Go to Post However, in the end, the renderer is only as good as the artist. - MiNT [more]
Unread 22-01-2012, 13:34
ProgrammerMatt ProgrammerMatt is offline
Programmer-Electrical-Mechanical
FRC #0228 (Gus)
ProgrammerMatt is just really niceProgrammerMatt is just really niceProgrammerMatt is just really niceProgrammerMatt is just really nice
Robot drive... Output not updated enough.
Im triying to call a digital in from the driverstation and when i enable the robot i get spammed with this line, any ideas thanks
Unread 23-01-2012, 22:19
carrillo694's Avatar
carrillo694 carrillo694 is offline
Alex Carrillo
FRC #0694 (Stuypulse)
carrillo694 is a jewel in the roughcarrillo694 is a jewel in the roughcarrillo694 is a jewel in the roughcarrillo694 is a jewel in the rough
Re: Robot drive... Output not updated enough.
This is affecting our team as well. Were you using the SmartDashboard at the time by any chance? We think it might have to do with that.
Unread 24-01-2012, 12:40
kgabbott kgabbott is offline
FRC #2035
kgabbott is an unknown quantity at this point
Our team was also having problems with this, but we found that it has to do with the RobotDrive object in your code. As long as it does not have access to the specified jaguars or there is no joystick, it will be unable to perform the task RobotDrive.arcadeDrive(), or whatever method you are using to drive. For testing purposes, just comment out everything having to do with RobotDrive and you should be fine.
Unread 24-01-2012, 15:14
loafdog loafdog is offline
AKA: Maciej
FRC #2876 (DevilBotz)
loafdog is on a distinguished road
Another thing you can do is call the RobotDrive method: setSafetyEnabled(false)
-Maciej
Unread 25-01-2012, 00:28
Alex Carrillo
-Maciej
That did the trick! Thanks.
Unread 13-02-2012, 17:52
NS_Radication's Avatar
NS_Radication NS_Radication is offline
Student
AKA: Marco Schoener
FRC #1369 (Minotaur)
NS_Radication is an unknown quantity at this point
Our program, test, was working on SimpleRobot and we switched to Iterative, but now the error for updating Robot Drive appear. I tried setSafetyEnabled(false) but that only stopped the error. Nothing moves and I don't know what to do
Any advice or comment would be helpful right now. Thank you in advanced!
Team 1369
Senior
Head Programmer (Java)
Head Electrician
Unread 13-02-2012, 18:17
Student
AKA: Marco Schoener
UPDATE: just after my post, the robot drive train moved. After a few minutes, it disconnected because a CRIO wire came loose. Then the autonomous made one motor move really slowly, which was not supposed to HAPPEN! Now it doesn't move again.
Any comments, advice, or anything else will be greatly appreciated1
Team 1369
Senior
Head Electrician
Unread 13-02-2012, 18:58
Patrick Chiang Patrick Chiang is offline
Programming
FRC #3070 (Team Pronto)
Patrick Chiang is a name known to allPatrick Chiang is a name known to allPatrick Chiang is a name known to allPatrick Chiang is a name known to allPatrick Chiang is a name known to allPatrick Chiang is a name known to all
Code?
Unread 14-02-2012, 17:06
joelg236 joelg236 is offline
4334 Retired Mentor & Alumni
AKA: Joel Gallant
joelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond repute
Our team has encountered this error a lot. It mostly has to do with either the Timer.delay() method or the robotDrive.setSafetyEnabled() method. Check to see also if your code contains
while(isEnabled() && isOperatorControl()) {
Unread 21-02-2012, 18:54
sebflippers sebflippers is offline
FRC #2914
sebflippers will become famous soon enoughsebflippers will become famous soon enough
Restart the driver station.
Unread 21-02-2012, 21:12
FRC #2914
Scratch that. It only fixed it for a second. After inverting one side of the wheels (only one line of code), everything stopped working again. This happened even after I stripped the code of everything except joysticks and robotdrive. Help!!!
Unread 27-02-2012, 17:50
CompSciGeek CompSciGeek is offline
FRC #0948
CompSciGeek is an unknown quantity at this point
Our team also had this problem, forgot how we solved it, BUT we did not use RobotDrive. Our robot is swerve Drive, so we had to code our own Drive class for swerve algorithms.
So it's not robot drive alone it seems.
Unread 28-02-2012, 11:18
FRC #0228 (Gus)
I just forgot to use the .getInstance();
Unread 28-02-2012, 18:50
Ian McShane Ian McShane is offline
FRC #3585 (Rogue Robots)
Ian McShane will become famous soon enoughIan McShane will become famous soon enough
We had the same problem and i somewhat forget what the problem was but i think restarting the computer helps. we also found out that we were calling for the same PWM port for 2 different objects i think.
in FIRST, it's process over product, and team over robot.
http://www.roguerobotsof4h.com/
Team 3585 Rogue Robots of 4-H
Unread 28-02-2012, 23:24
AlexD744 AlexD744 is offline
FRC #0744 (744 Shark Attack)
AlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond repute
This error message is a frustrating one because it would seem that this error would originate from the RobotDrive class, however, the real problem could be in any part of your code. This displays whenever your code is running too slowly, and will subsequently disable your drive functions (and probably everything else, not sure though, I haven't spent too much time trying the different functions when this has popped up). Anyway, this message appears a lot if you are doing image processing on the cRio because that takes longer than the 20mS loop time. Other (more likely culprits) include infinite loops (or any loop that lasts longer than 20mS), methods that call themselves without end (I had a setMotorSpeed(speed) method that called setMotorSpeed(speed) at the end of it instead of motor.set(speed)), and anything else that potentially stops or slows the code.
It may be helpful to add your own output messages throughout your code, then you will see what is getting called before the RobotDrive message, and it will probably point to the area of code that is causing the stop.
www.sharkattack744.com
