Go to Post Attempted to like Andrew's comment and then realized this wasn't Facebook :P - afowl [more]
Unread 28-02-2012, 00:37
Luiz12 Luiz12 is offline
FRC #4210
Luiz12 is an unknown quantity at this point
Gyro Autobalancing
Hi this is our first year in this competition and as a rookie programmer I've attempted to write a could to auto balance my robot. Now I may be completely wrong but I was wondering if I did anything right or this could even work when I'm on the bridge.
Unread 28-02-2012, 00:55
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
Re: Gyro Autobalancing
You've got the right idea, but the implementation needs some work.
First - never set motors inside if/then's like that. The motor set should be outside, over to the right of everything. You should only have 1 of any particular motor set in teleop. This helps to avoid potential race issues.
Next, your case structures should be nested inside one another. This is good coding practice, and helps to avoid extra calculations. There's no reason to check one if the other is true....
Next, you'll find this will oscillate around your setpoint. Mechanical systems have momentum, and once it starts moving it won't stop immediately. It will drive back and forth over your setpoint (probably quite wildly with a motor value of .75!).
I suggested reading some papers on PID's. That's what you need to implement here.
Unread 28-02-2012, 01:02
FRC #4210
I have tried to read on PID's but I simply do not understand them since they dont really provide a practical example for what I what. This would all go in my Periodic Tasks.vi and well well I just put the left and right ref get was just so you could see what I'm trying to do. I set it to .75 to limit the speed a bit but I'm not sure if thats correct.
Unread 28-02-2012, 01:50
Ziv Ziv is offline
Has code to be writing...
FRC #0125 (Nutrons)
Ziv is a glorious beacon of lightZiv is a glorious beacon of lightZiv is a glorious beacon of lightZiv is a glorious beacon of lightZiv is a glorious beacon of light
Is the difficulty you're having to do with understanding how a PID loop works or understanding how to implement one? Many resources you can find online—especially on this very forum—are great at explaining the former, but details on the latter can be harder to find. I haven't programmed a robot in LabVIEW for a few years, but if I recall correctly there are PID VIs that you can put in your code that do most of the work for you; they just need tuning of the constants. Some FRC teams—including some that use LabVIEW—post their previous years' code here; reading examples is a great way to learn.
A few other things to watch out for:
-As Tom mentioned, nest the case structures and make them manipulate numbers that feed into a single motor command (not just here but anywhere you have motor output).
-The gyro will in practice never give exactly 0; your code as above relies on that to stop the drivetrain from moving.
-If your gyro angle is, say, –20, I don't know if the remainder operation will output –20 or 340. Unless your robot does a somersault (which for all I know might be crucial to your strategy ), the gyro you use for bridge balancing will never be out of the range [–90, 90], so you should be fine without taking the remainder.
Unread 28-02-2012, 02:47
FRC #4210
So from what I understand is that I have to have a set point, which I assume would be zero since when the angle reaches zero thats when I want it to stop. My process variable would be the angle output of the sensor, and well the output would go to my tank drive vi. and basically from what I've read the only thing that I would need to tune would be the proportional gain. Heres what I came up with.
Unread 28-02-2012, 07:24
dbeckwith's Avatar
dbeckwith dbeckwith is offline
Lead Programmer
AKA: Daniel Beckwith
FRC #3205 (The Patriots)
dbeckwith is an unknown quantity at this point
Not to discourage you or anything, but has anyone actually tried this and gotten it to work? My team tried using it at first, but we realized that automatic PID control could never be as good as human prediction. I think the problem with auto-balancing is that PID is completely reactive. In order to be able to balance successfully, a human driver needs to be able to pretty accurately predict how the bridge will react to the robot moving and adjust accordingly. If you can get this to work, great, but I feel the problem may be more complicated than just using PID and human control will always be better.
q = (2*b) | ~(2*b);
if (life.getLemons() != null) this.lemonade = new Drink(life.getLemons());
else throw new NoLemonsException("What now?");
Unread 28-02-2012, 08:13
fsgond's Avatar
fsgond fsgond is offline
Why aren't you throwing balls?!
AKA: Anthony
FRC #5484 (Memento Vitam)
fsgond has a brilliant futurefsgond has a brilliant futurefsgond has a brilliant futurefsgond has a brilliant futurefsgond has a brilliant futurefsgond has a brilliant futurefsgond has a brilliant futurefsgond has a brilliant futurefsgond has a brilliant futurefsgond has a brilliant futurefsgond has a brilliant future
Team 135 was able to get this to work quite well with PID control. I do not have access to the code right now or I would post it. We found that the robot could balance in about half the time than the human could. You are definitely on to something and you should not be discouraged. FIRST is all about figuring out problems that you never thought you would come across. If I am in our shop in the next few days, I will try to get a screen shot of how we are doing it.
