagnetic solenoids.
Jason
