Go to Post Even if this is the Rumor Mill, there are behaviors that need to be adhered to. - meaubry [more]
Unread 05-01-2003, 12:17
cbudrecki's Avatar
cbudrecki cbudrecki is offline
AKA: Carl Budrecki (buh-dre'-key)
FRC #0222 (Tigertrons)
cbudrecki is a name known to allcbudrecki is a name known to allcbudrecki is a name known to allcbudrecki is a name known to allcbudrecki is a name known to allcbudrecki is a name known to all
Exclamation Pyramids
If you end up having two adjacent stacks of containers, then one container sitting on top of both stacks, do both stacks get cancelled as your multiplyer, just one of them, or neither?
Unread 05-01-2003, 20:35
blue blue is offline
#0116 (Epsilon Delta)
blue is an unknown quantity at this point
the matches are scored as such, the total number of bins in scoring area minus the height of tallest stack in shus times the hieght of the tallest stack. to clarify if you had to stacks of four next to each other with a bin strataling the two stacks it would be worked out like this:
total number of bins - 9
stack height in shu - 5
9-5=4*the stack height 5 makes your score 20
it is scored the same way as if you had a stack of five bins with four on the floor. i am under the impression that the scoring was set up the way it because of what you just mention, so height is detirmed by the shu not the number of bins in the stack.
"Even nonconformists hate a nonconformist who refuses to conform to the noncomformality of the day."
Unread 05-01-2003, 20:43
MikeWherley's Avatar
MikeWherley MikeWherley is offline
MikeWherley is on a distinguished road
Send a message via AIM to MikeWherley
Correct ...
I read the rules that same way!
Unread 05-01-2003, 20:46
Yan Wang's Avatar
Yan Wang Yan Wang is offline
Ithaca is Gorges
AKA: John Wayne
FRC #0639 (Code Red Robotics)
Yan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud of
Send a message via ICQ to Yan Wang Send a message via AIM to Yan Wang Send a message via MSN to Yan Wang Send a message via Yahoo to Yan Wang
LOL!! Yeah... we have someone on our team named, Shu... boy that's gonna be a lot of bad jokes.
Code Red Robotics Team 639 Alumnus | www.team639.org
<Patrician|Away> what does your robot do, sam
<bovril> it collects data about the surrounding environment, then discards it and drives into walls
Unread 05-01-2003, 20:53
Tom Schindler's Avatar
Tom Schindler Tom Schindler is offline
Now an AIR Striker....
FRC #0078
Tom Schindler has a reputation beyond reputeTom Schindler has a reputation beyond reputeTom Schindler has a reputation beyond reputeTom Schindler has a reputation beyond reputeTom Schindler has a reputation beyond reputeTom Schindler has a reputation beyond reputeTom Schindler has a reputation beyond reputeTom Schindler has a reputation beyond reputeTom Schindler has a reputation beyond reputeTom Schindler has a reputation beyond reputeTom Schindler has a reputation beyond repute
Send a message via AIM to Tom Schindler
I read the rules differently - i would think that all supporting objects of the tallest bin would be cancelled out... so in the example given with two stacks and a single bin on teh top, both stacks would be cancelled out.
Thats how i read it.
Tom
Unread 05-01-2003, 21:05
ColleenShaver's Avatar
ColleenShaver ColleenShaver is offline
Asst Dir, WPI Robotics Resource Ctr
FRC #0190 (Gompei and the HERD)
ColleenShaver is a glorious beacon of lightColleenShaver is a glorious beacon of lightColleenShaver is a glorious beacon of lightColleenShaver is a glorious beacon of lightColleenShaver is a glorious beacon of lightColleenShaver is a glorious beacon of light
Send a message via AIM to ColleenShaver
I have to disagree with that intepretation of the rule..
For instance, if you stack four bins but flip the top bin such that it counts in the five zone, then your intepretation would involve subtracting an extra point for a bin that is not in the stack.
Example: You have a stack of four bins and four other bins in your scoring area. The top bin in the stack is flipped over such that it extends into the "5" zone.
The score, I believe would be:
5 (for the stack) x 4 (on the floor) = 20 points
Your interpretation yields:
8 (total bins) - 5 (stack height) = 3 x 5 (stack height) = 15 points
But to answer the initial question about the pyramid stacking.. we discussed this today. I think it was our general determination that it would count as one stack of 5 and none of the 9 bins would count for points, based on the way the rules read. I think it's an excellent question to pose for FIRST for their clarification because it is not really stated in the rules. Another interpretation would be that one stack of four would count, and the other 4 would be counted as 1-point bins and the top bin negated because it is supported by both.