Anthony Rubio
Co-Coach, Memento Vitam Team 5484, 2015-????
Mentor, Black Knights Team 135, 2009-2015
Student, Black Knights Team 135, 2007-2008
Unread 28-02-2012, 08:24
45Auto's Avatar
45Auto 45Auto is offline
FRC #2992
45Auto has a brilliant future45Auto has a brilliant future45Auto has a brilliant future45Auto has a brilliant future45Auto has a brilliant future45Auto has a brilliant future45Auto has a brilliant future45Auto has a brilliant future45Auto has a brilliant future45Auto has a brilliant future45Auto has a brilliant future
It's been done repeatedly for many years on problems much more difficult than this year's FIRST challenge. (Ask Dean Kamen about something called a "Segway"). You have a bridge that will balance if the CG is located within about a 6" band between the hinges.
You may want to do a little more research. The only thing the current problem requires is a quick reaction time. Human reactions will never come close to machine reactions - judgement is a different subject!
Try something like either of these under human control if you think you can:
http://www.youtube.com/watch?v=bI06lujiD7E
http://www.youtube.com/watch?v=IH4EZ1GCrK0
2007 - Rookie All Star - Bayou Regional (1858 - Tyborgs)
2009 - Rookie All Star - Bayou Regional (2992 -Prometheus)
2010 - Champions - Bayou Regional (2992 -Prometheus)
2012 - Finalist - Bayou Regional (2992 - Prometheus)
team2992.com/design.php
Unread 28-02-2012, 08:57
dbeckwith's Avatar
Lead Programmer
If other teams have done it, I stand corrected, but I guess what I really was getting at was that these robots that we're developing in FIRST (or at least our team's) aren't ideal for balancing. Our robot's center of gravity is not in the very center since we never really had time to fine-tune that. Those robots in those videos are small and light and built specifically for balancing, and the Segway especially is built to have perfect balance. I guess what I really meant was that in the time frame we had for coding and tweaking, we realized we wouldn't be able to develop something that was better at balancing than the human driver. Although it is true that the design of the bridges makes it slightly easier than if they were just balanced on a single fulcrum. Also we had a weird issue with the gyro itself, but that's a separate problem.
fsgond, I'd love to see your code for the PID. My team is new to PID, we only started using it this year and we don't really know much about how to use it or especially how to tweak it to get optimal coefficients.
q = (2*b) | ~(2*b);
Unread 28-02-2012, 09:35
Chris_Elston's Avatar
Chris_Elston Chris_Elston is offline
Controls Engineer
AKA: chakorules
FRC #1501 (Team THRUST)
Chris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond repute
I always go back to the basics on controls questions.
Your control loop is only as good as your sensor feedback.
Have you tried to see what a single Gyro input does when you are using the get angle in Labview? Did you notice that the gyro drifts over time, 1-10 degrees? Because of this drift problem, your PID will always be seeking "ZERO" if that is your set point, but your gyro is reporting the wrong angle in relation to your robot.
Study the sensor first, and determine if it's responsive enough, and "accurate" for your controls loop. Always do that first to prove that to yourself, before writing the first bit of code. Turns out, you can use labview to study the raw data from the sensor to determine it's response, and accuracy over time. You “could” reset the gyro before you visit the ramp, but try mounting the gyro on the robot and flipping the ramp back and forth about 3-4 times, then make the ramp go back to level, does your gyro raw data still read 0 degrees after just a few iteration of tilt cycles? If not, your control loop won't work either because your sensor data is mis-reporting due to gyro drift of integrating an angle from the gyro rate.
Spend some time on getting accurate sensor feedback, before moving to control loops is what I am suggesting.
Bottom line, the problem may not be your control loop, but because your sensor is mis-reporting, has noise, is effected by another axial movement, such as acceleration of the robot, etc…
Team T.H.R.U.S.T. 1501
Download all of our past robot's source code here:Repository
Favorite CD quote:
"That can't be their 'bot. not nearly enough (if any) rivets to be a 1501 machine." ~RogerR: Team #1369
Unread 28-02-2012, 10:04
fsgond's Avatar
AKA: Anthony
Chris brings up a good point with this. You will need to reset your gyro to zero quite often. It was very frustrating during the initial coding to have to constantly reset it. As it stands not we will need to zero our gyro seconds before we attempt to balance to assure that it is close enough to achieve the feat.
