Go to Post Don’t let the medals you win and the trophies on your mantel define who you are. Let it be the lives you’ve touched and the legacy you leave behind. - Sean Schuff [more]
Unread 28-02-2012, 19:18
jaysun jaysun is offline
jaysun is an unknown quantity at this point
Using a magnetic encoder to get speed of a motor
We have a magnetic encoder mounted to a test motor and, using the magnetic encoder example code, we get a nice sawtooth signal that gives us a position. However, we cannot just calculate the speed of the motor using (current_position - last_position)/time because we would calculate an erroneous speed when the position loops from 360 degrees to 0 degrees.
Any ideas on how to work around this to calculate the speed of the motor?
Unread 28-02-2012, 19:29
plnyyanks's Avatar
Data wins arguments.
AKA: Phil Lopreiato
Re: Using a magnetic encoder to get speed of a motor
Can't you just WPILib's encoder VIs? Encoder Get has an output for rate, which is scaled accordingly to Distance Per Count (which you set when you opened the encoder in Begin.vi). That should do it for you.
If you can't/don't want to calculate Rate this way, you can do it this way:
average_rate = delta_position / delta_time
So...
average_rate = (current_position - previous_position)/(current_time - previous_time)
Unread 28-02-2012, 19:44
I believe WPILib's encoder VIs only work for the quadrature optical encoders, not the voltage-based magnetic encoders.
Edit: I guess WPILib's encoder VIs do work with the magnetic encoders. I might see if any of this helps.
Unread 06-03-2012, 17:03
For future reference, I would not recommend using a magnetic encoder to get the speed of a motor. While the readings are smooth, there aren't enough voltage changes in a second to differentiate enough between speeds.