Colleen Shaver (Traitor) - Assistant Director, WPI Robotics Resource Center
FRC190 WPI/Mass Academy (2001-Present) :: FRC246 BU/O'Bryant School (2000) :: FRC126 Nypro/Clinton High (1996-1999)
Unread 05-01-2003, 21:06
Mark Garver's Avatar
Mark Garver Mark Garver is offline
AKA: Garver
Mark Garver is a splendid one to beholdMark Garver is a splendid one to beholdMark Garver is a splendid one to beholdMark Garver is a splendid one to beholdMark Garver is a splendid one to beholdMark Garver is a splendid one to behold
Send a message via AIM to Mark Garver
I read the rules differently...
I would disagree with you about not counting all supporting boxes because how would FIRST determine given the example that you gave, if one stack of boxes were pulled away would the box still stand? Since I dont believe FIRST to be doing this, I would say that only the one stack would be counted.
Unread 05-01-2003, 21:13
Suneet Suneet is offline
Physicist-In-Training
None #0599 (RoboDox)
Suneet is a splendid one to beholdSuneet is a splendid one to beholdSuneet is a splendid one to beholdSuneet is a splendid one to beholdSuneet is a splendid one to beholdSuneet is a splendid one to beholdSuneet is a splendid one to beholdSuneet is a splendid one to behold
Send a message via ICQ to Suneet Send a message via AIM to Suneet
That seems wrong. Height IS determined by SHUs, but the cancellation of points is NOT based on height (See rule SC8, below)
Tom
Agreed. Rule SC8 clearly says that "All containers in the tallest stack located in the scoring zone (the "multiplier stack") are worth zero points..."
So there's no room for mis-reading. All containers in the multiplier stack are worth zero points. This is NOT based on the height of that stack. Mind you, they might change this rule in an update. It seems a bit brutal.
Unread 05-01-2003, 21:25
Mr Obnoxious's Avatar
Mr Obnoxious Mr Obnoxious is offline
Mr Obnoxious is an unknown quantity at this point
Maybe this question should be referred to the FIRST forum
Unread 05-01-2003, 21:30
Merle Merle is offline
FRC Mentor, FLL Coach
FRC #3146 (GRUNTS)
Merle has a spectacular aura aboutMerle has a spectacular aura aboutMerle has a spectacular aura about
We brought up this pyramid stacking question to Woody at the Manchester, NH Q&A period. His answer was the total number of boxes in your area minus stack height (by measuring stick, not actual number of boxes in stack) multiplied by stack height (again, by measuring stick).
I agree that this does not match what the rules currently state and expect we will get a clarification to match the above counting method.
There is still an advantage to flipping a box upside down in that you don't have to lift it as high to get the next higher stack multiple.
Unread 05-01-2003, 21:36
Rusted_Grail Rusted_Grail is offline
Rusted_Grail is an unknown quantity at this point
A question that goes along with this is if a box is leaning or touching your multiplier stack, but not part of it, does it count for points
Unread 14-01-2003, 10:47
cbudrecki's Avatar
Thanx to update 3, this question has beeen cleared up. The update simply states that you take your total number of bins, subtract the height of the tallest stack, then multiply that number by your multiplyer.
Unread 14-01-2003, 21:32
Quentinfool's Avatar
Quentinfool Quentinfool is offline
#0217 (Thunderchickens)
Quentinfool is an unknown quantity at this point
bad jokes are an essential building block in FIRST arn't they?
what do you call a cow with no legs? ground beef!
"A strange game. The only winning move is not to play"-War games
Unread 15-01-2003, 14:51
Jeremy L's Avatar
Jeremy L Jeremy L is offline
Videographer, Team 177
AKA: The Basket Maker!
None #0177 (Bobcat Robotics)
Jeremy L is on a distinguished road
Send a message via AIM to Jeremy L
hehe...bad jokes
as long as we're on the subject of bad jokes...
what do you call a contortionist from the Philippines?
A Manila folder.
"Why is your team so successful?" "Two words: Good decisions."
"How do you make those?" "One word: Experience."
"How do you get that?" "Two words: Bad decisions."
Unread 15-01-2003, 15:17
Jeremy_Mc's Avatar
Jeremy_Mc Jeremy_Mc is offline
GitHubber
Jeremy_Mc will become famous soon enoughJeremy_Mc will become famous soon enough
haha...
anyhow, the rule (imho) reads that any bin touching a stack doesn't count...
i think they elaborated on this somewhere but i'm unable to find it right now...
*jeremy
GitHub - Collaborate on code, documentation, etc. - http://github.com