Anthony Rubio
Unread 28-02-2012, 10:21
FRC #4210
Well we tried to balance it using human control but we realized that its to top heavy an its proned to tip. But other than the obvious points that i will need to constantly reset it, is the code sound? I know that the robot will never be exactly at zero but i assume the accerlation will be low enough that it wont move as it gets close to zero..
Unread 28-02-2012, 11:19
engunneer's Avatar
Alumni turned Mentor
AKA: Branden Gunn
FRC #4761
PID does not always need to be reactive. In general terms, there is a further thing you can add called FeedForward, which you can apply to either velocity or acceleration, as the case may be. The basic idea with Feedforward is that you know you'll be moving in a certain direction anyway, so give a little boost to your velocity or acceleration, then let the rest of PID react once you get going.
I've taught PID to quite a range of people. I really ought to do a youtube video, so i don't have to perform it as much.
The basic idea for PID is that it corrects for errors. if you make a PID loop based on position, it will move your motors such that the position is what you want. you can replace the word position with the words velocity, angle, and even acceleration or motor current. you can also loop multiple parts of your motion. (i.e. Loop position and velocity), but for FIRST, you usually only need to put a loop around one thing.
Let's use position for discussion, which is easiest to visualize. First, you need a way to measure your position (an encoder can be used for position or velocity, the gyro or an accelerometer can measure angular data.). The difference between the position you are in, and the position you want to be in, is your error. PID acts on this error to try and make it 0.
In a typical machine tool (like a CNC machine (Hey look, FIRST applies to the real world )), you want to position an axis. Say the axis is currently at zero, and you want to move it a meter. Your commanded position is 1m, and your actual is 0m, making your error +1m. (The sign is important!). Proportional Gain is a number we multiply by the error to get a motor command. Sometimes this is a speed (engineering unis such as m/s), or in our case, it is a motor command in the range of -1 to +1. Let's say our proportional gain is 0.5. 0.5(gain)*1m(error) = 0.5(command), which moves our motor towards where it is supposed to go.
For the sake of discussion, let's say our motor is geared such that a command of 1 means the mechanism in question is moving at 1m/s. That is also the top speed of the motion, since the command cannot be greater than 1.
PID loops execute repeatedly in your Periodic tasks, so they occur with a fixed time base. To demonstrate, I've put this together as an excel worksheet, and posted it to my blog. The sheet lets you play with some different PID settings, and lets you look at how the mechanism will move based on the commanded velocity.
I finish the discussion of PID there. (That post is based on this one)
Simulating the bridge in excel is a bit harder, since you need to keep track of the CG of the bridge and everything on it, and use that (as well as inertia) to model the bridge actual angle. The basic PID concepts follow along, but the response of the bridge is not a 1:1 relationship with what you command for motor velocity.
Unread 28-02-2012, 15:10
DominickC DominickC is offline
FRC #0023 (PNTA)
Rookie Year: 1620
DominickC is an unknown quantity at this point
I believe you'll find that once you get to competition, bridge balancing is going to be quite easier to be handled manually by the drivers to compensate for inconsistencies like the number of bots on the bridge and so on. Since the bridges are calibrated with springs to return to 0 degrees, they are pretty easy to balance on.
If you still want to try a form of software balancing, more power to you. I did mine similar to how you did yours the first time around. The way you wrote your code the first time was pretty good, but just needs a few changes.
Since the bridges are considered balanced if they are within 15 degrees either way of 0, you don't need to be directly at 0 degrees, nor would the Gyro be accurate enough to bring you to 0 degrees exactly. I'd say < 3.5 and > 3.5 to give a 7 degree drift.
I'm not sure how your bot's drive train works, but 0.75 is quite speedy for ours. You might consider telling your drivers to drive up onto the ramp fully THEN engage the auto-balancing code, which may allow you to use slower motor outputs, leading to a more accurate balance.
As someone else suggested, you should nestle your case structures. If the < 3.5 case structure is false, check to see if it's > 3.5. If that's false too, set the motor outputs to 0.
Dom
Unread 28-02-2012, 15:28
Tom Line's Avatar
Dom
I was not aware that the competition bridges are calibrated with springs. I was under the impression that they use their own considerable weight and the off-center position of their hinges to effect their self centering. Can you please point me to the documentation that led you to this conclusion?
In addition, I believed that the bridges needed to be within 5 degrees of level to be balanced. Where did the 15 degrees come from? That is a considerable angle.
